Please note that the BOTTOM of the valve should be placed into the pressurized IC hose (the side opposite of the Vac line fitting) and not the other way around.
The pistion in most BPV's moves vertically (Red arrows) so when the valve does its thing, the air pushes the valve up and lets the air go out via the outlet on the side of the bpv (purple arrow) which in turn is rerouted back into the intake track..
Hope this helps out with some of the confusion
