Originally posted by DVS18t
there is no evidence just many people who dont understand what the real use it. there is only so much air that can be recirculated into an intake you have to remember that everything is done very quickly and the DV is only as good as it is big. on a k03 or k04 this is not a necessity as these things flow shit for air. but when you start to creep into the bigger turbos with higher boost things change. some people dont realize what the DV is doing as they just dont know but they can cause surge. my current setup is causing the ever popular evo valve to surge. i have however watched a wideband with my own eyes and seen that the A/F across the revs does not change as the map adjusts when the system returns to closed loop. when i get a chance to take recorded logs i will as no one has ever produced logs to say otherwise with the hybrid valve. i personally ran the valve on my car for 1 1/2 years and felt that turbo response was better than with my evo (which was put in to pass smog and will come back out.)
The A/F is dynamic throught the band is it not? You wold have to do a plot graph of the A/F throughout and do a side by side comparison. You are also saying you haven't done this yet, so basiscally we still don't have solid proof. I'm basing my opinion on BOV from the fact that this guy had problems:
http://forums.audiworld.com/a4gen2/msgs/417318.phtml
and that it's a closed turbo system. The air is metered then it is gone... thats running rich. Remember we are talking about KO3s and KO4s here. Thats what Yeagy has.
I'm really interested in your results, but then again it sounds like you have a totally different setup then Yeagy or I or the majority of the people here on AZ.
What kind of boost are you producing? IMHO the EVO is surging because it can't handle that amount of boost. How much boost can the BOV in question hold?
