Results 1 to 8 of 8
    Veteran Member Four Rings needforspd's Avatar
    Mar 05 2004
    Deceased 01.5 A4 1.8tm
    Sylmar Hills
    Question Is the S4 wheel liner a direct fit for A4s?
    My brother had one in his garage I found when I helped him move. He had it and was going to mod it to fit his B5 Passat but decided not to so I took it. Forgot to get the part number off of it to make sure its a S4 liner. But as the title states, if it is indeed a S4 liner will it fit my A4 with no trimming etc ?
    Thanks
    Do you have a need for speed? Then drive it like you stole it!
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    Well if you have it,why not just try to put it on?, I'm sure you would be able to tell in seconds if you are going to have to trim it to fit.
    789whp
    Active Member Four Rings
    It should fit in just fine.
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    yup I have them on my A4.
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Junior Member Two Rings Spam-N-Rice ETR's Avatar
    2000 Audi A4 1.8T
    San Diego
    It's a 99.8% perfect fit...
    2000 Audi A4 1.8TQM and some mods....
    Veteran Member Three Rings G-low's Avatar
    Feb 13 2004
    Ct
    why would you want to replace your liners with the s4 one? i remember reading something about it but cant remember the difference between the two
    97 1.8tqm T3T4
    Account Terminated Four Rings MR VTEC's Avatar
    98.5 Audi 1.8TQM
    Brooklyn
    it has holes to let that oh so important minimal air flow through to cool the intercooler
    Veteran Member Four Rings Chard's Avatar
    If you're anal (like James R. from AW), you can trim it and merge it into your stock one to make it a perfect fit, but it's not by any means necessary. It just hangs over a little tiny bit on the rear of it.
