Results 1 to 9 of 9
    Veteran Member Four Rings idrivemyself's Avatar
    Boxes 'n stuff
    Vancouver, WA
    Audi A3 Sportback Information: Long Version (Biggest 56k Warning EVAR!!!))
    Audi A3 Sportback: At a Glance
    - Newly designed five-door body with decidedly sporty, coupé-like design and generous amount of space for all occupants
    - Dimensions: Length 4286 mm, width 1765 mm, height 1423 mm, wheelbase 2578 mm. Luggage compartment 370 litres/1120 litres (front-wheel drive)
    - Engines:
    3.2 litre six-cylinder engine developing 184 kW (250 bhp), 320 Nm torque. 0-100 km/h: 6.3 s; top speed 250 km/h (governed)
    2.0-litre TFSI developing 147 kW (200 bhp), 280 Nm torque.
    0-100 km/h: 7.0 s; top speed 236 km/h
    2.0-litre FSI developing 110 kW (150 bhp), 200 Nm torque. 0-100 km/h:
    9.1 s; top speed 214 km/h
    1.6-litre FSI developing 85 kW (115 bhp), 155 Nm torque. 0-100 km/h:
    11.1 s; top speed 196 km/h
    1.6-litre engine developing 75 kW (102 bhp), 148 Nm torque. 0-100 km/h: 12.2 s; top speed 185 km/h
    2.0-litre TDI developing 103 kW (140 bhp), 320 Nm torque. 0-100 km/h:
    9.2 s; top speed 207 km/h.
    1.9-litre TDI developing 77 kW (105 bhp), 250 Nm torque. 0-100 km/h:
    11.7 s; top speed 187 km/h
    - Manual 5 and 6-speed gearboxes, alternatively 6-speed tiptronic
    - Direct Shift Gearbox DSG with twin clutch for 3.2 quattro, 2.0 TFSI and 2.0 TDI as optional extra:
    - Front-wheel drive; quattro permanent four-wheel drive as standard on 3.2 quattro; also available as optional extra for 2.0 TFSI
    - Suspension: McPherson front axle with triangular wishbones and four- link rear axle for sportily agile handling
    - Electromechanical steering with speed-dependent steering assistance
    - 16 or 17-inch wheels as standard
    - Three equipment lines: Attraction, Ambition, Ambiente
    - Standard equipment: including electric windows at front and rear, front seats with active head restraints, sideguard head-level airbag system, ESP
    Even my dishwasher is made by Bosch.
    I have Vag-Com and am happy to help... PM me for more info.
    Boxes 'n stuff
    Vancouver, WA
    Audi A3 Sportback: The Design
    Even when glanced fleetingly in the rearview mirror, the A3 Sportback is unmistakable: its front end is dominated by the striking single-frame radiator grille with the striking continuous chrome strip. The marked tapering of the sides and the dynamic shape of the clear-glass headlights give the face of the car that self-confident and thoroughly forceful character for which Audi is famous.
    The falling line of the silhouette towards the rear of the A3 Sportback, reminiscent of a coupé, picks up on the styling of its three-door counterpart. The roof arching gently to the rear binds the redesigned tail end neatly into the dynamic, road-oriented overall proportions.
    As well as the expansive additional rear door, the third side window is a characteristic feature of the new side view. This is where the lower and upper horizontal lines draw closer together, accentuating the coupé-like proportions. The optional roof rails, both subtle and striking, accentuate the styling highly effectively.
    With their bold contours, the round wheel arches appear to rest on foundations in the sills, which themselves are highlighted by the dynamic line. Large wheels of 16 or 17 inches in size (also 18-inch as an option) underline the impression of masculine athleticism and make the dynamic potential of the new Audi A3 Sportback clearly visible even when stationary.
    The visual centre of gravity of the A3 Sportback is thus to be found at its powerful, trapezoidal rear end, creating the impression that the entire car is about to leap forward. The rear end itself features an entirely new design, with its restrained use of styling lines and the clear, graphic division of surface areas.
