Results 1 to 26 of 26
    Senior Member Three Rings L3x's Avatar
    Apr 07 2004
    More bad news...
    Well it seems as if I fried my ECU... I was putting in my stock chip back in because I'm switching back to stock for a bit until I get my GIAC chip. I hooked everything up, fired it up, but my car wouldn't start. I checked everything to make sure it was in the right position then tried again, and nothing. I put my GIAC chip back in, tried again, but no answer...
    Did I fry my ECU? Or just my chips?
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Thats odd... did you do a TBA?
    Maybe it's completely out of whack.
    click my sig, go to links/tech and go to chip and there is a link to doing a TBA. It takes minutes.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Feb 10 2004
    2019 Mk7.5 Golf R His/Her
    Eastvale
    yah and did you properly ground yourself?
    Instagram: @daohaus_garage
    Apr 07 2004
    Should my fan come on during TBA?
    Apr 07 2004
    And when I put my key to ignition, should I click it once or twice into it?
    Feb 10 2004
    Eastvale
    click it all the way to the point of starting it and let it sit...you'll hear some high pitch sounds coming from the TB wait bout a good minute and then go...
    Apr 07 2004
    I do here it, but then my fan turns on and remains on
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Thats fine... if you turn off your climate control it will turn off and you can hear the TB whine. Just wait a few minutes then start the car and wait a few minutes again. Also, check to make sure you didn't put the chip in backwards.. DOH!!!
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    Apr 07 2004
    Yeah I checked, the chip is in the right place. I don't think it's the climate control fan, it's the fan up in front by the engine bay, it's going crazy when I turn it into ignition.
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    either way it won't take longer than 3 minutes, so just let it sit for that long and you should be fine. Let us know if the TBA works.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    Apr 07 2004
    Ok, I'll try that.
    Thanks a lot!
    Veteran Member Four Rings DLSJ5's Avatar
    Feb 12 2004
    2005 M3 ZCP
    LA, CA
    If your fan comes on while you are transferring a file to your ECU, it can/will freeze up. You should always unplug the fan. That's what did it. Only the Dealer can fix it. Sorry about that.
    Apr 07 2004
    Even more bad news, it still doesn't work. I think I may have fired my chip, but hopegully not my whole ECU.
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Almost sounds like what happened to me b4...
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | JBOM 100 Cell downpipe | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Registered Member Two Rings
    Apr 01 2004
    CA
    It could be a few things
    The chip is in backwards
    the chip is blank
    A leg is bent on the chip
    the stand off on the circut board counld not be making contact
    The fans come on when the ECU can not detect a chip as a saftey feature
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Hows your connections? You know how the connectors to the ecu clamp in? YOu don't just put them on, you have to press the sides in to clamp it. Know what I mean? It's alongshot that someone doesn't do this right, but hey, you never know.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    Apr 07 2004
    Theres a "L" shape that connects my chip to the circuit board. I think I might have bent on of the legs on the chip when I was trying to connect the bracket that hold on the in place back into the board. Does this mean my chip is gone? Or does it mean my ECU is fried? Damn, I'm running into so much bad luck with my car. First my intake hose, and now this. Despite my bad luck, I appreciate all the help guys!
    Feb 24 2004
    Land of the smiles
    What did you end up doing?
    I ended up towing it to my local dealer....then my tuner was notified via me. Dealer said it couldnt communicate with the ecu. Local tuner grabbed the box and took it back. Told me "Chip was bad", gave me a new box with chip.
    Apr 07 2004
    So the chip screwed your ECU up? And you ended up having it replaced? Or was it just the chip that went bad?
    Feb 24 2004
    Land of the smiles
    Well the weird thing is that...i had the chip for over 4k miles then it just went kaput! They say the chip just went bad...basically sounds kinda vague and wouldnt give me more details..NEways new box new chip..
    Feb 25 2004
    Sounds just like what happened to me last week. Does it just crank and wont start up? What ever you do dont take it to the dealer because they wont warranty your chip. I found out the hard way and now I gotta buy a new ecu. call your tuner and talk to them. my ecu went bad. let me know if u need more help
    Apr 07 2004
    Yeah I keep cranking it and it wouldn't start. It happened after I tried to install my stock chip back into the ECU. I think it's the chip and not the ECU, at least I hope not. So you ended up getting a brand new ECU? What happened?
    Apr 07 2004
    the chip is blank
    So that means my ECU is still alive right?! *Crosses fingers*
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    This happened to me on my old car.. I accidently broke one of the pins on the giac board itself.. So no matter what chip you'd put in, it wouldnt work.
    Took about 5 min of soldering to fix it
    Apr 07 2004
    Too bad I live so damn far away from you.
