Results 1 to 16 of 16
    Jul 18 2004
    SF Bay Area
    1.8T Test Pipe Group Buy
    I've put together the Tantrumwerks' 1.8T Test Pipe groupbuy. Price will be $189 + s&h for 10+ buyers (10% off $210 list price).
    Please click on link for additional info:
    Test Pipe GB link
    Veteran Member Four Rings Villains's Avatar
    2003 and 2006 Audi A4
    Woodland Hills, CA
    Just FYI, the test pipe from EuroCode is $199 and there is no GB needed.
    http://www.ecodetuning.com/home/
    -Derrick
    It will be nice working with proper villains again!
    - Basher (from Ocean's Eleven)
    Veteran Member Four Rings Starting's Avatar
    Feb 13 2004
    98 A4 1.8t
    Central, NJ
    worth it to get in on the group buy?
    Feb 22 2004
    1999.5 Audi A4 1.8T quattro
    Henryville, IN
    Originally posted by LAS
    i've seen both pipes.... there's a difference.
    What's the difference?
    Never Follow
    Woodland Hills, CA
    Really? They are both made by the exact same company for the two distributors. I have gone to the factory where they are made and talk to the owner. Your eyes must be seeing something that even the manufacturer doesn't know about.
    They are the exact same thing. EuroCode and Tantrumwerks get them from the exact same place.
    -Derrick
    Registered Member Three Rings QuattroCoryG's Avatar
    May 10 2004
    Silver 98.5 Audi A4 1.8TQ
    St.Louis, Missouri
    Thanks for the heads up derrick.
    Veteran Member Four Rings LAS's Avatar
    Feb 12 2004
    HI.
    maybe i should've said "slight" difference. may not mean much to you, but for some people, attention to detail counts. they(labree) probably provided the first pic for a reason. not exactly the same, but yes, still function the same.
    here's a pic of the ecode(left) and labree(right) pipes:
    Woodland Hills, CA
    I don't know where you got the pic of the Ecode one, but my test pipe did not look like that when I got it. It was clean like the second pic.
    -Derrick
    Feb 12 2004
    HI.
    Originally posted by Villains
    I don't know where you got the pic of the Ecode one, but my test pipe did not look like that when I got it. It was clean like the second pic....
    They are the exact same thing. EuroCode and Tantrumwerks get them from the exact same place....
    i took that pic this morning right on my desk.
    enhanced from the ecode website:
    Woodland Hills, CA
    Even the one from the website doesn't look as bad as your first pic. The first pick looks like it is used and torn up. The one from the website is more of what mine looked like. By the way, the little clean up work that looks like the other one has mine had as well. Maybe they just started doing that, but like I said they are both made by the same company and shipped to both distributors so why wait for 10 people to save only $10 on the same item?
    -Derrick
    Feb 26 2004
    Akron, OH
    Guess who's back back back, back again... Villians back back back, tell a friend. LOL.
    BTW, my testpipe looked like what was in the first picture and I never got any sort of gasket or bolts... I had to use stock ones, so the pic from ecode is a bit decieving...
    Jul 15 2004
    San Diego, CA
    So does a test pipe replace the cat? I'm confused
    Feb 12 2004
    HI.
    yes, that is correct. frees up the exhaust flow.
    Senior Member Three Rings ItsJ's Avatar
    May 26 2004
    BMW 335i
    U.S.
    if i were to get it can i use it with the miltek 2.75 or borla 2.5 exhaust and will i fail emissions tests and get all sort of check engine lights
    btw....
    what is the diameter on this piece
    Current: 2008 BMW 335i
    Past Audi:
    -2002 Audi TT
    -2002 Audi S4
    -2001 Audi A4
    Veteran Member Four Rings quattro_maniac's Avatar
    Aug 29 2004
    2001 Audi A4 1.8T Quattro
    middletown, nj
    btw....
    i'd also like to know the diameter of the piece...
    can it be fitted to the stock exhaust?
    what's the diameter of the ecode one?
    WorkSafeBoredom
    Mr. Blonde
    Borla - GFB - BFG - Flik - RedLine
    "The American dream really is fucked." - Hunter S. Thompson
