Results 1 to 35 of 35
    Veteran Member Four Rings Eddie Man's Avatar
    Nov 05 2004
    Detroit/Clarkston
    Check Out my New Servotronic Mod (PowerAssist Disable Mod)...
    Well first of all, just a recap of my earlier mod...
    Quote Originally Posted by Eddie Man View Post
    I know when I had my A6/2.7t, removing the Servotronic Relay (for me, I retrofitted an In-Line Dash Mounted Switch) disabled the powersteering assist or boost at all times. For the A6, it proved to be invaluable for increased road feel and drivability for speeds above 15mph...
    As for powersteering assist while parking, one just has to flip the retrofitted switch to re-activate the Servotronic.
    I just completed the above mod on my S4...
    I'm sure this applies to both B6 & B7 models.
    I used a Tech Article in the A6 Electronics Section from AW >>> Modifying the Servtronic Steering Boost Relay to Tighten Steering
    And also this write-up in the MJB Motorsport Site as resources >>> Servotronic
    Mod Time = 30 min.
    Tools Required:
    1. Wire Stripper
    2. Socket Set
    3. Drill with 3/4" spade bit
    Parts Required:
    1. (2) Wire Nuts (smallest guage available); Soldering would be best though in lieu of nuts.
    2. Electrical Tape
    3. On/Off Rocker Switch (Radio Shack #275-693)
    4. 2 wire cord (light guage, my guess is that 20 or 22 ga is fine).
    5. (2) Spade Connectors
    Well anyways, here's what I did:
    1. Locate Servotronic Relay adjacent to the Fuse Area
    2. Locate 3 screws that secure the driver's side dash panel. 2 at footwell and 1 inside fuse box area. Remove dash panel. Sorry no pics :(
    3. Locate 2 screws that secure fuse box to fuse box bracket. Remove fuse box and push aside for clearance to relay boards.
    4. Locate relay boards & 2 mounting nuts.
    5. Pull Servotronic Relay Out, remove 2 mounting nuts & remove lower relay board and push aside to access Servotronic Relay Board.
    6. Remove Servotronic Relay Board and push aside to access the rear of the board.
    7. Pop-Out the Servotronic Relay Harness to aid working on wires.
    8. Locate BLACK wire behind harness.
    9. Snip Wires and wire nut the ends to a 2-wire cord & tape connections to prevent wire nuts coming loose. For this step, soldering is best but the space to work in is very tight, so this is the next best thing, IMO.
    10. Carefully re-assemble (#7, 6, 5, 4 & 3 above in that order).
    11. Locate Switch to your liking. I located my non-OEM Switch in an inconspicuous location (not to clash w/OEM Switches) in the Owner's Manual Slot Area. Drill hole in lower dash panel.
    12. Strip free-end of 2 wire cord and secure spade connectors. Connect spade connectors to mounted switch.
    13. Add some electrical tape to the connectors for problem free electrical current.
    14. Finished Servotronic Switch (on left). BTW, the switch on the right is my On/Off Switch for my Lidetek LE-30.
    15. Carefully re-assemble (#2 above).
    16. Done :)
    Observations:
    I test drove it this evening and all I got to say is WOW.
    A completely new driving experience w/no power assist. Pretty tight steering as it feels much better (at least for me) to the touch.
    Best of all, I can go back to stock in a flip of a switch. It's definetly needed when parking.
    Well I hope this helps whomever wants to give this Mod a whirl.
    2006 S4 Avant
    dolphin gray | 6speed | alcantara | premium | cold | bose | sirius | navigation | bluetooth | parktronic | ebony | carbon fiber
    >>> Got Mods?
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Re: Check Out my New Servotronic Mod (PowerAssist Disable Mod)...
    Nice write-up once again Eddie. Hey, what's the other switch for? I searched your mods but didn't see it?
