Results 1 to 19 of 19
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    A little service reminder... just screwed me over
    thought i might look out for those who dont already know. if you have a black coolant temp sensor or a blue one you should switch to the green ones as the black and blue are faulty and can potentially cause many issues.... i just order mine from vw parts for like 3 bucks its like 6 total with the gasket. if you havent done this its time to do so....
    install #1:http://www.audiworld.com/tech/eng54.shtml (V6)
    install#2:http://www.audiworld.com/tech/eng47.shtml (1.8t)
    just a little preventive maintenance... it will take the V6 boys a little longer but its all good. enjoy!
    part#'s
    059919501A - sensor
    N90316802 - gasket
    Registered Member Two Rings
    May 26 2004
    Cali
    thanx will check it out tomaro
    1999 A4 1.8TQ
    San Jose, Ca
    Any particular model years this effects?
    My temps run high when I shut down the car and start it up again. Say I drive around when it was cold and it got warm (to the middle part), it'll stay there throughout the drive, but when i shut the car off, and turn it back on, it'll shoot up halfway between the middle mark and the H mark. But after somemore constant driving, the needle will go back down and stay back in the middle. You think this is faulty or is my coolant just running hot(ter)?
    I plan on flushing the system and refilling it up again with g12 comes next oil change. I bought one container last time and it wasnt enough to fill it up the the minimum line. I just added water. I think thats my problem.
    Mar 02 2004
    Orange County
    my understanding is that basically all of the blue and black sensors are faulty.. and fail... they no longer make the black ones and i dont think they make the blue ones either but not sure about that
    Established Member Three Rings A Foore's Avatar
    Apr 07 2004
    '05 6spd TSX with NAVI.
    GO LEAFS GO! GO LEAFS GO! ...
    I've noticed that my temp gauge doesn't always work. I will be changing my sensor, but I thought you can't use the green one if you currently have the blue or black one. That's just what I've heard. Is this true? If it will work, do I need to do any modifications to it for it to work?
    97 1.8TQ
    GIAC / 710N / H&R Race / Koni yellows
    Mar 02 2004
    Orange County
    no no you are supposed to change to the green one if you have either the black or the blue one. the black iirc comes on dbw vehicles while the blue came on ndbw.... not sure about that just what i have seen thus far.
    If you do this and this takes care of any of your ailments be sure to post your findings. i know this is not a new thing but there are alot of people on there that havent been on the audi forums for awhile so i figured i would revive the topic.
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    I changed my temp sensor cause my temp gauge was running crazy, up and down, that problem is fixed, only thing i noticed, when i shut the car off after a long drive and start back up, the temp is higher than middle, start to drive again and it goes back to center. any other sensors i need to change?
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
    Mar 02 2004
    Orange County
    did you change both of them on your car? (might seem like a dumb question) and you are using the green one?
    Feb 12 2004
    B5 S4
    I change one, i am using the green one now, where is the other one located?
    TEAM A.C.E. NY
    Q7, Q7, F-type manual
    No. The green one wont work on cars with the blue one, I know for a fact. they have two different connections. If you are having a problem with yours, the car should throw a code and let you know.
    on the 2.8, they are symetrical in location, one on the passenger side and one on the driver side in pretty much the same loaction in reference to the cylinder banks. they are a bit hidden and buried, but they are there.
    Feb 13 2004
    <> Posts: 9913
    I'm pretty sure that the blue and green have two different connectors, so they would not be interchangeable.
    I think Blue is for AEB engines, and the Green is for ATW. I'm not 100% on the ATWs, but I recall reading that.
    I have a 97, it uses the blue one.
    -Theodore Roosevelt, 1907
    Veteran Member Three Rings chrisrunner's Avatar
    Feb 12 2004
    97 A4 1.8t, 2000 BMW 328i
    boston area.
    my blue one went, so i went to the dealer and bought another blue one..which works...but it cost me 26 bucks,.
    chris.
    chris.
    http://img.photobucket.com/albums/v9...ri/Driving.gif
    you call it your right. i call it your weakness.
    Feb 13 2004
    <> Posts: 9913
    You can get them from ECS for about $10.
    Mar 02 2004
    Orange County
    i bought mine from vwparts for about 3 bucks i think 5 and change with the gasket.
    Mar 02 2004
    Orange County
    check the tech article i am pretty sure they all use the same connector... i will let you know for sure when we install one on nismosx's car cause he just got one and has an AEB.
    Just a heads up, I have seen them both side by side, and they are not the same, one wont fit in the other's slot.
    Feb 16 2004
    98' A4 2.8 30v 5spd, sport; 98 Nissan Altima GXE
    Santa Monica, CA
    what kind of mileage are you all having this problem? And did we narrow down a year?
    thanks...
    98' A4 2.8 Q 30v, 5spd, sport
    ~Every different monkey is different.
    Veteran Member Three Rings Kurzer's Avatar
    Feb 12 2004
    MkV VW Rabbit
    Beaverton, Oregon
    The only exception is the '96, I tried the green one and it was a no go. The '96 will only take the stupid black one
    Thank you: MatrixIntegrated