    The geometry of the rear light units is likewise new. From their decidedly vertical orientation at the transition from the sides to the rear, they taper towards the centre of the vehicle. This emphasises the wide horizontal line below the window area and the low centre of gravity – a further visual indication of the Audi A3 Sportback's dynamism.
    As previously on the three-door model, there are one or two visible exhaust tailpipes hinting at the vehicle's power, depending on the engine version. And the rear lights high up at the back of the car accentuate the trapezoidal design of the rear end particularly at night, giving the new Audi A3 Sportback its powerful appearance from behind.
    The interior
    The interior design of the Audi A3 Sportback is distinguished by two features: sportiness and elegance. This impression is conveyed by the low seat position, in typical sports car style, the high centre console and the clear, expansive composition of the dashboard. The attractive appearance of the interior surfaces and of each individual detail is the result of select material quality and a perfect finish of the highest standard.
    The flush transition between the instrument panel and the door trim is again typical of Audi. The top shoulder rises subtly, tapering dynamically towards the rear. The trim strips, likewise tapered, emphasise the potent looks. The instrument cluster is housed within an almost round cover, an element that consciously echoes the design of other sporty Audi models such as the TT and the
    A4 Cabriolet.
    The new Audi generation of steering wheels is being introduced in the compact class for the first time with the Sportback. These three or four-spoke steering wheels can be recognised by their trapezoidal central element, the lines of which allude to the design of the single-frame radiator grille.
    Once again it is the design of all the details that makes the A3 Sportback a genuine Audi in every respect. To begin with, there are the car's ergonomics: the perfect position of the gear lever as well as the accelerator pedal in an upright position as on a sports car, and the clear contours of the instruments and controls with all the precision architecture of a chronometer.
    Superior ergonomic design is combined with equally outstanding aesthetic qualities throughout the car's interior: typical examples are the round air vents with aluminium surrounds, the rotary knobs of the automatic air conditioning also with metal edging rings, as well as the generous use of aluminium-look trim on the door and glove box handles, for instance.
    The trim inserts high up on the insides of the doors and rising to the rear provide a particularly dynamic note. Connecting the centre tunnel with the vertical plane of the console, two slender bars create an impression of particular lightness. It is no coincidence that this feature is reminiscent of a classic icon in modern automotive design, the Audi TT.
    Glancing through to the rear, the L-shaped rear head restraints enlarge the driver's field of view, a particular advantage when reversing into parking spaces.
    The Audi A3 Sportback builds on the successful equipment line concept of its three-door counterpart. There are three lines to choose from, each of them composed with engaging thoroughness:
    - The Attraction line full of character,
    - The particularly sporty Ambition line, and
    - The exclusive Ambiente line.
    In addition to the wheels and functional distinguishing features, these lines use different colours, with different types of upholstery, steering wheels and trim inserts. Just one example: whereas the trim inserts on Attraction models are in grain-structure, matt-painted plastic, on the sporty Ambition versions they have a black or blue piano finish; on the Ambiente, they are optionally in Vavona wood.
    Substantially more space
    A significant increase in the amount of space available for all occupants bears clear testimony to the substantial progress offered by the latest addition to the A3 generation. This applies even more to the Sportback than the three-door version, because its body has grown overall by 83 millimetres. The 68-millimetre longer tail end results in both more interior length and more space in the luggage compartment. The wide opening angle of the rear doors and the outstanding amount of leg room for a car in the compact class provide easy access to the rear seats.
    A fundamental comparison with the first-generation Audi A3 reveals that the 65 millimetre longer wheelbase is translated almost in entirety into extra interior length (+55 millimetres). And the greater width of the car (+30 millimetres) results in a significant improvement in interior comfort.
    Compared with the previous five-door A3, the rear passengers in particular benefit from substantially more knee room (+40 millimetres) in the A3 Sportback. And both rows of seats enjoy significantly more shoulder room (rear +29, front +35 millimetres).
    As well as the larger dimensions overall, many improvements in the car's design economy help to provide more interior space: the space-saving design of the handbrake lever with its Z-shaped mechanism provides sufficient space on the centre console for two additional drinks holders that are also easily accessible from the rear seats.