    Just wondering...Steve
    Veteran Member Three Rings mercury26's Avatar
    1977 VW Scirocco, 2005 BMW 300i ZHP, 2007 RS4
    Westminster, Colorado
    Ejector seat and oil slick spray out the back. :)
    Cheers,
    Chuck
    2021 Audi RS 6 Avant
    2021 BMW M2 Competition
    2019 VW Golf Alltrack (wife's car)
    2007 Audi RS 4
    2005 BMW 330i ZHP
    1977 VW Scirocco (undergoing restoration)
    Nov 05 2004
    Detroit/Clarkston
    Quote Originally Posted by S4J View Post
    Thanks...
    It's for my Lidetek LE-30 (laser jammer).
    2006 S4 Avant
    >>> Got Mods?
    Veteran Member Three Rings scoobycarolan's Avatar
    Nov 02 2007
    Albany, NY
    Eddieman~ you rule.
    Scooby Carolan: Massive Audio
    2008 Ibis A4 2.0T
    Titanium | S-Line | Sport (20% Tint / Debadged)
    APR 93 octane / JHM SS / EVOms DV / Eurojet PCV
    Koni FSD / Eibach Pro-Kit / RS4 Sway
    **Join the Upstate NY Regional Group!**
    Veteran Member Three Rings UberDave's Avatar
    Mar 15 2008
    TX
    That's hard core, nice job.
    Veteran Member Three Rings Storm33's Avatar
    May 13 2008
    Cape Coral, FL
    Very cool! Wish I had the cojones to mess with stuff like this.
    2011 Q7 TDI Prestige S-Line, Orca Black / Black
    2012 Q7 TDI Premium Plus (Sold back to Audi), Mugello Blue / Limestone
    2010 C6.5 S6 Prestige (Guh-bye!), Phantom Black / Black; RS6 Grille
    2009 B8 S5 (R.I.P.), Silver / Black; Nav, Tech, ADS, B&O; MTM Catback, H&R OE, RS5 Grille
    2005 B6 S4 MT6 (Sold), Silver / Black, RS4 Sways
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    i did this mod on an allroad what difference it makes
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    I am a little confused on the black wire, just to clarify is that the only wire that is cut? & where is it wired to... Just the on off switch? Maybe I missed something thanks!!!!
    Knick
    EcoLuxuryDetail.com
    6-Speed, Neuspeed Chip, Heat Shield, 034 Intake, Euro Jet PCV, 3" Magnaflow, Test pipe, Sport Suspension, RS4 Sway, Snub mount, Apexi super ground, K&N, RS4 Pedals, Podi, Hawk HPS, Super Blue Fluid, Chrome Mirrors, Clear cornered, Laminx, Debadged, Ziza Led, Xexon Interior, Alcantara boot, Infinity 1000W 12", painted markers, VAG's 19" A8 12 Spoke, 10 & 15mm Spacers
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    I'm not too knowledgeable, so forgive the noob question:
    Does adaptive power steering allow for the steering to be very light at low speed, and unassisted at higher speeds? That is different than power steering is it not?
    Is there a way to disable adaptive power steering but keep power steering so when you are parking you don't have to strain yourself?
    I know the A4s have a similar mod, but they just pull a fuse I believe, but I could be wrong. Is this the same thing but with a switch?
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Nov 05 2004
    Detroit/Clarkston
    Quote Originally Posted by Cosworth View Post
    Knick
    Yes, just the black wire...
    The black wire, if disconnected will disable the Servotronic Function.
    So basically, the switch acts as the enable/disable function for the Servotronic.
    Hope that clears things up. :)
    Quote Originally Posted by JMG View Post
    Yes & Yes.
    Yes, this mod is basically that and as when you park and need to go back to normal mode, one just flips the switch.
    Yes. It's pretty tough to reinsert that module conveniently when you need it, hence the switch.
    2006 S4 Avant
    >>> Got Mods?
    Senior Member Two Rings wva s4's Avatar
    Jan 19 2008
    Charleston,WV
    I also did this mod to the old 2.7 A6 and loved it, but I have never noticed the S4 being as overboosted (for lack of a better word) at higher speeds like the A6. Maybe I will pull the relay to see how it feels? I remember my wife having trouble turning that boat in the driveway when I would forget to flip the switch. the switch is a must!!!
