Results 1 to 3 of 3
    Registered Member Two Rings Richard 350z's Avatar
    How wide can you go on B6 S4 ???
    I want to put wider wheels and tires on my '04 S4 sedan. Quesetions:
    1. What is the widest 18" wheel that will comfortably fit?
    2. What is the widest 18" tire that will fit without modification of the wheel well?
    3. How big a deal is it to modify the wheel well to accomodate a wider tire?
    4. Can I put wider tires on the rear? The owner's manual says no due to the awd system, but the 911 4S has awd and it runs much wider tires on the rear.
    Thanks.
    Richard
    2004 Audi S4 (B6)
    2004 Mitsu EVO RS
    __________________________
    "There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games."
    Ernest Hemingway
    Registered Member Three Rings C280 jr's Avatar
    May 12 2004
    Chicks Car
    Atlanta -LW
    i dont think that you would have problems fitting 265 tires in the back but i dont know about the front.
    Elvir
    dürtydübs
    clean cars, dürty people
    Veteran Member Three Rings DoubleAudi's Avatar
    Aug 03 2004
    Miami
    265/30/ in the rear and 225/35/ in the front and you shouldnt rub at all.
