Results 1 to 12 of 12
    Feb 15 2004
    2009 M.B. C300 Sport 6Sp
    T.O. Canada
    Anyone use the GFB Boost controller in their car??
    any benefits to use one of these with my current mods?
    - Chip
    - Exhaust
    - HI-flo cat
    - intake
    Opinions?? Or another MBC you recommend?
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    Re: Anyone use the GFB Boost controller in their car??
    - Chip
    - Exhaust
    - HI-flo cat
    - intake
    that is what i use and i am happy with it.
    Feb 15 2004
    T.O. Canada
    What mods do you have on your ride??
    Mar 02 2004
    Orange County
    lol you name it short of a big brake kit which is coming up next... i ran the MBC on my K03 and there were some good things to come of search for another thread where we had a discussion on them it shows how to install them as well.
    Active Member Four Rings
    Feb 18 2004
    Audi A4
    East Aurora NY USA
    What do you plan on using the MBC for? Lowering boost or raising it?
    i like my black girls clean and my white girls dirty.
    doesn't matter either way they're all out to hurt me.
    Raising most likely
    Feb 18 2004
    Audi A4
    East Aurora NY USA
    I would expect GIAC to push the Ko3 as far as possible safely. There really shouldn't be a need for a MBC at least if you have Ko3 software and a Ko3 turbo. I also wouldn't run 15psi or whatever on stock software...wouldn't want to lean the car out.
    Mar 02 2004
    Orange County
    there are other things that a bleed valve causes that GIAC has no control over. not every one is running an xchip either. as for stock software i have made it blatently clear that boost controllers should not be used with it. though its not necessarily the best thing for the turbo i used the mbc to make up for the 1.5 psi i lost from my front mount.
    Feb 15 2004
    T.O. Canada
    My Chip tends to have low boost in 1-2 gears...
    so I was thinkin of tuning it with a MBC, and try and raising the boost level for the low end..
    Also, testing a Hybird BOV....
    So, should I get this MBC ?
    Feb 18 2004
    Audi A4
    East Aurora NY USA
    Hybrid BOVs work but they'll make you lose a few MPG...at least that's what happened to me.
    Mar 02 2004
    Orange County
    check your MAF...
    Feb 15 2004
    T.O. Canada
    Check if its working??
    last time I VAG'ed it....it was still functional...
