Results 1 to 11 of 11
    May 20 2004
    More cars
    Never Land Ranch
    need help wierd noises
    Well i just changed my brakes and rotors and now this warning sign goes on (O). Along with that, the passanger side brakes sound like they are rubbing all the time. And the drivers side suspension is clicking as i brake. WTF. Here is all the info i can tell you....
    I got brake pads with out warnings, i'm not sure if that has anything to do with anything
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Veteran Member Four Rings sumpsfast's Avatar
    Apr 02 2004
    '92 UrS4 - Black
    Denver/Chi-town
    Well I beleive that light is your brake light. Maybe you forgot to re-plug the brake sensors back in?
    If the new pads are not the right fit, they will clunk.
    May 20 2004
    More cars
    Never Land Ranch
    UPDATE. The brakes i bought are the right fit they just don't have a sensor(do i need a brake with a sensor so the warning will goes away?) I fixed the clunking noise but the rubbing noise(brakes to pads) is still there, any ideas?
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Feb 13 2004
    <> Posts: 9913
    You can just wire it up to bypass it so it thinks you still have sensors.
    -Theodore Roosevelt, 1907
    May 20 2004
    More cars
    Never Land Ranch
    how?
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Feb 13 2004
    <> Posts: 9913
    I don't have these pads, but I'm quite sure it's just a simple circuit, with think wire running through the pad. That wire connects the two wires together to close a circuit, to send the signal that the pad is fine. Once it starts to wear down, it eventually wears out the wire, breaking the signal, which triggers the light on the dash. So, just find that connector, wire the two together, and it will close the circuit, and get rid of the dash light.
    Or, just deal with the light for now. Or just buy the pads with the sensor.
    May 20 2004
    More cars
    Never Land Ranch
    well i already efffed up, i cut the wires off that came from the sensor and so i can't, shit now i have to go buy more brake pads. I still can't get the F*CKING rubbing noise away
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Registered Member Two Rings greski's Avatar
    Jun 01 2004
    1998.5 Audi A4 1.8t Quattro, 2003 Audi Allroad Quattro
    Minnesota
    Correct me if im wrong, but the pads need time to created new grooves in the rotor. Having new rotors this might be a longer process. I think this might be where the noise is coming from. I have always been told to take it easy on new pads for about 100 miles.
    May 20 2004
    More cars
    Never Land Ranch
    i hope that this is the case, i drove about 50 miles already and the noise is getting better but still there. And as for the wear sensor, i clipped it off and now i'm fooked. I'm just going to buy new pads i guess
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Established Member Two Rings s1n3d's Avatar
    Oct 26 2004
    99 1.8tqt
    Nu YorK
    Howd u fix teh clunkin noise? i just put some new pads( well pepboys did) and i got the e-light and abs light go off on me for a good 6-7 seconds, hasnt come back but iget the clunking noise and like a screachin/draggin aginst metal noise when i step on the brake, this is like 350 miles after the pad isntall, the noise of the screechin new pads jus went away and this happens now. any help would be appreciated thnx
    Registered Member Three Rings A4ed's Avatar
    May 26 2005
    96' Audi A4 2.8
    Orange County
    I had terrible brake noise for the longest time, even while rolling slow it would rub loudly. Finally I just went to pep boys and spent $10 on some brake gel, and the noise almost completely went away.
    Audi A4 2.8m
    http://img378.imageshack.us/img378/803/sig25sn.jpg
    "Who needs a v12 when you've got a 12v"
    "To the Nürburgring or death!"