    Iroz downpipe/midpipe * Iroz Intercooler * Iroz Boost Tap * Iroz DSG Catch Can * Iroz Haldex Switch * Iroz turn down pipe * APR Inlet * IE Intake * Unitronic ECU/TCU Tuning * Innovate ECB-1 Gauge * WaveTrac Limited Slip Differential * KW V3's *Whiteline Swaybars * Vinny’s Custom Dog Bone Mount *Titan T-S5 Wheels
    Registered Member One Ring jmarch's Avatar
    Mar 10 2009
    SF Bay Area
    So does this mod completely disable the power steering or simply eliminate the additional assist provided at low speeds?
    TIA,
    Joe
    1995 Porsche 993 (OBD-1 VRAM conversion)
    2001 BMW 530i
    1988 BMW 325is
    2005 KTM 450EXC
    Nov 05 2004
    Detroit/Clarkston
    Quote Originally Posted by jmarch View Post
    TIA,
    Joe
    Just the additional assist at low speeds.
    2006 S4 Avant
    >>> Got Mods?
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    I like the switch idea
    Mar 10 2009
    SF Bay Area
    Thanks Eddie.
    2001 BMW 530i
    1988 BMW 325is
    2005 KTM 450EXC
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Badass Eddie, thanks. I hate the servotronic, but need it on 9 hour long drives. this is just what I needed. +1
    2021 Audi S4, P34 Intake
    Nov 05 2004
    Detroit/Clarkston
    Thanks and I'm happy to help.
    And you are right, the switch comes in handy at those times when you crave that tight steering feel!
    2006 S4 Avant
    >>> Got Mods?
    Apr 18 2008
    Jacksonville, FL
    is it ok for the ecu to switch this on & off while the engine is running?
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Dec 03 2008
    2018 SQ5
    I am currently trying to find a stock-looking button to do this mod, similar to this a3 button, but have had no luck!
    May 26 2009
    VA
    Quote Originally Posted by minameismud View Post
    I'm curious about this as well. Anyone have any long-term feedback from using the switch. This is the only thing that is holding me back from installing it this way. Thanks.
    Dec 03 2008
    2018 SQ5
    The OP has had this done for two years, with no problems thaT I can see. I'm sure he uses it everyday. He'll reply soon.
    Nov 05 2004
    Detroit/Clarkston
    I've been searching since 2003 (back when I still had my A4/3.0) and I too have had no luck.
    What I have found is an OEM momentary switch like the one I use for my Remote V1 Mute Switch
    The ones you've shown for the A3 are also momentary switches.
    I guess, one could use anyone of these momentary switches and w/a series of relays, could accomplish what one would want.
    But you know, simplicity is usually the safest bet.
    Quote Originally Posted by v_audi View Post
    Yep...
    jimrobbington is right.
    I've had mine installed in my '03 A4/3.0 w/o any problems and I've had it installed after a few months of ownership (9/07) w/o any problems whatsoever.
    2006 S4 Avant
    >>> Got Mods?
    Apr 18 2008
    Jacksonville, FL
    completed this mod this weekend, and it works great! kinda screwy turning it on & off while turning - not recommended. and to anyone looking to do this mod: USE WIRE NUTS! i tried crimp butt connectors and they kept falling off. i ended up having to solder an extension wire onto both ends to have enough for the wire nuts i eventually picked up.
    anywho, thx for the DIY!
    SOLD 10/2011
    May 26 2009
    VA
    Thanks. +1. I appreciate the info. and the DIY
    Senior Member Three Rings MonkeyBiz's Avatar
    Feb 27 2009
    Nashua, NH
    Could you install the "Funk" button...http://oemplus.com/index.php?main_pa...roducts_id=545...and wire it to that?
    2004 B6 S4 6-Speed MT - Black w/Alcantara
    | ~ JHM ~ Magnaflow ~ Hotchkis ~ Hawk ~ Hankook ~ Hartmann ~ more to come...|
    Dec 03 2008
    2018 SQ5
    Yes, theoretically, but the funk button is only a momentary switch meaning, it will only turn it off while it is pressed. Supposedly there is a series of relays you can make to turn it into an on/off switch, but I'm no electronics engineer. Also not a big fan of the funk button, and was looking for something different.
