Results 1 to 22 of 22
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    Water misting pump. (EDITED WITH PICTURES)
    Just tested my new water pump for the water misting system.
    That pump sure pumps a lot of volume. It took it only 2min 53sec to get a full W/W reservoir down to the low warning signal.
    My first test on the road shows a drop in temperature of at least 25 to 30 degrees Celcius in the intake, perhaps even more. I intend to set up a course to test the system with and without the mister working and to get a better picture of what the temperature drop is.
    Feb 10 2004
    2019 Mk7.5 Golf R His/Her
    Eastvale
    nice keep us posted.
    Instagram: @daohaus_garage
    Veteran Member Four Rings zemun2's Avatar
    Feb 20 2004
    '04 A4 1.8t FWD APR Tuned
    Zemun, Serbia.
    Jet,
    Got any pics of the setup?
    APR Tuned Serbia
    Authorized APR Distributor
    Established Member Two Rings teknik's Avatar
    Mar 20 2004
    FL
    is this based on the avalon IC mister kit?
    what kind of chore was it to get to work with the car?
    ///MONEY PIT MOTORSPORTS
    95 318ti S52 Turbo aka The Money Pit
    95 M3 - DD - Green Machine
    Jun 17 2004
    Montreal, Canada.
    Originally posted by zemun2
    Jet,
    Yes I do, but it might be a while before I get them on here at Audizine. I would have to download a ton of pictures. The only pics I don't have are the actual install of the pump itself (no digi cam at the time), but again L-Sport did a fantastic job. They custom made an aluminium bracket to fit tha car's frame, welded stainless steel clamps to it to secure it in place and used a big samco hose to damped the vibs. It is secured in the frame by aluminium gromets which hold the bracket in place. I will have to take pics of that little job soon when I can borrow my friends digi cam.
    BTW, do you want the whole install including the electronics?
    Jun 17 2004
    Montreal, Canada.
    See post above^^^.
    Feb 20 2004
    Zemun, Serbia.
    Yes please Jet,
    Post as much info as you can. I still haven't decided between NX CO2 mister or just plain water mister.
    APR Tuned Serbia
    Jun 17 2004
    Montreal, Canada.
    Water mister installation...
    Yes please Jet,
    Here we go guys...First I would like to thank Luc and Claude from L-Sport in Montreal for the designing and installation of the water misting system.
    First the electronics.
    First I decided to buy from Avalon in Denver the eLabtronics water mister controller. It comes complete with all the wiring harness, thermometer, fuse and a CD with the instructions on how to do it. You could buy it directly from Australia but it would not be as complete a kit.
    First pass the main wiring harness of the mist controller from the cockpit side through the firewall and up through the ECU housing.
    Now take the grey sleeve of the wiring harness and take it off to expose all the wires. Lay down the wires towards the front of the car. These wires are for the units own thermometer sensor and for the cockpit mounted thermometer
    Now remove the big rubber hose that allows the car's main ECU harness to go through the firewall and pass through it a long screw driver. This is necessary to pass your mister controller's own wiring through the firewall. Once the wiring is passed through, re-install the rubber hose in place.
    Now here comes a more delicate operation. This is where I deviate from Avalon's instructions to make a neater job of it. Avalon suggest that you run a wire to one of the injectors on the manifold. I on the other hand decided to tap the injectors signal wire right here in the main ECU plastic box/housing where it is protected from the environment. Take a close look at the car's main wiring harness from the ECU. You will see in the background slightly out of focus a small bent green wire. You will also see that right after the bent point the wire is bare, the sleeve as been removed. In the foreground you can see a larger red wire. The green wire is from one of the injectors (signal) and the red is from the mister controller. By splicing these two together the mister controller will know instantaneously when the injector is commended to give fuel.
    Now for the actual soldering of the two wires together. Once done, secure the wires by taping them up.
    Another angle on the completed job. The big green wire crisscrossing the red mister controller signal wire is the wire used to power the pump.
    Now wrap the lose thermometer wires in the engine bay with a new plastic sleeve. These wires will end up somewhere in the front of the car. One sensor, the one with the two steel prongs will be pass through the left side I/C to read the air temperature in that I/C. The other sensor, the black one near the date in the picture, will be secured behind the I/C by the other one to give you a temperature reading in the cockpit. Finally the third sensor, by the technicians thumb and above the bolt, will be installed in the air duct on the left side of the car just ahead of the I/C.
    In the cockpit, the installation was rather simple. The kit comes with its own fuse so we installed that near the fuse box for easy access. I can't recall at this time where we connected it for power. The actual location where the controller is installed is in that slot below the steering wheel, perfect fit. I left enough of an harness to be able to pull it out to adjust it and to turn it on and off. I must have about three feet of harness. One reason I did this was to have easy access to it. I installed a bypass switch to the unit. I can spray on demand without having the car running. This way while I'm a line up in an autocross competition, I can spray my I/Cs as I wish to keep them cool.
    Finally the digital thermometer. I installed it dead centre just above the steering wheel. As you can see there are two read outs. Since this unit is nothing more than an indoor/outdoor home thermometer, the one on the left will give you your ambient temperature inside the car. The one on the right will give you the temperature coming out of the I/C. Sorry the pic is out of focus. That's it for the electronic side of things.
