Results 1 to 30 of 30
    Established Member Two Rings SaulV's Avatar
    Jul 02 2004
    Audi S4 B8.5, Porsche Cayenne Techart Turbo S 957, BMW M5 e39, Porsche Macan S 95B
    Oklahoma City, OK
    oil filters question!!
    Hello, im new to the board, new to my S4 and certainly new to piston engines...long history as a rotary owner..
    My question is where would i be able to get oil filters and stock maintenance supplies so i can do the oil change and routine maintenance myself.
    I called the dealer and just for an oil change they want $56.99 which is just stealing...anyways, is there any special tools or anything special i would need.
    Im doing my research as we speak but it would be nice to hear what other people are doing and where they get their parts from...online should be fine.
    thanks
    Saul V
    Feb 12 2004
    LA
    i get my filters from pure motorsports
    nothing out of the ordinary in terms of changing the oil for our cars. simply take off the belly pan (iirc 8 fake plastic screws) and under the driver's side front bumper is the filter and drain plug. i do change the crush filter during each oil change
    2000 S4
    $57 really isn't too bad for an oil chnage on this car, if they are using mobil 1, which almost even one uses, because it takes almost 7 quarts of M1 at $5 a quart and the OEM filter is like $9 or so, comes out to $44 just for the oil and filter. But it is a very very easy DIY job, once you take off the belly pan the oil plug and filter are right there.
    Jul 02 2004
    Oklahoma City, OK
    yeah, i just talked to a couple of people via AIM online and they guided me in the right direction. $14.37 for an oil filter and $.43 for a crush filter.... and where do they get $60 for an oil change??? thats ridiculous ...
    what other routine maintenance should i be considering ??? fuel filters??? water pump?? timing belt?
    Feb 12 2004
    LA
    well..i haven't reached the mileage to even think about timing belt/water pump. fuel filter change would be nice but i have not done it yet. have to make sure dealer does it b4 my warranty is up.
    2000 S4
    Your forgetting the most important and expensive part, the oil, Mobil 1 synthetic is $5 a quart and the S takes almost 7 quarts. $5 per quart x 7 quarts = $35 for oil + $14.37 for filter + $.43 for crush washer = $49.80 for the parts and oil alone.
    Veteran Member Four Rings aussie_s4's Avatar
    2001.5 S4
    That's about right. My Audi dealer charged me about $47 including filter ($16.58), 2 washers ($0.48) and $30.10 for labor. They use Castrol Syntec , so I supplied the Mobil 1 0W40 ($37), total $84
    My service advisor said they never change the S4's fuel filter under warranty. He said he's never seen an S4 have one changed. It's huge and is not easily accessible back near the tank. I've never gone looking for it, but a lifetime fuel filter doesn't sound like a good thing to me. Is this guy full of it?
    2001.5 S4 - Denver, CO
    - Valeo E-Codes - 710N DV's - Neuspeed 19mm rear sway - StopTech 332mm Front BBK
    - 19x8.5" B7 RS4's - Falken Azenis ST115 235/35/19 - Nokian Hakka RSI 225/45/17
    - RS4 Grille - AutoVation race pedals - XM Satellite Radio - GPS
    Go hard, brake late.
    Apr 12 2004
    2000 stgIII s4, 1997 jeep
    denver
    a fuel filter will never be a lifetime item, i dont care what anyone says. i changed my fuel filter and its a PITA, for sure. there is an article on AW if you want and the directions are on point. BUT after changing mine the bango fitting on the outlet line kept leaking fuel. not alot, but just enuf to piss me off. i put back in the stock washers, buffed them, buffed the new ones etc,but after a couple of hours they appeared to seat themselves and no mo leaks.
    buena suerte with this one.....
    Established Member Two Rings funkadelic's Avatar
    San Francisco, CA
    go to www.impexfap.com (aka VWParts.com) to buy the oil filter. part # 078-115-561-J
    they stock the audi/vw branded filter for $9.94/ea and the Mann version for $7.50/ea (Mann is the OEM for the Audi/VW filters but it's the same filter as far as I believe)
    just changed the oil & filter this morning as a matter of fact. like others have said, it's pretty straighforward.