    All occupants benefit from easily accessible storage options, the driver and front passenger being able to use extra-large trays in the front doors and in the glove box, as well as numerous storage options on the centre console and the large storage area in front of the gear lever.
    The storage package available as an option comprises, inter alia, nets in the front-seat backrests, a storage compartment beneath the driver's seat, a net in the front passenger's footwell, and bag hooks with an additional net beneath the luggage compartment cover. A sun blind can be integrated into the load-area cover as an optional extra (standard for the Ambition). The optional sun blinds on the rear door windows are another new feature.
    The optional, folding centre armrest at the rear housing two cupholders and a storage box offers particular versatility. When folded down, it also provides a through-loading aperture with an optional, removable transport bag that can be used for example for carrying up to four pairs of skis or two snowboards.
    The luggage compartment of the Audi A3 Sportback is quite sufficient even for substantial transport requirements, providing a capacity of 370 litres with the rear-seat backrest in place and up to 1120 litres with the backrest folded down.
    Superior seating comfort
    The steering column adjustable for reach and height as well as the driver's seat with the same adjustment options ensure an optimum seating position for drivers of virtually any build.
    The ergonomic design of the standard front seats in the Audi A3 Sportback incorporates attributes that make for fatigue-free driving even over long distances, combined with good lateral support when taking bends with verve. For an even more overtly sporty form of driving, sports seats are available as an optional extra (standard on the Ambition model).
    The front seats are also available as an option with electric seat adjustment and an electrically adjustable four-way lumbar support for particular comfort around the occupant's back and effective prevention of any painful back strain.
    Boxes 'n stuff
    Vancouver, WA
    Audi A3 Sportback : Driving Pleasure in a New Guise
    A major new model is about to appear in the premium compact class.
    The A3 Sportback is characterised by the sporting elegance of a coupé and the versatility of a five-door vehicle, sophisticated technology and well-defined driving dynamics. With four and six-cylinder engines developing up to 184 kW (250 bhp), front-wheel or quattro permanent four-wheel drive and – as an option – the revolutionary Direct Shift Gearbox DSG transmission, the drive train and suspension live up to the expectations raised by the sporty exterior of this special five-door vehicle – driving pleasure in a new guise.
    The Audi A3 Sportback is deliberately going its own, new way in the compact class. It offers the emphatically sporty qualities and the athleticism of the three-door version with which it shares its drive train, dynamic suspension and wheelbase. At the same time – as well as two rear doors – it offers even more space and variability thanks to the fact that its body is a total of 83 millimetres longer than that of its three-door counterpart.
    Beneath the coupé-like roof, there are 370 litres of space (1120 litres with the rear seat backs folded down) for transporting all kinds of sports and leisure equipment and anything else the family might need: even two golf bags can be stowed sideways in the luggage compartment. The asymmetrically folding rear seat back, a standard feature, and the optional luggage compartment and storage packages provide plentiful scope for using this space precisely according to the personal requirements of every driver.
    This also applies to the three equipment lines: the distinctive Attraction, the sporty Ambition and the exclusive Ambiente equipment versions enable the customer to turn the A3 Sportback into their personal dream car.
    The large-area glass roof known as "open sky", which has been developed specially for the Sportback, gives occupants a clear view of the sky and can be opened wide if required.
    A new, extremely dynamic representative of the FSI engine family, which really brings the special qualities of the new compact Audi to the fore, is experiencing its world premiere in the A3 Sportback: the 2.0 TFSI, a four-cylinder unit with turbocharger and intercooler, delivers 147 kW (200 bhp). Its phenomenal torque of 280 Nm is available across a wide speed range from 1800 to 5000 rpm. The A3 2.0 TFSI Sportback in conjunction with the unique Direct Shift Gearbox DSG sprints from 0 to 100 km/h in just 7.0 seconds, and on to a top speed of 236 km/h.
