Results 1 to 36 of 36
    Veteran Member Four Rings DeanUW's Avatar
    Feb 22 2007
    Lots of stock parts :-)
    Auburn, WA
    DIY: Fixing the terrible B6 glove box
    Alright, I know many of us have glove boxes w/ breaking or broken hinges. Besides this my glove box was very stiff, hard to open and even harder to close. After some looking over and taking apart I decided to do a write up on how to smooth out the mechanism connected to the glove box door.
    First open the passenger door to reveal a cover which needs to be removed.
    When removed you will see the glove box door mechanism. Pull the electronic plug off the mechanism, this tells the glove box light when to turn on and turn off. Next use a pair of pliers to pull the plastic dowel out from its position.
    Now that the mechanism is free, rotate it vertically, the pull straight out.
    Now that its removed from the car remember and take note to how it looks (position of electrical plug).
    Disassemble this mechanism by rotating the electrical plug 90 degrees. It takes a little effort as it needs to hop over the two taps shown in the picture.
    Now pull the electrical part from the body of the mechanism.
    Slide the white piece w/ the rubber attached up, notice how the picture shows a notch for it to slide up and out.
    Now my reasoning for the glove box sticking is the rubber stretching out and loosening up over time, expanding making it harder to slide smoothly in the mechanisms tubular body.
    So what I did was make this rubber piece a tiny but smaller. (You could go buy a new rubber piece but why when this mod can be free) First I cut a tiny bit off the lip.
    Next lay it flat and cut around the circumference. Only remove a small SMALL portion.
    And you are done! Put back together in reverse order. You may want to check the hinge of the glove box too as I did not notice but a small crack in the right hinge was starting so I patched it up with some JB Weld before it snapped completely.
    Hope this helps some people out good luck
    Deanophotography.com | The A4 (Updated 3/1/10)
    REVO Tuned GTRS Eliminator
    Caractere | Evolution Racewerks | Southbend | STĂSIS | ATP | QTP | Magnaflow | Samco | OEM | VMR | Defi | TurboXS Dtec w/ Gameboy
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    Re: DIY: Fixing the terrible B6 glove box
    Thanks for the writeup...maybe I'll finally get around to fixing mine
    Feb 22 2007
    Auburn, WA
    Haha, yeah I am constantly opening mine to access my Defi Controller and Dtec Gameboy and I finally got so annoyed w/ it I decided to fix it! Good luck.
    Active Member Two Rings crizo's Avatar
    Aug 19 2008
    2004 A4 Ultrasport
    wilsonville, oregon
    Great writeup! This is definitely a must-do if your hinge isn't cracked yet..because it will be with this POS door damper. My only piece of advice is follow the advice of the poster..and be careful how much you trim around the edge of the black rubber piece. I cut too much and the dampening effect was almost gone. I had to wrap some tape around the rubber damper to give it some friction against the inside of the tube.
    Senior Member Three Rings ThreePointOhh's Avatar
    Dec 24 2007
    |2004 A4 3.0Q 6SPD MT|
    New York, NY
    Quote Originally Posted by crizo View Post
    Great writeup! This is definitely a must-do if your hinge isn't cracked yet..because it will be with this POS door damper. My only piece of advice is follow the advice of the poster..and be careful how much you trim around the edge of the black rubber piece. I cut too much and the dampening effect was almost gone. I had to wrap some tape around the rubber damner to give it some friction against the inside of the tube.
    same here, i cut the damper too much after fixing my broken box wtih the brackets from pcyc. but what the hell ever im just glad that it's not broken anymore.
    ** I'm Gonna Drive it Till the Rings Fall OFF!! **
    Feb 22 2007
    Auburn, WA
    Thanks, yeah I actually hated that damper, I mean when I open my glove box I dont open it and slam it down you know, normally you open it and place it in the open position. But yeah like you said, cut off a very small amount of the black rubber, basically as little as you can.
