Results 1 to 40 of 46
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    Got Rims - Cant Get Old Rims Off? Anyone Have This Problem
    so i picked up my rims today. i went to take off the old rims and after taking the lugs out, i could not pull the rim off. it was stuck to the car. what am i missing?>
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Active Member Four Rings
    Does you car stay outside at night? Not garaged. It may be like old brakes. A little bit of rust gets in there and they get stuck a bit. Try maybe hitting them with a rubber mallet from behind. That should knock them free
    Veteran Member Four Rings bong2611's Avatar
    2000 A6 AVANT, 2004 MBZ ML350
    Newark, Ca.
    man never heard of that problem before. Not sure what to tell you. Sorry.
    May 20 2004
    More cars
    Never Land Ranch
    i bet ou left one lug in and didn't realize it was still in there
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    1999 A4 1.8TQ
    San Jose, Ca
    Re: Got Rims - Cant Get Old Rims Off? Anyone Have This Problem
    Jack the car up first.
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    Tap around the tire with a rubber mallet, rotating the tire, so you hit it in all directions, then, hit it a few times from behind and presto, no more wheel!!
    Re: Re: Got Rims - Cant Get Old Rims Off? Anyone Have This Problem
    I knew it was coming
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    evil you are probably right. i noticed the lugs were rusted. now i just have to find a rubber mallet.
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Registered Member Two Rings
    May 26 2004
    Cali
    No No No Just drive around until they fall off. Duh
    Q7, Q7, F-type manual
    had the same problem with my swings after winter. if at first you dont succeed, pull harder . Anyone know if it would be a bad idea to use a little grease on the hub when putting rims back on for the winter or even in general?
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    good thinking. i drove around and they fell off. thanks guys, couldnt have done it with out you
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Feb 18 2004
    Audi A4
    East Aurora NY USA
    Kick the side of the tire straight on. it will fall off, don't scratch your wheel.
    i like my black girls clean and my white girls dirty.
    doesn't matter either way they're all out to hurt me.
    Registered Member Two Rings EnvyJK's Avatar
    Apr 28 2004
    VA
    easy, just give a few solid kicks on the tires. This happened to me before, it's just rust
    www.nuvowire.com
    Your community providing Washington D.C. regional events, chat forums, classifieds, job postings, and much much more!
    Veteran Member Four Rings SFexBOY's Avatar
    Feb 25 2004
    1990 BMW 325iX
    Staten Island, NY
    i hope you put the lugs back on when you did this
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    nah, no lugs. i just let the tires fall off and i skid about 400 yds. then i made sure i pulled the ebrake so i would roll backwards. im gonna grab a mallet and take it to the tires tommorow. if the rubber mallet doesnt work, ill just kick it like you guys said.
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Registered Member Three Rings AFOUR_PLAY's Avatar
    Apr 15 2004
    Sydney, Australia
    Rubber mallet will work, as HotSauce said above.
    Same thing happen to me when changing pads.
    Daniel
    http://smileys.smileycentral.com/cat/3/3_2_116.gif
    A4 1.8T Quattro - Clicky Here
    -Stoptech Brake lines - RS4 Grille - DIESELGEEK SS - GFB DV - APR Snub Mount - K04 Turbo - Samco Turbo Inlet Hose - S3 injectors - GIAC - 18x8.5 1/16 Carlsson copy 18/40/235
    Newark, Ca.
    by the way, what wheels did you get?
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    i picked up moda r3's with wheels for 200 bucks. not sure how i will feel about the wheels until they are on. i figure worst case scenario, i can turn around and sell them. they were on the guys s4, but i didnt see them on it.
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Feb 18 2004
    Audi A4
    East Aurora NY USA
    Seriously, just a good kick straight on perpendicular to the sides of the tire will drop it right off...what happens is the alloy of the wheels and the hubs react to each other and rust solid to each other.
    When you put on your new wheels use some never seize.
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    so i should kick the treads of the tire head on or i should stand facing the broad side of the rim and kick it.
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Jul 26 2004
    Madison
    Just kick the tire, any pressure should break it loose.
    "When all else fails, use a bigger hammer"
    Apr 15 2004
    Sydney, Australia
    Just kick it already!
    Daniel
    May 26 2004
    Cali
    whats wrong with my idea ? lol If kicking doesnt work go ask a tire shop if you have a ride to get there. I bet they have something to get the job done for you.
