Results 1 to 3 of 3
    Veteran Member Four Rings Pureaudi's Avatar
    Jun 23 2004
    97 a4 1.8t
    San Jose
    oil temp readings?
    what should your oil temp gauge read when its all the way warmed up?
    Feb 17 2004
    Sterling, VA
    It depends. My car will reach normal coolant temp and the oil temp will read between 150F -175F.
    Once I get the boost flowing, I can sit in the 190F-220F range.
    I guess the max oil temp would be best to stay under 230F.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings A4 in SC's Avatar
    Feb 16 2004
    '84 911 Carrera GP White, Burgundy cloth
    Simpsonville, SC
    Agreed. It varies. I know on my car, once it hits 175 degrees, I feel it's warm 'enough'. My car normally doesn't go over 200 degrees - it usually stays at 190.
    Mike
