Results 1 to 12 of 12
    Veteran Member Four Rings quattroanillos5's Avatar
    Feb 13 2004
    2004 S4 MT6
    Jersey
    lower door trim???
    does anyone know wher i can get the lower door trim for a decent price..... checked mine the other dat and it appears that htey are rusting..... i need to get them off asap.....
    sold:
    1999.5 B5 A4 1.8T quattro MT5
    current:
    Moro Blue 2004 B6 S4 MT6
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    www.ecstuning.com very common problem just repaced all mine.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Feb 13 2004
    2004 S4 MT6
    Jersey
    did you have to replace all the clips as well..... how do the clips come off? do they just pop off or do they have to be drilled out?
    sold:
    current:
    Sold:1997 Audi A4
    Your gonna have to drill the screw on the inside of the doors...but otherwise all my clips were fine. They just pop off once you get the screw out. New ones clip back on use a new screw and your done.
    Alex
    Senior Member Two Rings BuffysRS4's Avatar
    Jun 12 2004
    Audi A4 1.8T, Audi Q7 3.6 Prem
    Markham, ON - Eastvale, CA
    No you don't need to, the trim slides off the clips after removing the one screwholding it in place. Just clean off all the dust and grit that has accumulated behind you old trim and slide the new ones on, simple.
    "Speed kils, drive better"
    2007 Audi Q7 3.6 Premium
    2004 Volvo XC90 T6 AWD (TRADED POS)
    1999.5 Audi A4 1.8TQM
    1996 Mitsubishi Montero LS
    1993 Geo Storm SiR (RIP)
    1992 Mazda 323 (RIP)
    Registered Member Three Rings
    May 28 2004
    00' VW MKIV GTI GLX
    PNW - 509 reppin' hard
    "93 Geo Storn SiR"
    Am I reading that correctly?
    MKIV GTI GLX
    Q7, Q7, F-type manual
    Whats with that. Why did such a simple job of removing the moldings have to get complicated? Three out of 4 of mine werent coming out, so I ended up drilling them.
    Mar 27 2004
    2001 A4 1.8T
    PA
    The screw goes into a metal piece that is molded into the plastic. This metal bit comes loose from the plastic very easily it seems. But you can pry the molding off and then use a pair of pliers to hold the (now) exposed bit so you can turn the screw. No need to drill anything. This assumes you are replacing your moldings of course.
    2001 A4 1.8TQMS - SOLD
    Mods: APR 93 octane, Milltek Catback, 710N, V&S SS, RS4 grill, RS4 reps, Sport Seats, AWE DTS, Neuspeed 19mm w/ metal end links, S4 wheel liners, PureMS Strut Bar
    Convenience: "one touch up" rear window mod, PhatBox
    my Member Gallery
    That would be too easy. Even with pliers on one side of the screw and the screw driver on the other, I couldnt get it out. The screw driver just kep slipping off the end (they must have been really rusted together). Simple job became a pain in the a$$.
    Mar 10 2004
    08 A4Avant 2.0T
    Thumbs up
    BTW I have a complete set of OEM door trims from my '01 A4 waiting for someone who needs a replacement set. LMK
    I am swapping for S4 sides.
    '17 A4 Allroad
    '08 A4 Avant 2.0T Titanium Edition
    '11 TTS Coupe (sold)
    '01 A4 Avant 1.8T S line (sold)
    '90 CQ 20v (sold)
    '95 VR6 "Getta" (sold)
    '85 4000s quattro (sold)
    May 06 2004
    W124s
    PA
    I have a BRAND NEW passenger side front peice I can part with for less than cost... I bought all new ones from impexfap.com, cheapest place I could find them. LMK!
    Mar 27 2004
    2001 A4 1.8T
    PA
    That really sucks. I hate when crap like that happens (all too often).
    my Member Gallery