    Registered Member Four Rings audlman's Avatar
    Apr 19 2004
    04 SRT-4
    louisville, ky
    eat your spinach! lol
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    alright, ill give it the boot
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Registered Member Three Rings []D[][]V[][]D's Avatar
    Jul 22 2004
    2004 A8L 4.2, 2004 A4 1.8t Cabrio, 2000 A4 1.8TQ
    Los Angeles, Ca
    give it the boot! give it the boot!
    well?
    Veteran Member Four Rings MKGIY's Avatar
    2012 S4, 2012 GMC Acadia
    New Jersey
    SO, did the boot work or what?
    Mike
    Veteran Member Four Rings buck's Avatar
    Feb 16 2004
    '05 Tacoma & '03 Yamaha R6 & '14 Yamaha FZ-09
    Simcoe County ON, Canada
    If the kicking/booting/hammering doesn't work (like it didn't in my case), just loosen your lugs and drive up/down your street for a minute until you feel a little vibration and voila - your wheels are now ready to be changed!
    seriously!
    APR 93 Octane Chip, VDO Boost Gauge, 710N, Koni C/O's, Carbonio CAI, High Flow Coconut air freshener.
    60% of the time, it works EVERY time.
    Veteran Member Three Rings G-low's Avatar
    Feb 13 2004
    Ct
    was changing my buddies rims on his 325 and those things were a pain he had beat the crap out of the tire to get the damn things off its suprizing how strong rust it
    as for the driving with loose lugs idea that doesnt sound too safe
    97 1.8tqm T3T4
    Veteran Member Three Rings chrisrunner's Avatar
    Feb 12 2004
    97 A4 1.8t, 2000 BMW 328i
    boston area.
    usually a good kick at the top of the wheel gets mine off..theres this stuff called anti seize lubricant...a silver bottle..put it on the bolts and it keeps everything rust free.
    chris.
    chris.
    http://img.photobucket.com/albums/v9...ri/Driving.gif
    you call it your right. i call it your weakness.
    Newark, Ca.
    well did you get the wheel off?
    Feb 16 2004
    Originally posted by G-low as for the driving with loose lugs idea that doesnt sound too safe [/B]
    maybe not safe to take on the highway - but perfectly fine if you're only doing <5mph in front of your house. You only need to loosen them until you can see a paper thickness gap between the lug and bearing surface on rim. I'd hate to damage my rim by hitting it with a hammer. BTW - ever try to hit an inflated tire with a rubber mallot? .... BOOOIIIINNNNGGGGGG
    Not only do I put an anti-seize compound on my lug threads, I also put a little on the bearing surface between the rim and the brake rotor. Hopefully when I'm ready to put the winters on - I won't have this problem.
    Feb 21 2004
    MA
    As Chrisrunner said give it a few good kicks and it will come right off!
    Feb 12 2004
    00 A4 1.8T
    i know its ok to put anti-seize on the bearing surface, is it safe to put it on the lug threads (in case they might loosen easier during driving)?
    <a href=http://www.turboawd.com><img src=http://www.audizine.com/gallery/data/500/347turbosig.jpg border=0></a>
    Registered Member Two Rings markc's Avatar
    2000 Audi A4 1.8 turbo sport
    Portsmouth, England
    Enough already!!!! Did he get the wheels off???? I usually put a thin film of copper grease between the wheel and brake rotor, never had a problem getting the wheels off.
    Registered Member Three Rings aborchew's Avatar
    Feb 25 2004
    '98 Audi A4 2.8QM
    Chicago, IL
    Same thing happened to me, the wheels get oxidized and stuck, I didn't even use a mallet. I was a bit rushed (with a flat) last time I have to remove mine and I just kicked it with my heal from behind. Came right off.
    Feb 18 2004
    Brooklyn
    one way is to leave a lug on loosely while car is jacked and kick it so that when it comes off it doesn't fly off
    another way is to leave a lug or 2 on loosely then drop the car back on the floor...now rock the car sideways....it should loosen the wheels from the rust from the weight of the car....this way u don't have to kick ur wheels....
    aka NYC_SpeedRacer
    Apr 15 2004
    Sydney, Australia
    He is probably still trying to get it off this moment!
    The suspense is killing me!
    Daniel
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    This makes me sad
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
