Results 1 to 13 of 13
    Oct 11 2006
    Sway bar link stuck on old control arm. Dealer says to replace it...
    New control arms going on my car right now, and the dealer called to say that the sway bar link is stuck to the old control arm and cannot be removed without damaging it. $77 for a replacement. Anyone else run into this issue? Advice? I guess my car is stuck in the shop until I get something figured out...
    Oct 11 2006
    Re: Sway bar link stuck on old control arm. Dealer says to replace it...
    Or can the car be driven with only 1 sway bar endlink attached?
    Jan 25 2006
    A4 2.0T
    MD
    They probably stripped the bolt... I almost did the samething changing my rear sway on my B5. The sway bar link has this allen bolt and it may strip if you are not careful.... The sway bar link bolts were very very stubborn, even after some lubricant.
    Oct 11 2006
    Maybe I'll go check it out in person over lunch to see if it's stripped. Can it be driven with only 1 link?
    Feb 13 2006
    pb buster on that suckerr
    Oct 11 2006
    Just took a look and they stripped the bolt and chewed up the bushing on the link in the process. So I'll just get a new set from eBay for $35, but it seems a little strange that they mess something up and it's my responsibility to fix it...
    Oct 11 2006
    They did say they thought it'd be fine to drive short distances until the new links come in.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    One turning go real slow....if you are going to drive it. Otherwise, going straight has nothing really to do with the sway bars.
    As for THEM damaging the bolt, I would fucking raise hell, if they are trying to charge you.
    -Sami-
    Oct 11 2006
    "The bolt failed so the technician was not at fault."
    Oct 11 2006
    And of course the eBay set I was looking for $35 at was for a b5... b6 is $70. Not a big deal but I hate it that they won't take responsibility for damaging it. No amount of arguing is going to change their minds either. They couldn't care less if I ever come back again or not.
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    oh man, i gatta do my control arms soon, im figuring its the lower one. i guess ill take my time disconecting the sway bar link.
    what where the sympotons of noise whas it clicking on small sharp bumps?
    Oct 11 2006
    you could just feel something was loose in the front suspension, and a dull rattle on bumpy streets.
    Feb 20 2007
    ct
    Hmm thats not exactly my issue, i guess im going to have to look into it some more. its more of a clicking noise.