    Veteran Member Three Rings felondnb's Avatar
    Jan 12 2008
    London, UK
    I might have to give this a go... it would be great to have an OEM style switch though
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    Established Member Two Rings nvds4's Avatar
    Jun 20 2011
    Elk Grove, CA
    Awesome...easiest & best mod ever! Just what the Doc ordered. Much "meatier" feel. Now I don't feel like a granny after driving the S4, then the 335, back-to-back.
    -Neil
    '06 S4 B7 Saloon, 6MT, Brilliant Red, JHM ShShifter+wt'd knurl SS knob, 641 relay delete, K&N drop-in, Vogtland C/O's, stock 18x8 BBS-CH (winter), 19x8.5 VMR v710's/Hankook V12 (summer), Audi Euro Flat-Bottom steering wheel, Seat Cupra R Lip, Euro front plate, F1 Classic tint 5% bk/Pinnacle ceramic 50% frt, Dension GW16AC1 & IPO5DC9 iPod Integr, Tune/Exhaust/Piggies soon (JHM/FI)
    Established Member Two Rings Fox's Avatar
    Apr 16 2012
    2017 S5 B8.5 6MT, BMW X3M40i
    Thanks for the DIY!
    Is there a way of installing the switch without cutting the black wire? I tried to pull out the wire after removing the top part of the socket but I couldn't do it.
    Also, is there another relay that we could use instead of 641 which would give us less steering assistance? How about the one used in RS4? I never drove an RS4 but I would expect that its steering is heavier than the one from S4. Can we use that one in S4 to make it heavier?
    Fox
    Established Member Two Rings go_getta's Avatar
    Jun 11 2012
    Edmonton, AB CANADA
    Thanks eddieman, just did the identical mod...cant wait for the drive home
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by Fox View Post
    Thanks for the DIY!
    Fox
    The RS4 has different suspension tuning, tires, and wheels, all of which change the steering feel.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Veteran Member Three Rings keithwbloom's Avatar
    Jun 20 2011
    2008 Audi A3 S-Line 2.0T, 2011 Audi A4 Quattro 2.0T
    Alexandria, Virginia
    I have been wondering about this since I got my S4. I noticed the difference more pointedly when I drove my B5.5 Passat the other day, it's steering input felt so much more dialed in.
    It is cool that it has been refreshed recently and came to the top of the posting activity. I would have never thought of the right terms to look/search for, and I loathe asking uneducated questions.
    I have bookmarked the thread, and will get started on a switch option right away. I think a modified FUNK button will suffice, my kids liked the FUNK button on my Passat purely for giggle factor. I have also been wondering what I could do with the three button blanks in the center console, I guess this solves for one of them.
    :wrench:
    Now: 2013 S5 Cabriolet Prestige, 3.0T Monsoon Grey Metallic, Black with Stainless Interior Trim, Drilled/slotted Rotors with EBC RedStuffs
    Before: 2007 S4 Cabriolet 6MT, APR Tune, AWE Touring Exhaust w/Down Pipes, B8 S4 Peeler 19s with Michelin Pilot Super Sport 255/35s, RS4 Grille, JHM Phenolic Spacers and 6-rib Conversion, Clear Corner Mod
    Aug 13 2008
    Reston, VA
    Did this mod on my s4 cabrio
    Module is numbered 628 on the cab, I have an on off switch
    Don't really like it on corners (too much effort), but much more stable on highway
    And to those that say it only affects low speed driving, that's wrong.
    Even at highway speeds (70-80) steering is much firmer with the mod
    Wish I could have it speed activated :)
    Aug 13 2008
    Reston, VA
    Quote Originally Posted by keithwbloom View Post
    :wrench:
    You're welcome to try my car before you do it
    In case you don't like it, you don't go cutting wires etc :)
    I live in Reston and work in McLean
