Results 1 to 12 of 12
    Senior Member Three Rings ItsJ's Avatar
    May 26 2004
    BMW 335i
    U.S.
    rubbing compound trouble
    ok i recently debagged my car, the left side came out great however the right side had some minor scratches when i took off the badges, so i used a little bit of rubbing compound, after i did that i used so wax on a rag to buff the area, however now there is a slight dull look in that small area from the rubbing compound, my car is black and that small area looks somewhat grey, like is someone took there sweaty fingers and made a smudge on the car???
    anyway to fix it???? claybar???
    thanks
    Current: 2008 BMW 335i
    Past Audi:
    -2002 Audi TT
    -2002 Audi S4
    -2001 Audi A4
    Veteran Member Three Rings Brrman's Avatar
    Indianapolis
    Does it still feel smooth to the touch? If so you might want to try a glaze and then a wax again. If it feels rough then you may have rubbed through the clearcoat. How much compound did you use - and for how long?
    2019 S4 Prestige
    RIP... 2013 A4 Allroad
    SOLD 2007 A4 2.0T S-Line Ti (APR stg1, Koni Coilovers, LED Tails)
    SOLD. 2000 A4 avant 1.8T (GIAC stg1, Bilstein/H&R)
    RIP... 1998 A4 1.8T (GIAC stg1, Bilstein/Neuspeed)
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    Basically you scratched your paint with the compound. You now need to go over it with some polish to get the scratches out.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Mar 22 2004
    B6 S4 6MT
    Los Angeles, CA
    A solutuion from Pepboys. It's made by Turtle Wax I think. It comes and black with what looks like lipstick. The stick is for scratches. The bottled wax restores color. I used it on a black GTI at work. Give it a shot.
    Registered Member Two Rings
    Aug 01 2004
    83 Rabbit shell, 99 Avant
    Schaumburg IL
    I Would try clay bar. It works wonders
    I debadged my Avant this past weekend and since the badges have been on there since 99 there was some nasty dirt and buildup and it took it right off, just make sure to wax or polish the area after clay baring it.
    *Sara*
    Past: 01 Bosered JTI, 1999 Avant SLAMMED to the ground
    Present: 2005 Subaru WRX
    ...Team bag-tag, not the cool kids club...
    May 26 2004
    BMW 335i
    U.S.
    its smooth, it just a bit greyer looking in one area, its still black though.... i will try to find the glaze at pepboys, is there a specific company???
    what would the claybar due
    Past Audi:
    -2002 Audi TT
    -2002 Audi S4
    -2001 Audi A4
    Aug 01 2004
    Schaumburg IL
    it removes dirt and stuff thats embedded in the paint
    *Sara*
    Sold:1997 Audi A4
    Don't bother with the claybar. It won't do anything for scratches.
    Don't waste your time with glaze either it will make it look better temporary basis by filling in the scratches but won't fix the problem.
    Here's what you did you put very light scratches in your paint by using compound. Don't worry though it's not permanent. You just need to use a polish to buff the scratches out. Use a soft cloth too or you will just scratch it and make it worse.
    I do know what I'm talking about I used to be a professional detailer. Just be careful black can be a real pain to work on if you don't know what your doing.
    Alex
    Mar 22 2004
    B6 S4 6MT
    Los Angeles, CA
    He's right. I didn't know how bad your scratches were. Good luck anyways.
    Indianapolis
    yeah claybar is great for deposits on the paint, but does nothing for scratches. I use Meguiars #7 Show Glaze. Works very well, but like BurntAudi says, a polish, which is a slightly heavier cut thant glaze will work better for the scratches you are dealing with.
    2019 S4 Prestige
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    ok time for my opinion..professional body worker. get yourself some foam polishing compund and a electric buffer and foam pad and buff the area with the compund and that will restore the are to its brillant shine..however you might find yourself doing the entire car later one
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Sold:1997 Audi A4
    I thought of that too...but he could do more damage than good if he's never used electric buffer.
    If it was my car that's exactly what I would do...but a buffer in the wrong hands can do a lot of damage.
    Alex