    Jul 02 2004
    Oklahoma City, OK
    NOw here is the golden question!
    Ive seen a lot of you guys use Mobil 1, but my question is what is the biggest different about Mobil 1 and other 5w30 synthetic oil's????
    There is a few good brands out there, anybody else uses something else or what do you guys recommend?
    Feb 12 2004
    LA
    i'm running amsoil 0w30 and my car runs ~5-10 degrees cooler than with M1 0w40.
    San Francisco, CA
    i've been using M1 0W40 for the last 20k miles, and the previous 20k miles, Redline 5W30 (@ 71k miles now). I don't think you can go wrong with either (or Amsoil). I switched to M1 0W40 since it was cheaper & easier to get a hold of than Red Line.
    some posts on audiworld of my oil analysis results:
    http://forums.audiworld.com/s4/msgs/1557316.phtml
    http://forums.audiworld.com/s4/msgs/1053678.phtml
    Feb 12 2004
    LA
    i agree with funkadelic ... any of the big companies should be ok. M1 is very easy to get a hold of and is realtively cheap
    Jul 02 2004
    Oklahoma City, OK
    so what does all that mean???
    M1 0W40 is the best thing to use on S4's???
    should i just say screw Mobile 1 5w30??? what about in winter or hot....
    or what about other oils...like pennzoil, castrol..any of those any good??
    Diamond Bar, CA
    Mobil 1 0W40 should cover your summer and winter months.
    Jul 02 2004
    Oklahoma City, OK
    what about other brands??? like pennzoil that make 0W40 as well but isnt gonna take $40 to have an oil change.
    aybody use something else??
    Veteran Member Two Rings
    Nov 12 2004
    you want to run the 0w30 that the factory tecs recomend in the manual. Using an 5w... will not give you the cold weather start up protection as 0w... and runing a viscosity over 30 will put too thick of a film on the pistons and therefore cause more friction to occur yeilding more heat generated which can be bad for the engine longevity if you really get on the throttle in the summer months. Furthermore the reason why oil is changed so often (5k) isn't nessisarily for the engine internals but rather for the turbos that are easily damaged. A thicker oil that will not be able to run through the small passages within the turbos as a thinner one will. Only the factory designiers that built the motor will know the viscosity that is thin enough to flow easily, but thick enough for proper protection. They call for 0w30, that's what I run all year long.
    Registered Member Three Rings jkimspe's Avatar
    Nov 02 2004
    socal
    incase you guys didnt already know. pepboys has some calendars for $1 and inside there is a coupon for mobil 1 synthetic oil buy 3 get 3 free. also if you use the coupon and you get luckly like me (lady @ the register was a newbie) she charged me for 3 bottles of regular mobile oil. so 6qts for $5 not bad
    New - 02S4 homebrew stgIII(asp stgIII as of 5/17/08)
    Gone - 00S4 - 3-, lvl10 tip
    Wicked Motorsports :thumbup:
    AudiMods :thumbup:
    PureMS :thumbup:
    Eurotech Motors :thumbup:
    Veteran Member Four Rings imola_Jon's Avatar
    Dec 05 2004
    2k S4
    NoVa
    I wish I could change my own, but there is a claus in my aftermarket warranty that states I have to get my oil done by a commercial facility & maintain copies of my reciepts. I've already tried calling them to see if I could save my reciepts for my oil & do it myself, but they said they had too many false claims.
    I'm trying to find some kind of Mom & Pop place that can print me out a reciept saying they did it, if I promise to buy all my oil from them and/or throw them a 5 spot on the side. Anybody know a place like this in the Waldorf area??
    "Power without control, isn't."
    Veteran Member Four Rings cj-S4's Avatar
    Not enough space here
    Somewheretown, PA
    I use K&N oil filters. Advance Auto sells them. I used to use Mobile one filters. But switched to the K&N because they have a valve to keep oil from draining down through it as the car sits turned off. So then you have lots of oil up in the heads on start up.
