Results 1 to 8 of 8
    Jul 26 2004
    Sacramento
    Radio Static problem
    Hey everyone, I'm a new A4 owner and wanted to know if anyone has had a problem with radio static when they turn on the REAR DEFROST? If so how did you fix it? Also where is the antenna located? I have a 98.5 A4 with the Bose system. I think its the concert I head unit. Thanks for your help.
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    Re: Radio Static problem
    Bringing this back........
    I changed my radio from concert to Pioneer p7700mp when I bought the car. Ever since I changed the radio I get static when I turn on my defrost. I bought the amplified antenna adaptor from Crutchfield, but it won't fit my radio as the 7700 already has a coax out from the deck. I assume this means the antenna feed is already amplified.
    How can I get the static to stop? Any ideas?
    14 A4 allroad - stock
    05 allroad 2.7T Stock
    Feb 23 2007
    Burlington
    Alright....so here's what I found. When I took out my deck to attempt to fix this, I thought about grounding the antenna onto a better part of the car. I took the wire and started touching it to different parts of the radio and different parts of metal. I was curious to see what would happen when I touched the neg. of the antenna connection to the corresponding spot on the radio antenna connection, it was perfect!
    Best I can figure is the connection between the stock antenna and the connector on the deck is weak. I'm going to try to find a connector to make this easier, but short of that I'm going to solder a wire from the neg. of the stock antenna to the neg. of the HU antenna.
    Problem solved!
    Feb 23 2007
    Burlington
    well......so much for that idea. Tried to solder the wires into place and it didn't even make a difference. Now I'm at a loss again. Stupid Audi antenna
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    I get horrible reception in my car as well. I have the amplifier from crutchfield and it helps a little, but still can't get reception unless i'm less than 30 miles from the broadcast antenna. Luckily I rarely listen to the radio, Mostly XM and the iPod for me.
    Feb 23 2007
    Burlington
    my reception is awesome on fm. I have no concerns at all. However, I don't get AM, but really, who cares.....it's just now that it's getting cold and we have frost and shit, I want to be able to hear my radio when my defrost is on....not static.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    yeah i get fine reception when i dont have the defrost on. this has only been happening after i had the rear glass changed from when the glass broke. i never had the problem before that. anyone else who experiences this issue have the rear glass changed?
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Feb 23 2007
    Burlington
    this makes me wonder whether its a ground connection from the glass to the body, or is it just the wires are getting old.....could be both I guess....
