Results 1 to 23 of 23
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    Here is a teaser for you guys on those dyno runs...
    The best run of the day was done under less then ideal circumstance, 100 degrees F in the dyno room and the dyno's computer crashed twice so we had to reboot the system. The car got heat soaked a lot, I saw 70 C intake temps on the VAG COM. Still got good results but decided to cool the car a bit before doing a last run.
    Anyway we managed to pull under these conditions, 215 HP at the wheels and 285 ft/lbs of torque at the wheels at around 3100 RPM. Not too bad.
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Thats not to shabby.
    Veteran Member Four Rings neoprufrok's Avatar
    NOR CAL
    What's the total increase (over stock) on that Jet, and what's the difference between today's and your last run...
    Currently:
    2018 GT3 Touring - Graphite Blue Metallic
    2016 McLaren 675LT - Mexico Blue with Roof Scoop
    2019 BMW M4 Convertible - Yas Marina Blue Competition Package
    Will be missed: 2001.5 Audi S4, 2004 Audi A4, 2004 Audi A8, 2008 Audi RS4, 2016 Porsche Cayman GT4, 2018 Porsche GT3.2, Mercedes C63 Black Series, McLaren 12C Spyder
    Podcast and Instagram: The Throttle Dogs
    Jun 17 2004
    Montreal, Canada.
    Today it was 100F on the last runs in the dyno room vs 84F last time, but there is more to it then that which I will explain later.
    The total gain so far is 90 Hp over stock and about 130 ft/lbs.
    NOR CAL
    Man... nice numbers!
    Currently:
    Established Member Two Rings teknik's Avatar
    Mar 20 2004
    FL
    I know its not apples to apples, but arent these numbers similar to the e05 kit? which uses a bigger compressor then the ko4???
    ///MONEY PIT MOTORSPORTS
    95 318ti S52 Turbo aka The Money Pit
    95 M3 - DD - Green Machine
    Jun 17 2004
    Montreal, Canada.
    I don't know the answer to that.
    Veteran Member Four Rings DLSJ5's Avatar
    Feb 12 2004
    2005 M3 ZCP
    LA, CA
    Mike,
    Awesome numbers, and here I was saying a K04 couldn't put out those figures, I'm glad you proved me wrong. MTM needs to change their HP #'s for the Stage 3, Avalon says 230CHP, and Hoppen says 250CHP, you shattered both of them!!!! Awesome!
    Mar 20 2004
    FL
    MTM doesnt like to brag....
    Jun 17 2004
    Montreal, Canada.
    Originally posted by DLSJ5
    Mike,
    To be fair, MTM usually plays it safe with their numbers. Also my car is tweaked what you could call a standard MTM Stage 3. I did polish and port the manifold and I do have the duals which may help and the turbo inlet pipe. If I have time I will post three seperate dyno runs with three different settings.
    Feb 12 2004
    2005 M3 ZCP
    LA, CA
    To be fair, MTM usually plays it safe with their numbers. Also my car is tweaked what you could call a standard MTM Stage 3. I did polish and port the manifold and I do have the duals which may help and noe the turbo inlet pipe. If I have time I will post three seperate dyno runs with three different settings.
    Sounds good, you never fail to deliever on the details!!! I realize that you're not just the basic MTM stage 3, but PP will only give you so much, the Duals marginal, the turbo inlet pipe maybe 5? Also the E05 hit 270Hp and I doubted that as well, so what do I know! I think with the right fuel, tuning and patience that it's possible. I think your attention to detail, quest for perfection and your knowledge has played a part in your success as well. Not to mention the ambient temps were not ideal in this latest dyno run and the fact that you hit such good numbers. I mean people always say it's the dyno and I always criticize those who blame the dyno, so I'm going to take your runs as facts. Excellent job Mike, looking forward to seeing the comparisons.
    Jun 17 2004
    Montreal, Canada.
    Thanks Drew.
    Veteran Member Four Rings astris's Avatar
    Mar 03 2004
    nothing
    San Diego
    That is a lot of torque. That thing must launch like crazy now.
    Veteran Member Four Rings A4 - Oh Snap's Avatar
    May 03 2004
    Irvine, CA
    isn't the MTM Stage 3 really expensive relative to the Revo / E05 setup? Or is it fairly close in price?
    Mar 20 2004
    FL
    mtm stage 3 is pretty much a complete kit less the clutch.. but its still quite expensive for a k04 setup....
    qaulity is top notch though..... youd have a hard time finding a better exhuast system...
    Jun 17 2004
    Montreal, Canada.
    Mike,
    The 230 CHP is the figure MTM uses in Germany, TUV?
    In England the distributor uses 240?
    Inthe USA Mike decided to use the 250 Hp and 255 ft/lbs after talking to the technician at MTM Germany. I would think that the Hoppen figures are most likely closer to the real numbers.
    Jun 17 2004
    Montreal, Canada.
    Not expensive, very expensive and that's all I'm going to say about that.
    Palo Alto, Ca
    You get what you pay for thou
    NOR CAL
    Yes you do. They're reliable kits and very rarely have I seen anybody get a failure with them. MTM does their research and I've always been impressed with their products.
    Currently:
    Registered Member Four Rings A4NCAR's Avatar
    Feb 12 2004
    Yes it is, $6500. It includes the full DP/CAT exhaust system though (which alone is around $3600). So, as some have pointed out, you can get an alternative power upgrade like this, but cheaper.
    There are reasons, as pointed out many times, why MTM is more expensive though (exchange rates, TUV costs, R&D,..etc). Same for Sportec. Just part of the inevitable consequence of buying a kit from Europe.
    Feb 12 2004
    Ahem
    Feb 12 2004
    Wow! So around 260hp / 290 ft/lb torque. MTM/JHM #'s were very conservative. Now if only my Stage 2 #'s were as impressive for 91 octane on my car. I should see better then 215hp / 245 lb/ft torque with the DP/CAT, TIP,.. etc. But wait, I keep forgetting I have 91 craptane (and no disclaimer was ever mentioned about that).
    NOR CAL
    Originally posted by A4NCAR
    Ahem
    Hahahaha...lol.
    Well, impressed with everything but how Hoppen has handled your issue with the MTM software/hardware.
    I have to have hope!
    Currently:
