Results 1 to 17 of 17
    Veteran Member Four Rings buck's Avatar
    Feb 16 2004
    '05 Tacoma & '03 Yamaha R6 & '14 Yamaha FZ-09
    Simcoe County ON, Canada
    VDO is finally in!
    Well, finally got the boost gauge in. As you can see, I went with the VDO. It's a decent match, not perfect, but decent. It's pretty responsive. Haven't experienced the "buzz", but I did put the paper filter in-line when installed.
    Ran the boost hose though the trunk release cable grommet..... BIG mistake because after the first rainfall, my floor mat was wet. Seems that the area where I ran the hose sees much of the water drainage from the windshield. A little silicone seemed to solve that.
    With the APR 93 oct chip, it peaks just below 20psi and holds at around 16psi. I get about 22Hg's of vac at idle. Seems that the system is running fine.
    I did the Plexiglas center vent location as it's a nice balance in the interior. All in all, it took around 4hrs from start to after everything was buttoned back up and all tools put away. That also included the Plexiglas mount fabrication.... took a few trial fits.
    Fairly easy job all in all. Any half-arse'd do-it yourselfer can handle it.
    ONE CRAPPY THING ABOUT HAVING A BOOST GAUGE: you look at that damn thing more so than the road!
    APR 93 Octane Chip, VDO Boost Gauge, 710N, Koni C/O's, Carbonio CAI, High Flow Coconut air freshener.
    60% of the time, it works EVERY time.
    Registered Member Three Rings
    Jul 13 2004
    san diego
    looks good man
    one point eight tee
    Feb 13 2004
    <> Posts: 9913
    You should run the gauge line through the firewall via the ECU box. There's a rubber gromment there you can just poke a hole in for such a purpose.
    I was the same way, looking at the gauge all the time at first. That wears off after awhile.
    -Theodore Roosevelt, 1907
    Account Terminated Four Rings MR VTEC's Avatar
    98.5 Audi 1.8TQM
    Brooklyn
    how much does the vdo gauge go for?
    Feb 16 2004
    I did the install with no instructions in hand, tried going by memory. I hit a snag when trying to remove the ECU cover. Couldn't figure how to get to the screw on the back of the cover. For the life of me, I couldn't get the wiper cowl off. My freaking wiper arm wouldn't come off. That when I started looking for another location.
    Feb 16 2004
    It's around $35 or $40 US I believe. Sure beats paying $149 for the AWE one!
    The VDO and AWE ones are back-lit. I don't find that the side-lit gauges match well enough.
    EuroAddict (sp?) can get you the VDO gauge if you're looking.
    Feb 13 2004
    <> Posts: 9913
    I have the APR setup. Not the cheapest, but I love the look and how well in blends in with the interior, and looks stock.
    Feb 16 2004
    DDQ - your APR one does look very clean for sure. I almost picked that one up.... but when I found out that a piece of plexiglass only cost $2.49 - I went that route! Gotta save that extra cash for wings and beer
    GTA, Canada
    Definately nice, but I know you've got tricks up your sleeve to keep going with it. Soon it will blend perfectly.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Veteran Member Four Rings D Piddy's Avatar
    Feb 12 2004
    Me: 2010 B8 A4 S-Line In the Family: BMW Z4M, BMW 335xi, Range Rover Evoque, Honda Element
    Washington, D.C.
    it looks damn good. i went with the AWE but only bc it was a gift. if i'da had to pay for it, i woulda gone a different route
    Feb 13 2004
    <> Posts: 9913
    I definitely agree, it's a bit much to pay for a piece of plastic! But, I really liked it, and it was an impulse buy. I too like wings and beer. But, since I know longer live in upstate NY, I cannot find good wings ANYWHERE. I don't get why the rest of the country can't figure out how to make good wings. It's not that hard.
    Damn! Now I want wings.
    Feb 16 2004
    Ripple, I still want to play around with the mount for sure! Maybe if time permits this weekend I'll take it to step 2.
    I wish someone was nice enough to buy me a nice and pretty gauge mount.... but the plexiglass route is really simple and the results are decent also!
    DDQ.... I too now have a craving for wings! The better half works at a bar where they make awesome wings.... I try to get a pound in a couple times a month. I'll take a nice picture of them and post for you ;)
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Looks good man! We have the same interior.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Feb 16 2004
    Hmmmmmm..... you went with the red condom, eh..... I was wondering how it would look with the white backlit dash gauges.... I kinda wanted to keep the same dash theme color.
    The white on the VDO doesn't match our dash light perfectly though. But with the red condom, yours seems to match the lights in the center console really well.
    What to do.... what to do?
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Yeah I strated with the white light... but it's actaully got a yellow tint to it. If you can find a very light blue condom then that might fix it, but I tried the red and really liked it. Matches perfectly.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    GTA, Canada
    Oh the possibilities.
    That does look good all red. Wonder if you can get a better white bulb to help it match.
    Audizine
    Registered Member Three Rings awe4rings's Avatar
    Feb 18 2004
    Fairfield County, CT
    Wiper Cowl - Put wipers in 12 oclock position and turn 1/4 rotation on either screw, its comes off.
    ECU Box - As for the rear screw, I believe earlier models had a hole somewhere to fit an extension through on a ratchet. I have a 2000 and I just shimmed the rachet in there, careful not to drop the screw on removal, and it came out easily with a few cranks.
    -awe4rings
