Results 1 to 6 of 6
    Registered Member Two Rings
    Mar 16 2004
    Audi A4 1.8T
    Akron
    Throttle problem
    Heres my two problems.
    Vehicle: 99 Audi A4 1.8T
    no engine mods (yet)
    Problem 1
    My timing belt broke which in turn bent my valves. I had a new head put on. I got the car back and it has no throttle response. Its very slow coming from a dead stop. When I lay on the gas at high speeds the rpms go up at first then drop for a second before they start going up gradually. The car is very slow now especially at slow speeds it seems like when I press on the pedal the rpms rev high but the car just doesn't actually take off as fast.
    Any help would be appreciated.
    Is there something I can do. new seals? Reseal any of the hoses.
    Or is the problem somewhere else?
    Problem 2
    When I got the car back I found out that the service place broke a piece on the throttle body. its the part where the throttle cable wraps around that wheel and the end of the throttle cable is held on by a wire tie. Does anyone know where to by a throttle body and if so is there a better or upgraded throttle body I can purchase instead of the OEM? I don't know a lot about this so any help please.
    I will provide more detail if anyone needs it to help me.
    Thanks all!!
    Account Terminated Four Rings MR VTEC's Avatar
    98.5 Audi 1.8TQM
    Brooklyn
    make them replace it free they broke not you. They need to fix it!
    Mar 16 2004
    Audi A4 1.8T
    Akron
    I would but right now thats a whole different situation. I want to see what I can do.
    Veteran Member Four Rings D Piddy's Avatar
    Feb 12 2004
    Me: 2010 B8 A4 S-Line In the Family: BMW Z4M, BMW 335xi, Range Rover Evoque, Honda Element
    Washington, D.C.
    that first problem soudns liek a clutch to me. from wut i've heard, if the RPMs go up fast but the car does not. it's time for a new clutch! but a 99 with no mods seems odd to have a clutch go so soon
    Mar 16 2004
    Audi A4 1.8T
    Akron
    It has the A/T transmission.
    Feb 12 2004
    Washington, D.C.
    still could be related to that, but i'm no expert, it's just a suggestion
