Results 1 to 24 of 24
Thread: HID Ecode pics
    Registered Member Three Rings VtAudi's Avatar
    Feb 12 2004
    00' A4 2.8
    Burlington, Vt
    HID Ecode pics
    Finally got them in, Valeo ecodes w/ ProtocoID's Valeo plug and play HID kit(Thanks) Still have to wire up the City lights, (Still looking for a thread), and get adapter at dealer tommorow for blinkers. See FS section for my old one piece FS.
    Veteran Member Four Rings Chard's Avatar
    looks good!
    Veteran Member Four Rings A4 in SC's Avatar
    Feb 16 2004
    '84 911 Carrera GP White, Burgundy cloth
    Simpsonville, SC
    What high beam bulbs are you running? From the pics, they look like they are a very good match for the HIDs. Then again, the pics may be deceiving and the highs may not be on at all. Might just be a reflection of how bright the HIDs are...
    Mike
    Account Terminated Four Rings MR VTEC's Avatar
    98.5 Audi 1.8TQM
    Brooklyn
    holla at yo boy with those 1 pieces!
    looks clean!
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    did you not put the turn bulbs back in the housing? because I noticed that they are not on? or did you cut the wire and plan on using that for the city lights?
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    98.5 Audi 1.8TQM
    Brooklyn
    true
    Veteran Member Four Rings Jon_Rhea's Avatar
    2001 S4 6 spd MT
    Manchester, TN
    looks good!!
    2001 Nogaro Blue S4
    Feb 12 2004
    00' A4 2.8
    Burlington, Vt
    The parking lights are just not on, I have to go pick up some adaptors today, hopefully the dealer will have them. I still need to figure out which prong to hook the city lights too, I'm thinking I'll just have them run w/ the parking lights.
    High beams arent on, just a reflection.
    Dodge RAM 1500
    Pittsburgh Area
    hows that work? you have the headlights on but no parking lights? WTF am I missing something here???? or you just never put them back in to the housing because it wouldn't fit because the holes don't line up right? just so you know the us spec turn holder will fit in the ecode housing. it just takes a little time and presuasion.
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    VT, did you see my response to your other post? it'll explain the problem you're having.
    Blacka4, the parking lights are not hooked up in those pictures. I'm currently running my ecodes without parking lights. I bought the wrong connector to wire my city lights, so right now mine basically look just like the pictures VT posted. But I have working blinkers :-P
    Feb 12 2004
    00' A4 2.8
    Burlington, Vt
    No but I'll have to check it out, I'm on mywaytothedealer now to get the 2 plug connector for my blinkers, still need to find how to wire city lights to work w/ parking lights.
    Washington DC
    Do you want them to work with the parking lights, or instead of the parking lights? All you have to do is instead of clipping the thin wire that keeps the parking lights on, just tap the city light wire into it. Both your city lights and your parking lights will come on together. I'm not sure if you'll be able to do this with the 2 prong harness though as it does not have parking lights.
    Feb 16 2004
    Simpsonville, SC
    Oh well. What bulbs are you going to use? Factory? Mine are way too yellow compared to my HIDs. Of course, the fogs are too. Anyone know of a good matching bulb? Of course, please post pics too.
    Mike
    Feb 12 2004
    00' A4 2.8
    Burlington, Vt
    Mike
    I got mine from SPP, H7 70w, have the blue coat on bulb. I've used the Yellow 75 w too, pretty diff, but really yellow.
    Dodge RAM 1500
    Pittsburgh Area
    i don't think the dealer will sell you the connector because we (you can thank DOT later) have to have the parking lights. IF you should heppen to get such a connecter post up some pictures I would love to see what you are talking about...maybe we are talking abotu 2 different things
    Feb 12 2004
    00' A4 2.8
    Burlington, Vt
    Finally got it all done, wasnt that bad, used my original blinker, just shaved off one tab. Wiring city lights wasnt bad at all, I can do a write up if anyone needs, I didnt have much luck finding one. I wired them into my parking lights, will post more pics tonight after I get some darkness ; )
    Veteran Member Four Rings awahl63's Avatar
    Jul 25 2004
    Phoenix
    Vewy Bright
    Feb 16 2004
    Simpsonville, SC
    Now all you need to do is disable your parking light, and you'll have NO AMBER unless you're turning left or right... You just need to find the right wire to cut. Not hard to do at all. Just use a multi-meter to check voltage in the socket. Very easy. Who needs amber parking lights anyway, especially w/ you have city lights...
    Dodge RAM 1500
    Pittsburgh Area
    yea where fif you get the little medal clip[ to put into the headlight harness?? i went to the dealer and they said it would take them forever to get me the damn thing..I wanted to nkow if you had a part number or something
    I don't have a voltmeter. Anyone know which wire it is? The way I want to run mine are:
    City lights on instead of parking lights
    Parking lights on only when signaling
    This is how they are setup in Europe, right? TIA.
    Washington DC
    the wire you want to clip and run to your main healight harness for the city lights is the skinniest one on the corner lamp harness.
    O, okay. Thanks. I'll give it a try later on tonight.
    Feb 12 2004
    00' A4 2.8
    Burlington, Vt
    I just use one of those fuse testers, screwdriver w/ metal point, and a wire/ground coming off the end, radioshack for like less than $5, thats how I found which wire to splice into, I think I'm going to leave the amber in there, to double check when you cut the wire, it should be number one, there are small numbers on the actual socket.
    Mar 03 2004
    does anyone now how to turn the city lights and ambers off when you flip on the HIDs??
    on Canadian A4s our fogs function as DRLs...
    so i was thinking... maybe i could splice the city lights to the fog wires?? so that during the day i have city lights+fogs as DRLs and when i turn on the HIDs i get just the HIDs and no city lights? does that sound like a reasonable idea? I just have to figure out where the wires to the fogs are.. anyone have pictures?