    Senior Member Three Rings edge19lw's Avatar
    Mar 24 2007
    03' a4 3.0
    Queens, NYC
    mine already broke =( and i always opened it slowly
    2003 A4 3.0 | Trunk Lip Spoiler | CC mod | Bilstein/H&R | RS4 Rear Sway Bar | K&N drop in filter | 23% Tint | Magnaflow 14851's & Magnaflow 10415's
    -Thomas
    Senior Member Three Rings covertS4driver's Avatar
    Jun 11 2008
    2005 Audi S4, 2000 Triumph 955
    Dutchess County, NY
    Nice write up! Thanks!
    2005 Moro/Silver 6MT; Hardwired V1, Escort 9500ci, Hardwired Dash Express, Hardwired Garmin 265wt, Uniden BCT15, RS Pro95 Scanner, Uniden CB, 2X Antennex Antennas
    Blackberry 9700 running Trapster
    More "covert" mods on the way.. Run Silent, Run Swift...
    Aug 26 2005
    An alternative method to trim the rubber piece OD, is to use some sandpaper to abrade the rubber away. This is a quick and controllable means of changing the size of the OD.
    An Audi TSB instructs to lube the damper with silicon spray also. If silicon spray is applied, the resize may not be needed. However, the resize is functional long term, whereas the silicon spray lube may not be.
    Aug 19 2008
    2004 A4 Ultrasport
    wilsonville, oregon
    ^^ Great ideas. What is an "OD"?
    Feb 22 2007
    Auburn, WA
    Outside Diameter
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    How can I fix a broken hinge?
    Dec 24 2007
    New York, NY
    Quote Originally Posted by Tony@Autobahn View Post
    http://www.audizine.com/forum/showthread.php?t=238177
    i installed the bracket on mine. helps alot
    Aug 11 2007
    California
    You are the man. Thanks!
    Veteran Member Four Rings Sablea4's Avatar
    2010 VW CC 2.0t MT6 Shadow Blue
    Charlotte, NC
    that last pic is where mine is breaking. how is the jb weld holding up?
    USP CLUB MEMBER #6
    Feb 22 2007
    Auburn, WA
    Quote Originally Posted by Sablea4 View Post
    Holding up on my car
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    hey Guys i am working on a DIY if i every get time but your gonna need a good many tools, iam trying to make them with just hand tools so most can make them it just takes forever...
    Registered Member One Ring Ardenkent's Avatar
    Apr 08 2009
    '04 S4
    Ohio
    Thanks for the help. I used Loc Tite Plastix Bonder, a two part for plastic.
    I followed all the instructions, scuffing, cleaning and "clamping".
    I placed some over the fractured exterior as in the photo.
    The real strength though came by injecting the glue into the space between the two layers of the door around the fracture especially into the space at the back of the hinge.
    Trimming the damper's piston ring is too much work and can't be undone. Instead drill a very small hole into the end of the cylinder. If the door falls too fast, make the hole smaller by covering it part of it with glue. Or you can lube the ring and cylinder interior with silicone spray lube.
    Apr 08 2009
    '04 S4
    Ohio
    And when taking the damper apart, don't rotate the end, a small part of the plug breaks. Use a small screwdriver to lift the open end of the plug slightly off the cylinder, like any other electrical connector, then use a narrow putty knife to pry the end off.
    04 Audi A4 USP,05 S4 Cabriolet
    Memphis, TN
    i opened mine the other day to find out the hinge was broken... next on my list i guess
    2004 A4 UltraSport
    APR 2+, Racetech FMIC, APR TIP, Southbend FE SS, Stasis 4:1 Center Diff, Neuspeed Exhaust/test pipe, Podi/VEI boost gauge, Stasis StreetSports, JHM Solid Short Shifter -1" Stern ACAs
    2005 S4 Sprint Blue Cabriolet
    Stock but 1 of 150
    Jun 11 2009
    2002 Audi A4 1.8T Quattro
    Pacific Northwest
    PCYC, still selling those brackets? Love to buy one, mine has been broken for a couple of months now.
    Veteran Member Four Rings Ruska's Avatar
    2005 A4 1.8TQ 6spd Stage III, 2011 Kawi ZX6-R
    Milton
    I did this last summer after being fed up with the way the door opened and closed and it is a must do IMO. The glovebox was such PITA to use before but now it works great. Good job on the write up!
