Results 1 to 10 of 10
    Apr 25 2004
    2000 Audi A4 1.8T, 2001 M-Bz ML430, 2002 BMW 745i
    Mississauga
    Central Dash Display went out? Help?
    Hey, i have..
    2000 Audi A4 1.8T
    Just today i was driving and i noticed that the middle thing went out.
    I have the auto/tiptronic. If you look int he central dash board, it is the place that is on top of display that displays your gas milage per gallon or whatever. It's on top of the gear display. The thing is totally blank now when i drive when it shouldn't be.
    However, the display is functional like when you open the door and stuff. Anyone know waht I mean? If you do help please
    Awaiting Confirmation Four Rings
    Feb 12 2004
    Albany NY
    on my '97 my digital odometer reading went out. The dash on mine is dif. setup then urs. But audi said you have to replace the WHOLE thing. Cost of this replacement u ask? $500. I said i can guess how many miles are on my car
    Apr 25 2004
    Mississauga
    The whole thing isn't out. Just the one piece section in the middle
    Feb 13 2004
    <> Posts: 9913
    Usually whenever something goes wrong with it you have to replace the whole thing. Maybe you can score one from a junk yard to same some dough. Also check out www.car-part.com
    -Theodore Roosevelt, 1907
    Feb 12 2004
    Albany NY
    Either is mine. Its just the odometer reading. Everything else on my dash works fine except that one little glitch.
    Registered Member Two Rings
    '01 Audi A4 1.8T, now '05 WRX
    Gainesville, FL
    On my 2001 i have a button under my windshield washer lever its located about an inch from the button that tells you what your avg miles are and everything else. try punching the lower button of the handle and it should come back on. Oh and make sure the car is on when you do this.
    Veteran Member Three Rings JpnA4Quattro's Avatar
    Feb 19 2004
    2001 Audi A4 Quattro 5spd,
    Santa Barbara
    maybe you pressed the reset button on your windshield wiper. Check that out. If thats not it, pray that you dont have to replace that whole thing.
    Feb 19 2004
    Santa Barbara
    ah you beat me to it but yea, what he said.
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    like the last few people that responded are correct, you pressed the OFF button which is on the underside of your windshield wiper stalk. Also take a second and read your car's manual, there is a lot of useful information in there.
    Veteran Member Four Rings jefferson88's Avatar
    Feb 12 2004
    08 A3 2.0T S-Line
    G-town, Ontario
    I accidentally did the same thing without knowing it... luckily I read the manual and it was all in there on how to turn it back on...
    Past: 99.5 A4 1.8TQ, 07 A3 2.0T
    Present: 09 A4 Avant 2.0T & 08 A3 2.0T S-Line
