Results 1 to 34 of 34
Thread: Intercooler
    Registered Member Three Rings
    Jul 13 2004
    san diego
    Intercooler
    i kno this has come up soo many times, and ill admit ive posted about it before...but i just want people who know there facts to answer on this one because to many people will belive the first thing sumone says and then go out and give that poor/good adive to others..
    but my main problem is i live in sd and its freakin hot here i live at the beach so that doesnt help either....so im looking at intercoolers and i see all types that are well over a grand, then i find greddy...a respectable company who puts out quality products...and there intercooler kit is aabout have as much as the others...so i asked around and people gave me half a$$ answers like its to big and it wont help..my main question is has anyone used it or does anyone had proof it will lower my boost pressure...because i knoiw it makes sence it will becvause its size an the amount of the intercooler that would remain hidddin under the bumper but i need more than that
    thanks
    and i hope this made sence
    one point eight tee
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    the greddy is a great unit, i love the way it looks compared to many other reputable manufacturers out there. however if your only running a k04 the pressure drop is too much, that intercooler is a great unit for people running larger turbos. im in the market now and dont want to spend money on an intercooler but if you plan on keeping the k04 and not going larger then i would suggest getting a smaller unit that would be more efficient like a abt one from ams. wich is what i hope to get, or a evo motorsport one. those tend to be the best units for k03 and k04 cars and require a minimum amount of cutting on rs4 and s4 bumpers. if you have the stock a4 bumper invest in a dremel as it will be your best friend. i found all this out from research and talking to steven at AMS. Steven seemed very knowledgeable about what he was saying as he told me as well as dvs that the greddy unit would be too big, Steven suggest the evo motorsport one or the one they make (ABT). he also told me he would sell me the ABT one for a grand and it normally retails for 1599 or 1499 i forget wich. so i think i will save and get the abt. hope this helps.
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    Intercoolers as large as the Greddy really were not made for the stock K03 or K04 as the internal volume of the IC will create a pressure loss as the overall internal volume needed to fill the intercooler channels and push them through to get to the other side and into intake manifold.
    usually you want an intercooler that will give you at least about 1psi of pressure loss which would be beneficial to the smaller turbos. this is made up by providing a cooler intake charge.
    blah blah blah
    2017 Toyota 86
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    blah blah blah
    thank you for repeating nismosx.
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    So what is a good FMIC for a stock KO3?
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Mar 02 2004
    Orange County
    SPP is good for a k03 or k04.... dont think they are producing them right now though... EVO and ABT are very good though they are pricey....
    Veteran Member Four Rings Hassmeister's Avatar
    Feb 12 2004
    2015 GOLF R APR Stage 2
    I placed my SPP Traditional FMIC on with the K03 and both the .08 bar and 1.0 bar and now my K04 chip and it runs just fine! What a diff with "JUST" the K03 and .08 bar - WOW!
    Click here for AMSOIL - Superior Protection!
    Wholesale pricing and delivery to your door - ask me how!
    Registered Member Three Rings sighpost's Avatar
    Jul 16 2004
    1999 Audi A4
    Jacksonville N.C.
    Bigger better ?
    I don't have any experience with ICs but this is what one website that sells turbo and turbo accessories says about intercooler theory...
    This is one area where the American addage, "the bigger the better", applies. When selecting an intercooler, choose (or have made) the largest intercooler you can fit into the space you have under your hood. Here's why:
    Efficiency and Size. Typically, a larger intercooler has more surface area over which the heat transfer can occur. The greater the surface area (given the same transfer medium), the greater the amount of heat transfered. As usual, better quality can make up for a smaller size. Having a better transfer medium, such as aluminum, will increase the drop in temperature. Also, surface area can increase without using a large intercooler, by using more and smaller fins. More fins, though, means less air which can fit between them. Many people report excellent results using intercoolers fabricated by Spearco. They are also capable of making custom intercoolers.
    Pressure Drop and Size. Smaller intercoolers can be a flow restriction. This flow restriction can increase the pressure drop across the intercooler. This causes the turbo to compress the air to a higher pressure in order to maintain the same pressure at the intake manifold (after the intercooler pressure drop). Greater compression, even if it's done at the same compressor efficiency, will result in higher temperatures leaving the turbocharger. Ultimately, this results in a warmer air temperature and lower air density at the intake manifold.:
    Taken from turbo calculator
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Thanks. That's what I was planning on. Eric said he might have another batch if there is enough interest. Otherwise I think something new is in the works.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    Mar 02 2004
    Orange County
    Re: Bigger better ?
    i am not even gonna go over the whole thing but please dont take anything there to heart bigger is not always bigger in fact it rarely is with turbo cars.... turbos can be too big for an application, injectors can be too big.... intercoolers can be too big... you have to size things comparatively.... if your turbo can only flow 300 cfms then why would you have an intercooler that can flow 750.... that would make it difficult for the turbo to create any real charge pressure.
    Mar 02 2004
    Orange County
    Re: Bigger better ?
    though i will say that this is very much the issue with k03 running more boost and one of the reasons that heat soak is such an issue with these setups.
    Jul 16 2004
    1999 Audi A4
    Jacksonville N.C.
    Re: Re: Bigger better ?
    i.... if your turbo can only flow 300 cfms then why would you have an intercooler that can flow 750.... that would make it difficult for the turbo to create any real charge pressure.
    I guess what they are promoting is the idea that the drop in temps makes up for the drop in pressure. Ultimatley we care about air volume not pressure. Is it just not possible for an IC to drop pressure but make up for it with a drop in temps?
