Results 1 to 15 of 15
    Veteran Member Four Rings Wholsea's Avatar
    1998 Audi A4 1.8tqms
    Blacklick, OH
    Battery, Alternator, or Starter?
    Hmm, yesterday leaving the office, car slow cranked, didn't think it was going to start...
    Got all the way home, no problems, went to start this morning, got two "whining cranks" then a click click click click...
    Checked the oil (don't know why) got back in, and tried again, slow cranked until it started, duno what's wrong... I think it is battery related though...
    Any ideas?
    1998 A41.8tqms
    Veteran Member Four Rings buck's Avatar
    Feb 16 2004
    '05 Tacoma & '03 Yamaha R6 & '14 Yamaha FZ-09
    Simcoe County ON, Canada
    doesn't sound like the starter.... sounds like there isn't enough juice to turn over the car.
    take the battery in for a test (make sure you have your radio code for when you re-install the battery).... if the battery is OK, it may very well be the alternator. You running a big stereo?
    APR 93 Octane Chip, VDO Boost Gauge, 710N, Koni C/O's, Carbonio CAI, High Flow Coconut air freshener.
    60% of the time, it works EVERY time.
    Registered Member Three Rings A4-Vblack's Avatar
    Feb 19 2004
    A4 2.8MQ
    Austin, TX
    Battery - just ahead and replace it. 48D is the size that you want.
    http://www.audizine.com/gallery/data/500/709S4_Sig.jpg
    2000 S4 / 18" RS4 Wheels / RS4 Grill / HW Val 1
    Blacklick, OH
    Daaaaamn...
    Just looked at interstate batteries... $100 for a damn battery.
    1998 A41.8tqms
    Registered Member Two Rings
    Feb 13 2004
    Sacramento
    i had a similar problem before, i took the car to autozone to have them test it, and they said that my battery was giving good wattage however my amps was down by ALOT 20amp instead of the normal above 80amps.... ALTERNATOR problem....
    saved me buying a battery.
    maybe you should go have yours checked... wouldnt hurt.
    Registered Member Three Rings awe4rings's Avatar
    Feb 18 2004
    Fairfield County, CT
    I bet you have a dead cell or two.
    -awe4rings
    Feb 13 2004
    99 1.8TQMS
    San Diego
    First thing...take off the caps on your battery and check the water level. IF they are low then you need to put some DISTILLED water in the cells and then try to start your car again. Jump start if required. Make sure the water is distilled and not tap water. Batteries aren't exactly maintenance free so check the water levels if you start experiencing starting problems.
    Drive a while and if see if the problem comes back. The solution may be that free and easy.
    If that doesnt help, then take the battery to autozone or something to have them test the battery first before you start buying a new battery, alternator, or starter.
    //99 1.8TQMS Brilliant Black
    K04 GIAC P-16, 310cc Injectors, 3bar FPR, Carbonio intake, other goodies....
    Blacklick, OH
    Yeah, battery was toast. At full charge had less than 300 cold crank amps, and would not hold it (continually loosing charge)
    Replaced battery, starts right up.
    1998 A41.8tqms
    Feb 19 2004
    A4 2.8MQ
    Austin, TX
    If the alternater is going bad, wouldn't it show in a your voltage meter on the display? Or at least show low?
    Blacklick, OH
    one would think so. Mine was definately the battery, when the key was in the "on" position, it would register <8 volts...
    1998 A41.8tqms
    Veteran Member Three Rings JpnA4Quattro's Avatar
    Feb 19 2004
    2001 Audi A4 Quattro 5spd,
    Santa Barbara
    same thing happend to me and the interstate batt. cost me 110. Which sucked even more was I had my windows down in a parking lot so I couldnt go out and leave my car unless i wanted it jacked.
    May 20 2004
    More cars
    Never Land Ranch
    i had to get my battery replaced too cause it would click click click click also. I got a 89M battery for $80
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Jul 12 2009
    San Francisco
    I'm having same issue with my B7.. car lights are all on, stereo can turn on etc. But car wont start makes a sound trying but then nothing happens.. i had it jumped and it started immediately. what to do ? is it possible i have a short somewhere? I was doing some wiring work 2 months ago. Could something like that be related to wiring?
    B6/B7 owners: Buy my OEM suspension for $50 4 springs + 4 Struts
    Veteran Member Four Rings TConklin821's Avatar
    Mar 17 2011
    Binghamton, New York
    I had the same issue. Got a new battery from Napa and voila, problem solved.
    2001 A4 1.8TQM. Custom catless turbo back, GTRS turbo, 440 green giants, FMIC, custom tune, ECS RA4 clutch + LWFW, short throw, ST coils, 235-40-18 tires
    ^RIP^
    Veteran Member Four Rings ianwpb's Avatar
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    West Palm/ South Florida
    I had to buy a battery recently for my wife's jeep. I found a great way to save $20. Go on advance autoparts website. Find the battery put it in the cart and select in store pickup. Google advance autoparts coupons. I found a $20 off 100 dollar purchase online only. Put in the coupon code and your payment and go pick up the battery. Being your old one for another $10 off. I ended up paying $86.00!
    '16 Q5 3.0t S-line Daytona Grey Pearl, Black Optics, APR stage 1, Magnaflow exhaust (Looking for stock exhaust)
    '16 S3 Misano Red Pearl, Black Optics
    Gone -
    '13 Q5 2.0T Premium Plus
    '13 BMW 135Is 6MT Coupe - #387/586
    '01 S4 6MT - SRM K24's, Stock Block, E85 448/392 Mustang Dyno
    '12 A3 TDI Premium Plus
    '10 A3 Premium
    '99 A4 2.8 5MT