    Boxes 'n stuff
    Vancouver, WA
    Audi A3 Sportback: Engine and Transmission
    A six-cylinder engine, FSI petrol direct injection versions, the world's only turbocharged FSI and high-torque TDI engines with high-pressure pump-injector fuel injection, Direct Shift Gearbox DSG with twin clutch, 5 and
    6-speed manual gearboxes, an innovative 6-speed tiptronic automatic transmission and quattro permanent four-wheel drive:
    Offering a wide range of choice but dedicated throughout to sporting performance – this philosophy characterises the range of engines and transmissions offered for the new Audi A3 Sportback at launch. All engines have a further quality in common: they all undercut the limit values laid down in the EU4 standard.
    The range of engines at a glance:
    3.2 six-cylinder engine developing 184 kW (250 bhp), 320 Nm
    2.0 TFSI developing 147 kW (200 bhp), 280 Nm (new)
    2.0 FSI developing 110 kW (150 bhp), 200 Nm
    1.6 FSI developing 85 kW (115 bhp), 155 Nm
    1.6 developing 75 kW (102 bhp), 148 Nm
    2.0 TDI developing 103 kW (140 bhp), 320 Nm
    1.9 TDI developing 77 kW (105 bhp), 250 Nm
    The petrol engines
    The 3.2 six-cylinder engine
    The highest-performance engine for this model, and also the top petrol engine for the A3 Sportback: the four-litre V6 engine with a displacement of 3.2 litres.
    The six-cylinder engine is particularly suited to a distinctly sporty vehicle such as the Audi A3 Sportback thanks to its outstanding torque and power characteristics.
    Its maximum output is 184 kW (250 bhp), and the torque range is particularly impressive, peaking at 320 Nm between 2500 and 3000 rpm.
    This is just perfect for powerful pulling at all speeds as well as nimble acceleration – regardless of whether the driver opts for a 6-speed manual gearbox or the new, sporty Direct Shift Gearbox DSG.
    The performance figures of the A3 Sportback 3.2 quattro with Direct Shift Gearbox DSG are correspondingly impressive: it accelerates from 0 to 100 km/h in just 6.3 seconds and reaches a top speed of 250 km/h (governed).
    Throttle valve actuation is designed for an exceptionally agile, spontaneous engine response to accelerator pedal movements. Indeed, particularly the interaction of the engine with ultra-fast, precise control of the Direct Shift Gearbox DSG creates an entirely new sensation of power and performance on the road.
    The DSG transmission control exhibits its particularly sporty character in the active throttle blips during downshifts in the selector lever position S and in the manual gate.
    The dual-branch exhaust system both helps to cut emissions and makes a very presentable sound. Audi's acoustics specialists have created a sonorous sound which, without ever becoming excessively assertive, is entirely appropriate to the sporting potential of this power unit.
    The A3 Sportback 3.2 is equipped with quattro permanent four-wheel drive as standard.
    The 2.0 TFSI
    The engine range of the new Audi A3 Sportback marks a double "world first": the 2.0 TFSI is not merely an entirely newly developed engine, but the first ever production engine to combine turbocharging with the FSI concept of petrol direct injection.
    This combination has already emphatically demonstrated its potential in the world of motor racing: the Audi R8 models with turbo FSI engines are notching up victory after victory on the circuit and recorded already their fourth triumph at the Le Mans 24 Hours in June 2004.
    The term "petrol direct injection" highlights the very revealing feature which distinguishes these engines from conventional petrol engines. In contrast to the manifold injection principle, the fuel is injected directly into the combustion chamber.
    The injector, located on the admission side in the cylinder head, is served by a high-pressure pump driven by the camshaft and a pressure reservoir shared by all cylinders - the common rail system. The injector controls the injection time to within thousandths of a second at injection pressures of up to 110 bar. By way of comparison, a manifold injection system operates at a maximum of four bar.
    The design of the four-cylinder turbo FSI is based on the 2.0 FSI naturally-aspirated engine, with which it shares key dimensions such as the cylinder spacing of 88 millimetres, as well as having the same cylinder head and crankshaft drive. On the other hand, a great many components have been adapted to reflect the substantially higher operating pressures and also the higher dynamic load of the turbo engine.
