Results 1 to 13 of 13
Thread: idle questions
    Veteran Member Four Rings bOOOOstedAudi's Avatar
    May 27 2004
    C6 A6 S-line 3.0T Quattro, BT B7 A4 2.0T S-line Quattro
    Sacramento, CA
    idle questions
    When I was in Cali my car started to idle roughly when I have the ac on. It doesn;t do this when its off but its annoying. I was thinking maybe it was the oil I put in but i doubt it. I usually use Castrol Syntec but for the first time evr I used Mobil 1 0w 30. What could possiblely be wrong?
    May 20 2004
    More cars
    Never Land Ranch
    your car has to make extra juice to support the AC, and will cause your car's needle to just a bit. Nothing to worry about. If you want to make sure, try letting your car idle, and either turn the steering wheel, or(While the windows are up) just try and close them, your needle will jump around too.
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Veteran Member Four Rings littlewhite's Avatar
    PNW Rainy States
    Re: idle questions
    i use mobil ow40 winter time. Since CA is quite warm, try movin up to 5w30 or 10w40
    Littlewhite
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    its normal, mine does the same thing
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    Re: idle questions
    if you have access to a vag-com check your maf readings and find someone with a similar setup to compare data with. i was having idle issues and it turned out to be a bad maf and primary o2 sensor. woo hoo yeay 2000 maf recall oh well at least i get one for free.
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    mine does that from time to time.
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
    Jun 08 2004
    2001 A4 1.8TQ tip
    Quakertown, PA
    My car is doing the same thing with A/C on. I noticed that the vacumm pressure is less when I have the A/C on than without.
    It's idling much more roughly than normal. I can see the steering wheel vibrate with the A/C on at idle.
    2001 A4 1.8TQ tip: GIAC; 710N; RS4 grille; H&R Sport/Bilstein
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    normal, and i agree with moving your steering wheel all the way to either right and left and watch the needle, it will move irratic. totaly normal and have nothing to wory about.
    May 27 2004
    Sacramento, CA
    i knew it was somewhat normal but when i noticed it it was really shaking.
    Apr 07 2004
    San Diego, CA
    Mine shakes even when the AC is off. It idles low at like 700 rpm. Also the check engine light is on. I VAG'ed it and it came out with and idle response error. I think i might try changing the spark plugs, im not sure if that will fix the problem.
    "All the dude ever wanted was his rug"
    Mar 02 2004
    Orange County
    just a random thought but you might try a throttle body adaptation
    Apr 07 2004
    San Diego, CA
    I tried that, didn't do anything.
    Registered Member Three Rings BoostinA4's Avatar
    Jul 12 2004
    thats normal mine does the same thing it drops to about 700rpm then jumps back up and it does that when i roll up the windows
    http://www.audizine.com/gallery/data...765sig-med.jpg
    http://www.cardomain.com/memberpage/589435/4
    -----FOR SALE HERE!!!-------
    ATP manifold
    T28 wastegate
    440cc greentops
    RS4 bumper
    (2) Sparco 3pt harnesses
    HKS ssq BOV w/adapter
    (2) 4 bar FPRs
