Results 1 to 9 of 9
    Apr 12 2004
    2000 stgIII s4, 1997 jeep
    denver
    painted calipers
    hey.
    so i'm def painting my calipers, RED.
    what i am looking for is specific info as far as what type/brand of paint to buy and what i should do to make it look as dope as possible.
    i'm guessing just clean the calipers up and paint and wait and paint and wait and paint and wait, then tons of clear coat. ????
    did you have to remove the caliper assembly???
    if no, then is it hard to remove paint from the rotors, should i use brake clean???
    thanks fellas........
    Jul 20 2004
    Duplicolor makes a caliper paint you can get at Autozone or Advanced Auto. Also theres something i think G-Tech Caliper Paint which comes in more colors (both offer red)
    -From what i remember you do not HAVE to take your calipers off but i would to get a nice full coat and to be able to take em to a table and paint them instead of trying to in the wheel well
    -If you get any paint on your rotors.. a couple of braking times will clear em right up.
    Feb 10 2004
    2009 A4 2.0T Sedan
    Painted mine basic black awhile ago, it wasn't too difficult. Just a bit tedious if they're in bad shape (IE: rusty and dirty as hell). Used steel wool and a Dremmel to clean them up and ready them for the next step.
    It's best to take them apart so you can really get in there, as the prep work is maybe more important than the painting part. You can also mask off the rotor and surrounding area as needed.
    Don't recall what brand paint I picked up, just know that it was a high-temp engine paint. Didn't clear-coat mine and they're holding up just fine. A high-temp clear-coat would definitely be a good idea though.
    Veteran Member Three Rings quicksilver_S's Avatar
    City that never sleeps
    here is mine, just basic high temp paint. match the car pretty well wit rings.
    http://audizine.com/forum/showthread...threadid=13211
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    brake cleaner will take the paint off the rotor, as it would with the caliper.
    Registered Member Two Rings SilverA4Fun's Avatar
    Feb 18 2004
    2000 A4 1.8TQM
    Arlington, VA
    Just do it like this guy on vwvortex
    http://forums.audiworld.com/other/msgs/2467450.phtml
    Friends don't let friends drive stock.
    Mar 22 2004
    B6 S4 6MT
    Los Angeles, CA
    Foliotec high temp paint.
    Feb 23 2004
    2001 Audi S4 & 2004 Audi A4 Avant
    I used G2 two part epoxy paint.
    I worked great! now I'm selling the brakes...
    http://public.fotki.com/LI-S4/cars_a...018_small.html
    Registered Member One Ring Sam 325i's Avatar
    Jul 24 2004
    BMW
    Boston MA
    I recently did this to the stock brakes on an A4 with a friend.
    We simply removed the wheel, cleaned the caliper using Brakleen and a brush/towel.
    We then covered the wheel well with newspaper, teh brake rotor and other brake parts with a plastic trash bag btu ripped the bag to reveal only the caliper. Two coats of red Brake Caliper paint and let it dry for a half hour before putting the wheel back on.
    he says he is happy wiht it and from behind his stock 16" 5 spoke wheels it looks pretty good.
    all in all took about 3 hours for 4 wheels.
    Not sure how it will last in the long run, better off taking the caliper off if you're picky about it.
    -Sam
