Results 1 to 12 of 12
Thread: Boost readings?
    GTA, Canada
    Question Boost readings?
    What are normal boost/vacuum readings?
    When cruising it varies, but if I come off the gas and am coasting it reads about 24 in/Hg (or whatever the pressure is). At lights the pressure is about 15, if idling in neutral its about 18.
    First time driving with a gauge, just wondering what everyone gets for readings...post them up please!
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Veteran Member Four Rings Audi_Sniper's Avatar
    01 & 04 Audi A4 1.8t quattro
    Buffalo, New York
    Thats about right.....
    Bringing the Great Lakes Regions Together
    http://www.greatlakeseuros.com
    BetaAlphaTau Member # 30
    The toys:
    01 Audi A4 quattro APR stage III (Fast and tight like some of your little sisters)
    04 Audi A4 quattro (Der neue tägliche Treiber)
    Veteran Member Four Rings buck's Avatar
    Feb 16 2004
    '05 Tacoma & '03 Yamaha R6 & '14 Yamaha FZ-09
    Simcoe County ON, Canada
    If my rev's are above idle and I'm decelerating, I'm reading about 22-24Hg of vac.
    At idle, it reads around 20Hg. At start-up, it is between 10 and 20Hg.
    So what does a "stock" ecu boost at ;)
    APR 93 Octane Chip, VDO Boost Gauge, 710N, Koni C/O's, Carbonio CAI, High Flow Coconut air freshener.
    60% of the time, it works EVERY time.
    GTA, Canada
    A whopping 10 psi, or there abouts.
    Just an easy commute to work, haven't seen what it will spike at and stay at. But right now it looks maybe 12, then 6-8.
    Feels like a waste, half the numbers on the gauge are never used.
    Audizine
    Feb 16 2004
    you know an APR or X-chip will fix that right up
    Veteran Member Four Rings awahl63's Avatar
    Jul 25 2004
    Phoenix
    *starts chant* chip it chip it chip it...
    Feb 16 2004
    *continue chant* ... chip it... chip it....
    GTA, Canada
    lol....donations welcome to Ripple's Chip Fund.
    Audizine
    Registered Member Four Rings joeya103's Avatar
    Apr 04 2004
    98.5 A4 1.8T Tip FWD
    Northern VA
    wow i'm surprised that a stock ecu can even hit 10psi. that's not that bad, i thought it was like 6-8 psi max or something.
    Veteran Member Three Rings Brrman's Avatar
    Indianapolis
    10 psi? I never hit 10psi when I was stock. 8 psi is what I normally hit. Of course I hit much above 10 these days.
    2019 S4 Prestige
    RIP... 2013 A4 Allroad
    SOLD 2007 A4 2.0T S-Line Ti (APR stg1, Koni Coilovers, LED Tails)
    SOLD. 2000 A4 avant 1.8T (GIAC stg1, Bilstein/H&R)
    RIP... 1998 A4 1.8T (GIAC stg1, Bilstein/Neuspeed)
    GTA, Canada
    I'll have to take a closer took tomorrow.
    I definately was holding 8 on the way home at times, but thought it got up and spiked at 10. Will have to double check later.
    Audizine
    Registered Member Three Rings
    Jul 13 2004
    san diego
    kinda a late post but is it normal for me to hit 20 psi when not even at wot....ill be pushin the pedal hard...but im not floored....i duno i thought it was kinda odd
    oh yeah i have a ko4 w/giac software
    one point eight tee
