Results 1 to 7 of 7
Thread: This Sucks!!
    Aug 03 2004
    Oklahoma
    This Sucks!!
    My passenger side back window shattered when I rolled it down the other day. Does anybody have some experience taking the door panel off and installing a new window? I see 2 screws and I am betting the rest is held in with snaps.Also..... where is the best place to buy glass . I am in Oklahoma. Thanks for any help. ~Jordan
    Veteran Member Three Rings chrisrunner's Avatar
    Feb 12 2004
    97 A4 1.8t, 2000 BMW 328i
    boston area.
    to take the panel off there are a total of five screws....one at the front side of the panel near the side mirror which can only be seen while door is open....one at the back side of the panel at the top..then unscrew the one underneath the handle that is near the window controls...slide that down using a flat head screwdriver...underneath that are two screws....take those out....slide the door up and off and youre all set....unclip all the wiring and watch out for the power door lock button, mine seems to have a knack for coming out very easily...hope that helps
    chris.
    chris.
    http://img.photobucket.com/albums/v9...ri/Driving.gif
    you call it your right. i call it your weakness.
    Veteran Member Four Rings Jon_Rhea's Avatar
    2001 S4 6 spd MT
    Manchester, TN
    There are the two screws that you see, on the top corners and one on the inside of the handle. Then when you get that 3rd one out, the black plastic slides down and exposes another. Then lift straight up and off it comes
    2001 Nogaro Blue S4
    May 13 2004
    New Jersey
    there is three more screws in the door handle, right where you grab your door when you wanna close it or open it
    Aug 03 2004
    Oklahoma
    Thanks for the quick help !
    2000 S4 Black/Grey 6spd NoMods
    Account Terminated Four Rings MR VTEC's Avatar
    98.5 Audi 1.8TQM
    Brooklyn
    how does that happen i bet it was some squirrels!
    Fockers!
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    Thats weird, what happend?
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
