If you are going with OEM fit don't got for pricy things, no need. a cross drilled OEM size rotor isn't going to imporve stopping much more(if even) cause, with the drills in your rotor, you are loseing surface area when the pad presses against the rotor.
Since you are just a daily driving, i would say go with slotted or just reg. cause you won't be loseing so much surface area, and plus your rotors arn't going to get that hot that you will need breathing holes in your rotors. If you are going to a big brake kit then yes i might say go with xdrilled, but if they are just oem i say slotted or reg. I have all ATE rotors powerdisc fronts and cheap ATE rears, and i have PBR/Axxis metal master pads. Everything came to $275, and i did the installation myself.
