heres what to do......Take the 1000.00 dollars you have now....and just do a stage of your system..short cuttin a system will only leave you dissapointed! Mids and highs are imparative to a system(you said"I want to run 5.25s in the front, I don't care about the back seat passengers so I don't need rear deck speakers right? ") No , thats Wrong. a system should be balanced, rear speakers should not be as loud as your fronts...its called "rear Fill" If you can understand this..when you are in your car think of it as a concert hall....there should be a direction from which most of the sound is comming but there should be sound all around you..this is called "imagining." To try and come with in what you can spend now....I would have to say look for a good mid/hi amp...I recommend Phoniex Gold or JL audio..(I am running there(JL) 4x75 watt amp bridged 150 x 2 for just my 3 way seperates with MB quartz comp cross overs). In the Audi's, this amp will be great in the 4x75 config. Also look into JL line of seperates and co-axles or MB Quartz seperates and co-axles. Both companies make GREAT stuff. Start with these things..make sure to get heavy guage wire, Power and GROUND..this helps keep any possible buzzing noise(ie.engine noise,wines when the motor revs or at idle) you can use a line level converter and run the stock head unit for now. IF you can find a place to get you a good deal on amp, mids/highs, anda head unit.....There is only one IMO...ECLIPSE..look for a 5V pre out unit..CLEAN SIGINAL =CLEAN SOUND..this also goes for amps! Take your time and do it right, you will be way happier that you did in the end. When you get more cash....Stay with JL..they make the BEST subs!!!!!!! and with that sub ...10W3....use the 250x1 or the 500x1 JL..hope this helps..Chris good luck
