Originally posted by dramaticstatic
I'd recomend a swirl mark remover like the stuff from 3M to fix the paint a little.
Just follow the directions and don't go crazy as the stuff is mildly abrasive but as long as you use an orbital buffer or something like that you should be fine.
Also the first two steps there don't need to be done every wash, only every 4-6 months to really remove all the gunk.
For the rest of the washes say every 2 weeks to a month just use a car wash soap that won't strip all the wax off of the paint.
It's not necesary to wash with dawn and claybar every time you wash the car because frankly it's an absolute pain and won't really net you any huge benifits. Only do it every so often to really clean the car.
Also keep a bottle of quick detail or similar prduct in your trunk along with a few towels. If you get anything major, say bird junk or some tree sap on your car you should get it off ASAP. Quick detail in the trunk is perfect for this.
It's also a good way to tell if the car needs wax. If the quick detail comes off easily without leaving any marks after a few wipes then the car is fine. When it starts to get difficult to cleanly remove then it's time to wax again. Or the whole water beading thing.
Oh and use a synthetic wax on the wheels every so often after a good cleaning, it will help them look shiny and will make sure that brake dust doesn't corrode them.
Use Vinylex on tires.
I agree, use Dawn only when you want to strip all wax off your paint.
Neoprufrok and Jumanji are the resident experts on this topic but this is what I do:
1) P21S or Eagle One Wet car wash. MF towel to dry
2) Claybar (Mothers, ClayMagic or Autopia)
3) Use Meguiars ScratchX to remove any scratches and 3M SMR to remove swirls (use terry or mf applicator, mf towel to buff off)
4) P21S Gloss Enhancing Paint Cleanser or S100 Shine Enhancing Cleanser (same product, different names) (mf applicator and towel)
5) Klasse AIO, wipeonwipeoff method (foam applicator, mf towel)
6) Klasse SG 2X very thinly, waiting 12 - 24 hours between coats to allow to cure, wiwo method, mf applicator and towel.
7) P21S or S100 wax (again, prolly same thing), foam applicator, extra soft/plush mf towel to buff.
Paint should look amazing and arm should fall off after this unless you have a porter cable. You'll need to do this only every 6-9 mos. Just apply wax every 3-4 weeks to maintain. Use Sonus carnauba, Mothers or Eagle One quick detailer after washing if you don't wax.
If you like the look of Klasse SG without wax (lighter colors), put on 3 or more layers and that'll last the whole 6-9 mos without any more applications. Use Sonus acylic spray detailer to renew shine after washing.
And like dramaticstatic says, Klasse AIO works great on wheels, Vinylex or 303 on tires and trim.
Sorry, lots of work and u have to be the obsessive/compulsive type to have a great looking paint finish.
