Results 1 to 9 of 9
Thread: My newest Mod
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    Angry My newest Mod
    My creaking control arm mod Anyone have experiance with this car only has 50k should I replace the noisy control arm or pull them out and put grease zerks in?
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Veteran Member Four Rings A4_Andre's Avatar
    Feb 13 2004
    99.5 Audi A4 2.8Q Tip
    Staten Island, NY
    mine actually started to creak when i hit the gas and the front rises... very annoying. will grease stop this.
    Veteran Member Four Rings SFexBOY's Avatar
    Feb 25 2004
    1990 BMW 325iX
    Staten Island, NY
    Mine creaked BAD this wkend. I sprayed some Prolong grease on all the possible joints, and it went away...for now.
    Feb 17 2004
    Sterling, VA
    The creaking almost always comes from the bushings on the lower arms. You can spray grease on the hole that the bolts travel though but, it won't go away completely.
    The cause of the squeak is that the bushing shrinks and now there's play between the metal collar inside the bushing and the bushing itself. As the arm pivots, the rubber slides against the metal collar and the squeak occurs. Since it's bolted to the subframe, the rubbing also vibrates the subframe bracket and the noise is more pronounced.
    If the bushing is worn, there's a good bossibility that the balljoints will be too. Mine started to squeak at 70K right after I changed my suspension (struts/springs). I replaced all my control arms and stabilizer links in Feb. and I haven't heard a peep since.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    Mine are fine, i just need an alignment very bad.
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
    Sold:1997 Audi A4
    thanks guys I think I'm gonna spray it down and see if I can get it to quiet down and plan on getting the Meyle heavy duty kit later on...there goes another $600 bucks + alignment
    Alex
    Registered Member Two Rings
    Feb 22 2004
    Portland
    contral arms
    I have squeaking and clunking , Matrix says its the upper control arm going bad.
    Europa Audi A4 Quattro
    Veteran Member Three Rings Brrman's Avatar
    Indianapolis
    If the creak is coming from a bushing that has a rubber grommet you can inject grease into it. That stopped mine last fall. Took 3 days of driving to stop, but then it was gone all winter and hadn't come back.
    2019 S4 Prestige
    RIP... 2013 A4 Allroad
    SOLD 2007 A4 2.0T S-Line Ti (APR stg1, Koni Coilovers, LED Tails)
    SOLD. 2000 A4 avant 1.8T (GIAC stg1, Bilstein/H&R)
    RIP... 1998 A4 1.8T (GIAC stg1, Bilstein/Neuspeed)
    Veteran Member Four Rings minira's Avatar
    Feb 13 2004
    Jurupa Valley
    i think mine is starting to get a lil bit more squeaky. should i do something now? it doesn't annoy much at all, it's just whenever i go over speed bumps.
    77 Porsche 911S
    13 RS5
    14 Porsche Panamera GTS
    16 Tundra PRO
    20 Sequoia PRO
    07 zx6r
