Results 1 to 9 of 9
    Registered Member Three Rings BrokenXenon's Avatar
    Apr 28 2004
    Question about my IE 6.0 it's acting weird
    2 problems right now with my IE browser.
    whenever i click a "link" it doesn't open up a new window. it almost does, then it disappears very quickly. then on my 2nd click, it does open up a link.
    2nd problem is whenever i hit "back" button, it brings back the screen from the top of the screen. Not middle of the screen where i was.
    i have been trying to re install the IE but i failed.
    i need your help...
    Feb 13 2004
    <> Posts: 9913
    I'm not an expert, but I had similar problems.
    Do you have a pop-up blocker installed? If so, try uninstalling it.
    When I had my issues, I ended up having to reintall my entire OS. I tried everything, but I had problem whenever I tried to click a link that requested to spawn a new window. Everytime it would just pull a blank window, and then freeze up. But, if I'd right click the link, and copy and paste the URL in a new window, it would work fine. After endless headaches, and trying to reinstall IE a bunch of times, I just re-installed Windows, and that fixed it.
    But, word of advice: If you do reinstall your OS, make sure to back-up EVERYTHING. I didn't realize how much I missed when I did it. I lost lots of stuff I wanted.
    -Theodore Roosevelt, 1907
    Veteran Member Four Rings needforspd's Avatar
    Mar 05 2004
    Deceased 01.5 A4 1.8tm
    Sylmar Hills
    pop up blocker might cause the stopping of a new window
    2nd one happens some times w/ me too but not all the time
    Do you have a need for speed? Then drive it like you stole it!
    Registered Member Two Rings
    Feb 12 2004
    at the bar
    Use Firefox.
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Forget IE and use firefox
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Amen to firefox
    Feb 13 2004
    <> Posts: 9913
    Question: If I download and install FireFox, will it affect my IE? Meaning, can I just go back and forth between the two? Or will I have to first uninstall IE?
    Palo Alto, Ca
    I have both on my comp. I just dont use IE cuz it the crapola.
    Feb 13 2004
    <> Posts: 9913
    Cool. I just downloaded. Have you used the Thunderbird email client? I may try out that as well.
