What is important to note, is that of the four plots that I was able to get, none of them differed by more than 6hp or 12lb/ft of torque. All runs were performed utilizing 93 octane Mobil fuel. The only cooling utilized was the DSMICs and three shop fans.
The following is one of the average plots received during my first set of runs. The folling run was done after the car was sufficiently heat soaked. All NUMBERS are AT THE WHEELS.
The next run was an average of the second set of runs after installing the Level 1 N75 valve sleeve. This is the most conservative of the sleeves. Again, the car was sufficiently heat soaked and this is the second of three runs during this session.
The above runs are some examples of some average runs the car made. I was able to achieve between 199whp and 205whp during the sessions. Torque was between 249 lb/ft and 261lb/ft at the wheels.
I would like to thank Anthony at Greedspeed for getting out those N75 Valve sleeves. I will be returning to Champion in a couple weeks to test out the other two sleeves (Level 2 and 3). Thanks to Ben and Edick for spending a considerable amount of time explaining all that was going on to me and for making me feel part of the process. Also thanks to Joe, Mike, Ken, and Ashley over at Joe Hoppen Motorsports for getting this car running as well as it does. Cheers! Mike
