Results 1 to 10 of 10
    Veteran Member Four Rings bong2611's Avatar
    2000 A6 AVANT, 2004 MBZ ML350
    Newark, Ca.
    Need help with spark plug wires
    I have a 97 2.8 12V. I just replaced the plugs. I had a hard time installing the last two spark plug wires on the passanger side. Is there a tool to grasp the wire to make sure its seated on the plug correctly? I can't get my hand near the plug because of all the metal hoses. How can I tell if the wires are seated correctly. Will I get a cell indication or something. The car seems to be running fine right now. I just want to make sure....TIA
    Newark, Ca.
    no help out there huh?
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    when you seat the coil pack on the top of the plug you should feel it kind of click into place that is when you know its in place. generally if you can screw it down it is in place as there is not many places for it to go.
    Newark, Ca.
    yah I just can't seem to get my hand situated to grab the wire and hear the it snap on to the spark plug. They seem to be on snug.
    Feb 13 2004
    <> Posts: 9913
    I didn't think the 12V 2.8 had coil packs? I'm not quite sure though.
    -Theodore Roosevelt, 1907
    Newark, Ca.
    I think i know what a coil pack is, i don't remember seeing one. Then again i could be wrong.
    Mar 02 2004
    Orange County
    you mean A4's have something else besides a 1.8T haha jk...i guess it would have helped if i had known it was a 12v
    Veteran Member Four Rings alen's Avatar
    May 10 2004
    1.8tqms
    ghettlanta
    yes, i remember all the headache at replacing those two wires. actually, just try to fit them in with your hand (i know that the clearing is very limited) but you will hear a quiet click and then try to pull the wire out. if there's considerable resistance then it should be all fine.
    Newark, Ca.
    thx
    Veteran Member Four Rings quattro30v's Avatar
    01' S2K | '98 A42.8Q | '04 C32
    you need to disconnect the intake pipe to get a good grip of the 2 rear plugs on the passenger side.... if your car is running fine and no backfires and surges, then you are fine.
    ... and yeah only 1.8s have coil packs, v6s use real ignition coils
    01 S2000 - Some Torque (IRTB, AEM EMS)
    98 Audi A4 - LOTSA Torque (GIAC)
    04 C32 AMG - HOLY SH!T
    04 Mini Cooper S - DINAN-S2 (daily driver)
    09 Ducati HyperMotard 1100 - crotch rocket