    Dec 05 2004
    2k S4
    NoVa
    ^^^cool I'll have to try one out next time^^^
    Registered Member Two Rings
    Dec 21 2004
    2001 Nogaro S4 sedan
    Walnut Creek
    I run the castrol synthetic and I have had no problems. I just hit 91k and everything is a O.K. I use to change my own oil in my 300zx twin turbo until I watch 20/20. They had a story on "do it yourself chores that cost you more money than you save". Now I just take it to Jiffy-lube and it comes out to 52.99 which is almost what I would spend if I bought everything myself. Its actually cheaper than changing it myself when you factor in driving over to get the stuff, cool down time of your car, your own actual labor, then driving somewhere to dispose of the used oil. I rather spend the $10 bucks extra of money and have the 45 minutes extra of my life to do something else. To each there own what ever works for you is cool.
    Kmas, The go 2 guy!
    Registered Member Three Rings S-fear's Avatar
    Feb 12 2004
    S4, A4 1.8T, Subaru Legacy, supercharged Miata, Turbo Alfa (top 10 in GRM $2000+ challenge). UR Quat
    SE MI
    THat is great if you bring your own filter. I would not use one of their no name filters in my S4. Still, I usually get a few bucks off when I bring my own filter in.
    Jeder Bloedmann faehrt 'nen Porsche, Jeder Arsch 'nen Audi Sport
    Nur Geniesser fahren Fahrrad, Und sind immer schneller da
    2001.5 S4
    The K&N website doesn't have an oil filter for the B5 S4. Do you know the part# ?
    Registered Member Four Rings dramaticstatic's Avatar
    May 13 2004
    2000 S4
    Delaware
    Are you sure you don't mean 0w40? M1 0w40 has a long positive history with the S4. And I don't know where you get the 0w30 info from, I recently took my car to the dealership for an oil change because I didn't have time to do it myself and they said their oil choice for the S4 is M1 0w40 as well.
    Drowning is my third favorite way to die.
    Veteran Member Four Rings illusive45's Avatar
    Feb 13 2004
    2009 Audi R8 - Gated Manual V10 | Former: 2006 A6 Avant 3.2:: Techno|Premium|Cold Weather
    SF Bay
    Castol Syntec 0W30 european formula. Made in Germany. Good stuff. I can only find it at Autozone.
    2009 Audi R8 V10 Gated Manual Sepang Blue, Tuscan Brown interior, Carbon Sigma Sideblades, Carbon interior, Stasis tune, Stasis exhaust, JRZ RS Pro 3 coilovers, HRE P40SC 20" wheels
    Former:2006 Audi A6 Avant 3.2:: Atlas Grey|Black leather
    2000 Santorin Blue S4 6MT , 1999 Volcano Black A4 1.8TQM, 1992 Sentra SE-R
    Track Weapon:: 2004 BMW M3 6MT
    Veteran Member Three Rings One Nice Audi's Avatar
    Feb 19 2004
    Massachusetts
    Aussie, were you THAT bored?
    2001.5 S4
    Nah, I didn't go looking through the archives, I looked at an old bookmark. Oil change coming up!
    Veteran Member Four Rings ny02s4's Avatar
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    im running Mobil-1 5w30... from what i got out of some light research, 5w30 is a solid all season oil, atleast in the NY area. My next change i plan on using an OEM oil filter and not the Fram $hit i had put in for the last change.
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Registered Member Two Rings Rev. Po-Jay's Avatar
    Oct 27 2004
    PHX
    By Crush Filter, I assume you mean the washer on the drain plug?
    I live in AZ and this thread brings up a good question... 0W40 is not a M1 weight that I have ever seen. I have such a hard time sourcing Redline, AmsOil, or Royal Purple that I just use 10W40 M1. Anyone got a link for a good deal on any of the major synths?
    2000 Laser Red Ess Fo