    Now for the hoses and nozzles...
    Basically I use the same type of hoses used by Audi for the headlight washers. I use one hose from the pump to the midway point of the front bumper. There I use a T fitting to go to each side of the car to each I/C. Since this year I decided on using two nozzles per I/C, I have to use two other [b]T[/b} fittings to split the hoses for each I/C. That way the pressure and water delivery remains constant and equal to both sides. Her in this picture the first and main split is where the man hand is at the top of the bumper. Coming towards the right side, you can see near the end of the aluminium bumper the second split. You can see the hose run at the top of the air duct to the top nozzle. You can also see the bottom nozzle (in white) coming through the bottom side of the duct. The same scenario is repeated on the other side.
    Picture showing the assembly, including the top hose and nozzle, bottom nozzle, horn and the right side I/C.
    Now for a close up picture.
    Close up of the nozzle spraying under low pressure condition. That's it for the hoses and nozzles.
    Now for the pump...
    On my 2002 car, I used the headlight washer pump. This turned out to be a problem. Because they are not meant to run as often as they were been used, I killed two pumps. So this year I decide to get a real pump.
    This picture shows you the headlight washer pump with my car key to show you a perspective on its size.
    Now get ready to be blown away. The OEM pump vs the Mickey (that's me) pump! IIRC this thing can move upwards of 3.3 gpm at up to 45 psi.
    Here is a side by side comparo.
    Another angle. That's it, that's all for now. Hope this helps you out. When I get the digi cam back I will show you the actual pump installation on the car.
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Damn, thats just nutty!! One of these days i'd like to do something like this, now that i have Dual IC's.. But my list of things to do is long, and this mod is towards the bottom
    Someday thou
    GTA, Canada
    Awesome work Jet, that's quite an addition.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Feb 10 2004
    2009 A4 2.0T Sedan
    That's a fantastic write-up! Going to have to add this to our new Tech Forum, if you don't mind...
    Veteran Member Four Rings Wilafur's Avatar
    Feb 12 2004
    Los Angeles (Westside)
    the pump is gargantuan. nice write up!
    Veteran Member Four Rings DLSJ5's Avatar
    Feb 12 2004
    2005 M3 ZCP
    LA, CA
    As always Mike great work and detailed pics. I called Zev at Avalon today to see about getting the kit, currently they're out of them, he's gonna see what he can do to get me one soon. This is not only a nice performance gain but another saftey mechanism to battle possible detonation and the fact that you saw a 25C drop can reduce that! Amazing stuff, no wonder the STI's come with these misters stock. Good work!
    Did your dyno runs include the misters? I think you said they didn't.
    Jun 17 2004
    Montreal, Canada.
    No they did not. I wanted to keep them out to keep a certain level playing field.
    Jun 17 2004
    Montreal, Canada.
    Sure go ahead if you think it is good enough.
    Palo Alto, Ca
    So wait.. Do you have vented wheel liners?
    Veteran Member Four Rings neoprufrok's Avatar
    NOR CAL
    Wow great writeup jet! As always, great info and great pics!
    Currently:
    2018 GT3 Touring - Graphite Blue Metallic
    2016 McLaren 675LT - Mexico Blue with Roof Scoop
    2019 BMW M4 Convertible - Yas Marina Blue Competition Package
    Will be missed: 2001.5 Audi S4, 2004 Audi A4, 2004 Audi A8, 2008 Audi RS4, 2016 Porsche Cayman GT4, 2018 Porsche GT3.2, Mercedes C63 Black Series, McLaren 12C Spyder
    Podcast and Instagram: The Throttle Dogs
    Jun 17 2004
    Montreal, Canada.
    No, I was told that on the B6 it would perhaps create more problems then without. But I know someone with the duals trying it and we should know soon.
    Palo Alto, Ca
    How would it create problems? Doesnt the air need to go someplace once it hits the IC?
    Veteran Member Three Rings 02A4TURBO's Avatar
    Feb 12 2004
    Phila, PA
    How do misters generally work? Do they spray automatically when needed? Is it manual? When would one hit the switch?
    Very curious about a setup like this. I'm going with Revo Injectors Software.. but I'm not gonna have the money to do exhaust nor FMIC at the same time. That said, I worry about heatsoak as its gonna be hard for me to get the hot air out of the car.
    I wonder if a mister system would be a good way to combat this before I pull the trigger on test pipe, exhaust, FMIC, etc.
    Thoughts?
    2017 RS7 4.0T | Daytona Gray Pearl | RS Black Seats | Sport Exhaust | Alu-optic Intakes w Quattro Script | Red Brake Calipers | 21" 5 spokes |
    2017 Q7 3.0T | Ink Blue | Premium Plus | Nougat Brown | 20" 10 spokes | Vision | Warm Weather |
    Veteran Member Four Rings Awadd9's Avatar
    Oct 04 2004
    North Jersey
    Re: Water misting pump. (EDITED WITH PICTURES)
    Next step Aquamist? I would like to ee someone move to an H20 Cooled set-up.
    Too confirm thi is an intercooler mister?? just want to check.
    KO4 is up and running btw
    Oct 04 2004
    North Jersey
    Watercooled , Watercooled. Aquamist, go for it..
