Results 1 to 6 of 6
    Veteran Member Three Rings wsdfOO's Avatar
    Feb 12 2004
    02' Audi a4 avant stg3 **sold 05' Evo MR **sold '10 Lexus RX450h
    Cerritos
    B5 S4 brake question..
    just a couple thoughts. if we can directly transfer b5 s4 brakes to b6 a4's, does that mean we can use direct replacement brakes with s4 caliper on our cars? doesn't sound like a bad alternative to a bbk.
    I miss my wagon...
    Veteran Member Four Rings Mark's Avatar
    1959 MGA 1600
    Chocolate Land, USA
    you need rotors and pads that are for either the B5 S4 or the 2.7T A6.
    I have tried two sets of OEM S4 rotors, both got deposits onthem very badly. Then moved onto slotted Disc Brake Australia rotors with mintex pads. The newer DBA 4000 series work very well.
    it is a good alternative to BBK's, much cheaper . . . but BBK's are the way to go if you are going to be racing.
    -Mark
    1987 5000 CS TQ 2.2T I5 - No more . . .
    2002 Denim Blue A4 1.8TQMS - RIP
    2005 Ebony Black Pearl allroad 2.7TQMT6
    Kinda stock . . . Tinted, H-Sport Sways, HP-2 Calipers, RNS-E, Bluetooth, and iPod/Sirius combined
    Got Vag-Com?
    Veteran Member Four Rings zemun2's Avatar
    Feb 20 2004
    '04 A4 1.8t FWD APR Tuned
    Zemun, Serbia.
    Steve,
    If you're gonna be doing B5S4 calipers you will need B5S4 rotors and pads and I would also recommend G2 caliper paint, SS lines and some good brake fluid.
    Entire set up will be around $700-800 for front.
    APR Tuned Serbia
    Authorized APR Distributor
    Feb 12 2004
    Cerritos
    well what i was thinking of doing was going with s4 calipers along with stoptech direct replacements. for the price, you can't beat the performance. definetely not gonna be tracking but the stocks brakes are getting old fast.
    Steve,
    yep those are definitely on my list of upgrades. motul baby!
    anyone know how big the s4 brakes are?
    I miss my wagon...
    Jul 21 2004
    South Florida
    B5 S4 brakes are 321mm x 30mm with a twin piston caliper. Stock rotors weigh in at approximately 21lbs per and the calipers weigh about 20lbs per as well. This is one heavy braking system, but again not very relevent unless you're tracking. You can get used S4 calipers for $200 or so and Zimmerman rotors for $200 and you're set. Stainless lines, RBF600 and some nice Pagids or Ferrodos and you're set. CHeers! Mike
    2018 Audi S5
    Gone-
    Registered Member Two Rings
    Mar 11 2004
    Mukilteo, WA
    I'm probably going to sell my b5 s4 hp-2 calipers if you're looking for a set. Just calipers though, no rotors (because I was going to buy sportech oem replacements or dba 4000's).