    The engine block is made from GG 25 grey cast iron, a material that exhibits both high pressure resistance and excellent acoustic properties.
    A mass balance transmission further improves the acoustics. Two balancing shafts rotating at double the speed of the crankshaft compensate for the engine's inertial forces. The power is transmitted by the crankshaft by means of a triangular-layout chain which drives the oil pump as well as the balancing shafts.
    The outcome of these measures is outstanding vibrational properties for a four-cylinder engine. Perceptible vibration and drumming frequencies under load are both effectively suppressed. The pleasing sound of the specially tuned exhaust system aptly complements these properties.
    The intake manifold on the 2.0 TFSI is made from a high-tech plastic. It also integrates the charge movement flaps, the position of which is adjusted by a continuous-action pilot motor. The optimum movement of the airflow, or tumble, can thus be controlled on the basis of the engine-speed and load conditions.
    The fuel is injected via a common rail system supplied by a demand-controlled high-pressure pump. The fuel is injected directly into the combustion chamber via an injector positioned at one side between the inlet valves.
    In contrast to the naturally-aspirated 2.0 FSI engine, the fuel-air mixture is distributed purely homogeneously within the combustion chamber. This provides a distinctive characteristic placing the emphasis on high performance and agile responsiveness at all engine speeds.
    The four-valve cylinder head with low-friction roller cam follower drive has a modified inlet duct geometry that produces even higher tumble values than the naturally-aspirated FSI engine. This results not only in greater refinement, but also in superior knock resistance and therefore efficiency.
    The result is that the turbo engine achieves a compression ratio of 10.5:1, a figure that is otherwise achieved only by modern naturally-aspirated engines. This, coupled with the advantages of petrol direct injection, plays a crucial role in boosting the thermodynamic efficiency compared with both manifold injection engines and conventional turbo engines: whereas the swept volume in the Audi A3 is just 10 percent higher than that of the predecessor version, the 1.8 T, the torque has risen by all of 20 percent to 280 Nm.
    This figure is available from as little as 1800 rpm, all the way up to 5000 rpm. This exceptionally broad torque plateau on the one hand permits a fuel-efficient driving style with few gearshifts, and on the other hand means that only light accelerator action is needed to produce assertive thrust and a spontaneous unleashing of power.
    This technology lends the A3 Sportback 2.0 TFSI flexibility values that are on a par with much larger-capacity sports cars: in 4th gear, the mid-range spurt from 60 to 120 km/h that is typically required for overtaking manoeuvres takes just
    5.4 seconds. The predecessor accomplished this in 6.8 seconds, thus taking around 20 percent longer.
    It is moreover impressive how spontaneously the new turbo engine always responds to accelerator action, and how assertively it translates pedal movement into acceleration. This too can be expressed in figures. Immediately after the throttle has been opened, the 2.0 TFSI summons up around 15 percent more basic engine torque than the 1.8 T, and torque rises to its maximum value much more rapidly: the new turbo FSI reaches the predecessor's peak torque in just half the time – and then goes a significant step further in reaching the maximum value of 280 Newton-metres.
    The A3 Sportback 2.0 TFSI with DSG gearbox accomplishes the classic 0-100 km/h sprint in only 7.0 seconds; its powerful 147 kW (200 bhp) engine is capable of taking it up to a top speed of 236 km/h.
    The new engine's efficiency is reflected by its remarkably low fuel consumption, for all its high performance. Its average consumption over 100 kilometres is just 7.7 litres of premium-grade petrol.
    The Audi A3 Sportback 2.0 TFSI is available both with front-wheel drive and the sporty Direct Shift Gearbox DSG, and with quattro drive and a manual 6-speed gearbox.
    The 2.0 FSI
    The two-litre naturally-aspirated engine likewise has petrol direct injection: a common-rail fuel injection system and a single-piston high-pressure injection pump supply the engine with fuel.
