Results 1 to 11 of 11
    Jun 24 2004
    audi a4 2002 1.8t
    Stanford
    Angry radio reads 'safe' and is frozen
    all of a sudden the radio just blanked out and now when i turn it on, it just reads 'safe' and won't work. . .does anybody know the solution to this annoying problem? thanks.
    Veteran Member Four Rings nadroj81's Avatar
    Feb 12 2004
    Albany
    i think it just means someone tried stealing it, but they weren't able to get it, hence its "safe".
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    Press and hold RDS and AS together, find your 4-digit unlock code, and enter it, and again hold RDS and AS.
    Veteran Member Three Rings lawong's Avatar
    Audi A4 1.8TQMS APR Stage II
    Belmont, CA
    Standard Windows troubleshooting 101. Your radio crashed.
    Pulled the fuse to reboot.
    Veteran Member Three Rings KaiDaRudeboy's Avatar
    2003 A4 3.0Q
    Hawai'i/SoCal
    What he said... your code should be in your manual...
    -Kai
    GTA, Canada
    This happens when the battery is disconnected as well. Good to make sure you have that code before disconnecting.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Registered Member Three Rings HICK's Avatar
    Feb 13 2004
    2007 Honda Odyssey EX-L
    Ansbach, Germany
    Since we are talkin bout radios, are these things known to change volume by themselves? I know about the Gala setting that automatically adjusts the sound level as the outside noise/speed increases but my shiat just changed on its own the other day, twice. Same with my climate control. It just cut all the way off and then back on and it was on the econo setting, I never use a/c unless I am in traffic.
    Veteran Member Four Rings teutonic_blur's Avatar
    Puerto Rico
    We not only have have radios and a/c's that do weird things... our windows and sunroofs also have a mind of their own and decide to open and/or close at the most inappropriate times.
    Welcome to the twilight zone...
    If A is a success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut.
    Albert Einstein
    It's not that I'm afraid to die, I just don't want to be there when it happens.
    Woody Allen
    2003 A4 1.8T FWD 5M
    Revo SPS1, K&N drop-in, NGK Coppers
    Veteran Member Four Rings A4Shizl's Avatar
    Jun 11 2004
    2003 Audi 1.8T, 2005 Honda
    Inland Empire
    Hell, I though my sun roof was the only one that had a mind of its own....
    Jun 24 2004
    audi a4 2002 1.8t
    Stanford
    great, thanks! as always, you guys are a great help.
    Feb 22 2004
    San Diego
    the sunroof is a known problem. a bad potentiometer or something in the switch. i already had mine replaced and no more strange sunroof issues.