    Jul 13 2004
    san diego
    there website still has them...are u shure there not sellin em anymore..because that is probably genna be my next choice
    and also if they still do sell em does it come will all hardware?
    (piping,brackets, conecters..blah blah blah)
    one point eight tee
    Jul 13 2004
    san diego
    blah i was getting excited because it looked alright with the stock a4 front bumper
    one point eight tee
    Jul 13 2004
    san diego
    welllllllllll good news...i just called them up and they said there still sellin em but they only get like 3-5 in at a time so if u want one u gota call ahead and reserve one...the guy was way chill and says for the stock a4 front bumper there is little trimming involved and he has full instructions on the install and trimming so i will definitly be reserving one them and probly gettin a rs4 front off him while im at it
    one point eight tee
    Jul 13 2004
    san diego
    i guess that was only good news for me
    one point eight tee
    Registered Member Two Rings
    Feb 13 2004
    SD
    pressure drop can be caused by too much volume, crappy core flow capability, bad end tank design, bad pipe layout/design. Just make sure you get a FMIC that is designed for the appropriate application and that it's designed with flow capacity/speed in mind.
    Jul 13 2004
    san diego
    yeah im hoping someone who has oen will see this post and give feedbakc but if not i guess ill be the lab rat an give it a go
    but hey where in sd do you live...im over in mission beach
    one point eight tee
    Feb 13 2004
    SD
    Mira mesa, we have weekly meets on tuesdays usually. Check us out for some regional info, www.socaleuro.com
    Jul 13 2004
    san diego
    whatttt man i went to mira measa high
    crazyyy i need to get wit the program here
    one point eight tee
    Mar 02 2004
    Orange County
    for what the SPP? many people have them you wouldnt be the lab rat by any means... they are priced just right for the build quality imo.... not trying to start a war here either those who have them i have just seen many build flaws in them. the flow is sufficient for a small triple K turbo though.
    Jul 13 2004
    san diego
    thatsss meee
    one point eight tee
    May 10 2004
    Rhode Island
    I am running a greedy with neuspeed sko4 and did not notice much pressure drop at all. Maybe .5 pound. Still a bitch to install need a RS4 or S4 bumper and mount it right to the bumper support. RS4 bumper still will need trimming but it fills the front air duct perfect.
    Mar 02 2004
    Orange County
    Sk04 flows alot more than a k04 iirc.... did you finally get that RS4 bumper on there? good to hear you like the greddy i know i am happy with mine.
    Registered Member Three Rings BoostinA4's Avatar
    Jul 12 2004
    the stock a4 bumper fits if you have a recipicating saw and alot of time, im running the greddy with a kkk k04 and its i like it alot
    [/img]http://memimage.cardomain.com/member_images/1/web/589000-589999/589435_1_full.jpg[/img]
    http://www.audizine.com/gallery/data...765sig-med.jpg
    http://www.cardomain.com/memberpage/589435/4
    -----FOR SALE HERE!!!-------
    ATP manifold
    T28 wastegate
    440cc greentops
    RS4 bumper
    (2) Sparco 3pt harnesses
    HKS ssq BOV w/adapter
    (2) 4 bar FPRs
    Jul 12 2004
    dont know how to post pics can anybody tell me???
    ATP manifold
    T28 wastegate
    440cc greentops
    RS4 bumper
    (2) 4 bar FPRs
    Veteran Member Three Rings voodooA4's Avatar
    take out the / from the first IMG tag
    98.5 Cactus Green A4 Quattro, APR Chipped
    114K Miles
    Open Source ECU: http://groups.yahoo.com/group/openecu/
    OpenDiag Group: http://groups.yahoo.com/group/opendiag/
    Mar 02 2004
    Orange County
    lol where the **** have you been? long time no speak...
    Mar 02 2004
    Orange County
    YOUR WELCOME
    Mar 02 2004
    Orange County
    Re: Re: Re: Bigger better ?
    guess i missed this before... there is very very fine line between the two.... the main things you want to focus on when creating a functional power producing turbo system (on the intake side at least) is creating the coolest highest velocity charge pressure that you can.... what that little blurb from that site is assuming (what they dont tell you) is that you want to go as big as you can because in most cases there is very little space to make an intercooler in the front of the car. but many people take blurbs like that one that lack info to heart and cut thing out to make larger intercoolers work this is not necessarily the smart thing to do as if you turbo cant make a strong charge your requested boost and your actual boost will vary this is pressure drop. you can use a boost controller to fix this but then what happens is (assuming you have 2 psi pressure drop) you have to boost 16 psi to make 14.... that is essentially called overboosting (normally at higher boost pressures).
    Veteran Member Four Rings littlewhite's Avatar
    PNW Rainy States
    I've had many good comments on the SPP FMIC. Greddy one i heard has some pressure loss, but u can just up your boost with a MBC
    Littlewhite
    May 10 2004
    Rhode Island
    [IMG] [/IMG]
    Still not happy with the grills. Had to remove the larger LLTEK mesh when I trimmed the back of the bumper. The stuff I used is a little to fine mesh for me. I am looking for some large diamond mesh made of plastic to attach in front of the fine mesh. Might go with stock RS4 grill Another project on another day. But it works great!
    Jul 12 2004
    thanks dvs
    ATP manifold
    T28 wastegate
    440cc greentops
    RS4 bumper
    (2) 4 bar FPRs
    Mar 02 2004
    Orange County
    thanks dvs
