Results 1 to 6 of 6
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    Engine start problem - ignition stage - help
    when i turn my key to start the car i hear the normal ch ch ch ch ...engine. It turns over right 80% of the time. Recently it has been inconsisted with its start noise. It might ch.....ch.... engine. Or it sounds week like its about to not start and then just catches. I went to the local auto parts store and they ran an electrical test and found nothingn to be wrong and of course when they asked me to start it, it started up perfect. Any advice would be good
    ch = the best letters i could put together to make the starting engine ignition sound
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Veteran Member Four Rings Starting's Avatar
    Feb 13 2004
    98 A4 1.8t
    Central, NJ
    I'm thinking the starter has a dead spot. Next time it doesn't want to start see if tapping the starter with a hammer works if it does theres your problem.
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    will it cause future problems, or can i just let it go
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Feb 13 2004
    98 A4 1.8t
    Central, NJ
    if it is the started it will eventually not work anymore and not start your car. I'm interested to see what other people think on the subject.
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    im hoping to my car on the vagtool from someone local soon to see what the deal is
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Registered Member Two Rings Focal X's Avatar
    Apr 28 2004
    Norfolk, Va
    Well I can tell you if you car craps out within the next couple months, it might be the fuel pump. I had the same exact problem, then the pump died, and I put a new one in and it never did it again.