    Nov 24 2009
    uk
    Thankyou this was a great help fixing my B7 glove box - I filed the washer after trimming then used a bit of grease on washer as well just to be sure.
    Audi A4 B7 1.9 TDi
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Hmm, anybody just try spraying into the mechanism with some the WD-40?
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Veteran Member Four Rings Lusticles's Avatar
    Nov 04 2009
    a lemon
    my glovebox broke off one of the hinges. such a pain to use, so anything that would normally be in the glovebox really i just sit on the seat
    Established Member Two Rings Sigster's Avatar
    Oct 04 2009
    California
    Quote Originally Posted by manhertm View Post
    My hinges weren't broken but the stopper was sticky. WD-40 didn't work for mine. I didn't try to fix it either. I just ordered a new one from Audi and it works like a champ now. Took about 5 mins to change and cost about 34 bucks list.
    Established Member Two Rings JBOOST's Avatar
    May 02 2009
    QUEENS NEWYORK
    Oct 19 2009
    2004 Audi S4, 2004 Lexus RX330
    can someone please fix the pics to this DIY? i only see red X's.
    thanks!
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    Pasadena, CA
    Get the bracket from Fritz/PCYC. It fit almost perfectly and I just had to Dremel out a little bit of extra space to compensate for it. It took longer to remove the damn box than it did to install his bracket.
    As for the hinge / slider piece, depending on how difficult yours is to move back n forth, I would suggest starting with some white lithium grease first and if that doesn't work try trimming out the rubber piece on the inside of it. (you'll know what this is once you get it taken apart.) Just mind the brass colored metal tings. They're kinda overly bendable.
    DIY
    http://audizine.com/forum/showthread...ve-Box-Bracket
    Order
    http://www.audizine.com/forum/showth...ve-Box-Bracket
    And big thanks again to Fritz for taking the time to make and send these little guys out. Finally have a working glove box again.
    Quote Originally Posted by v8s4 View Post
    thanks!
    Thomas
    | Chronicles | Threads | IG
    // A U B A
    Veteran Member Four Rings Peacob's Avatar
    Jul 08 2009
    Bicycles
    Detroit MI
    any way we can get this pictures working again? just got mine and really want to get this done
    -Brian
    B6 A4 OEM+
    DD: e90 325i
    Active Member Two Rings gTron23's Avatar
    Aug 27 2010
    2008 CBR 1000RR
    Syracuse, NY
    good write up. thanks for the help!
    Jan 14 2011
    Newark DE
    Just did the repair to my A4. Instructions were excellent. Thanks!
    Established Member Two Rings SourCream's Avatar
    Dec 08 2012
    B6 A4 Quattro 5spd Sline, previous and now bro's '04 GLI blue lagoon
    Montreal
    Pics are unavailable tho.. :(
    '02 A4 1.8T Quattro || Full S4 body conversion || B7 steering || Unitronic Stage 2 || 3" DP with Magnaflow catback || TT225 injectors || 18" OEM multispoke wheels || StaSiS coilovers
    Sep 10 2011
    Oregon
    Picture FAIL.
    Actually, aside from the hinge, you know what the worst thing about the glovebox is?
    That stupid little shelf on the upper left. It's the right size for sunglasses, but even with the door closed, they fall to the bottom shelf.
    ~Calvin
    2004 Audi A4 1.8T /// 6-Speed /// quattro /// Moro Blue Pearl
    || motoza tuned gt2871r elim || b7 thermal r&d exhaust || ns sport w/ b5 seats || v718 sunken treasure
    Apr 10 2012
    2003 Audi A4 1.8T Quattro
    Fort Worth,TX
    you guys should use something like the public folder feature on dropbox for the pictures. thats what i do, works great.
    Veteran Member Three Rings Lornnn's Avatar
    May 01 2011
    Wisconsin
    Quote Originally Posted by CrazyCal View Post
    Picture FAIL.
    Original post was from 2007.
    The upper left shelf is for the owners manual.
