Results 1 to 17 of 17
    Registered Member Two Rings
    Feb 13 2004
    SD
    1.8t challenge preparations continue
    Earlier this week Mike gave me a big hand and we pulled the front koni's out and dialed up the rebound dampening 10% from 70-80. The front end of the car settles much quicker than before when the weight is imbalanced from a bump. Today we went ahead and installed a set of H-Sport sway bars replacing the old stock/neuspeed setup I had.
    remaining to do items:
    Finish brake ducting
    Awaiting Carbotech pads
    Finish Oil cooler
    Potentially a new turbo kit... :) we'll see.
    In anycase here are some blinging H-sport pics for you guys to drool on :P BTW the h-sport front bar was 4lbs lighter than the stock sport front bar, and the rear was ~.4-.5lbs lighter than the neuspeed bar.
    Much thanks to Mike and Helen @ purems again for their time and assistance!
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    good stuff i get my H-sports on monday and just installed my AWE DTS.... too bad i am not gonna be in the 1.8T challenge though. Good Luck!
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    how do you like the H-sports compared to the Neuspeed/stock setup? i'm on the fence right now and will be ordering something monday afternoon.
    Jim
    I Do Werk.
    Feb 13 2004
    SD
    Well i've only had them in for a couple of days and to be honest haven't been able to push the car to the point of breaking the tires free. I avoid doing that sort of thing on the streets. But so far the car feels much more grounded when pushed hard through a turn. The car feels like it's just squatting under load and holding through most turns very well. Definately less twist(roll) in a hard turn. Turn in is noticeably quicker as well. We'll see how they do at the challenge :)
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    so what do you think.... is it worth it yet?
    2017 Toyota 86
    Veteran Member Four Rings awahl63's Avatar
    Jul 25 2004
    Phoenix
    Nice I've got the H-Sports great quality stuff
    Feb 13 2004
    SD
    So far so good :) Considerable difference over neuspeed.
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    anyone know where I can get those brackets? I don't want my rear end tearing off and I don't have a neuspeed or H-sport bar
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
    Feb 12 2004
    LA
    sweet...mike was telling me on sunday that you were there on sat installing the sway bars and lucky you it was cooler that day than it was on sunday
    Feb 13 2004
    SD
    Hehe, what were you doing at mike's anyway? I didn't ask him =P
    Feb 12 2004
    LA
    changed suspension setups to koni/vogtland ... so much happier now
    Feb 13 2004
    SD
    Sweet... just like me now =P well almost i have a4 front/s4 rear springs hehe
    Feb 12 2004
    LA
    yep almost the same
    Feb 13 2004
    SD
    And you're probably running S4 koni's and not a4 konis. Btw what setting did you put the shock rebound dampening to?
    yep almost the same
    Feb 12 2004
    LA
    actually i'm running the a4 koni's as thai had them since i just took his old setup. IIRC he had them 60/40 but I could be wrong. I was going to bump it up but Mike already put in one side so oh didn't get to adjust it. I'm still happy with the current settings definitely a big improvement over my h&r/bilstein setup
    Feb 13 2004
    SD
    sweet. :) I'm running 80/85 right now and i'm very happy so far.
    Apr 24 2004
    DC/NY
    Paul, speaking of 1.8t challenge preparations I sent you an email today. Bad news buddy, turbo won't be in my hands until thursday. Probably too late for 1.8t challenge right?