    The four valves per cylinder are actuated by low-friction roller cam followers. The intake camshaft can be continuously adjusted. The 2.0 FSI in the Sportback develops 110 kW (150 bhp) and maximum torque of 200 Nm at 3500 rpm. With this kind of power, the Sportback 2.0 FSI with six-speed manual gearbox accelerates from 0-100 km/h in just 9.1 seconds and has a top speed of 214 km/h.
    But its noteworthy efficiency is just as typical of an FSI engine as its sportiness. Because in view of the performance figures achieved, an average consumption of just 6.9 litres of Super Plus petrol per 100 kilometres (overall) is more than impressive.
    Thanks to a variable intake manifold and dual-branch front pipe, its torque curve sets standards in this class. This progress has been made possible by the air-guided combustion process of the 2.0 FSI engine. It allows stratified and homogeneous lean operation with excess air at part load.
    During stratified-charge operation, the FSI engine's most economical mode, fuel is not injected until the compression phase, and is then transported to the spark plug by the air turbulence produced in the combustion chamber. This causes an ignitable mixture to form around the spark plug, with a substantial air surplus in the remainder of the combustion chamber.
    At full load and at high part loads, this FSI engine also operates in the homogeneous mode.
    The A3 Sportback 2.0 FSI is available in combination with a 6-speed manual gearbox and with 6-speed tiptronic.
    The 1.6 FSI
    The third version of four-cylinder engine with FSI petrol direct injection, developing 85 kW (115 bhp) and 155 Nm torque, makes the A3 Sportback 1.6 FSI an economical sprinter.
    This propels the dynamic five-door model up to a top speed of 196 km/h; the speedometer needle hits 100 km/h after 11.1 seconds. But this four-cylinder engine has more than just sporting talents to recommend it.
    The 1.6-litre FSI engine also demonstrates potential for fuel economy thanks to its petrol direct injection technology. The A3 1.6 FSI consumes just 6.5 litres of Super Plus fuel per 100 kilometres, pushing the figure down to a remarkable 5.3 litres per 100 km in extra-urban conditions.
    This is undoubtedly an unbeatably low figure for a petrol engine, considering its performance. The 55-litre fuel tank means that a range of considerably more than 800 kilometres is possible without pauses for refuelling.
    One special feature of FSI technology is to be found at the admission end – the tumble flap. This can be adjusted to two different positions on the 1.6 FSI engine, thus specifically influencing the movement of the incoming air.
    This paves the way for two different operating modes as the very basis of the FSI principle's versatility: homogeneous-charge and stratified-charge operation. Depending on the engine speed, load status and accelerator pedal position, the engine electronics always select the optimum mode – without the driver even noticing.
    The 1.6
    The entry-level engine for the A3 Sportback is the well-established 1.6-litre four-cylinder power unit with variable intake manifold and overhead camshaft. With its engine block made of aluminium, this power unit is at least 13 kilograms lighter than a grey cast-iron engine of the same size.
    The valve operation by means of roller cam followers results in particularly low internal friction. The other engine components are also optimised for minimum friction in the interest of enhanced fuel economy.
    The result is that in conjunction with the 1.6-litre engine and 5-speed manual gearbox, the Audi A3 Sportback uses only 7.1 litres of premium-grade fuel per 100 kilometres (overall).
    For all its economy, the A3 Sportback 1.6 is decidedly nimble. Thanks to an engine output of 75 kW (102 bhp) and a torque of 148 Newton-metres, with the
    5-speed gearbox it accelerates to 100 km/h in 12.2 seconds and achieves a top speed of 185 km/h. Its responsiveness and acoustic refinement are further arguments in favour of this ultramodern drive version: an ideal basis for the Audi A3 Sportback.
    The A3 Sportback 1.6 is initially available in combination with a 6-speed tiptronic, with a 5-speed manual gearbox to follow shortly afterwards.
    The TDI engines
    The 1.9-litre TDI
    One of Audi's most successful and popular engines is also to be found in the A3 Sportback: the four-cylinder 1.9-litre TDI with pump-injector direct injection. The latest version develops 77 kW (105 bhp) and produces an impressive 250 Newton-metres of torque at just 1900 rpm.
    The A3 1.9 TDI takes just 11.7 seconds to accelerate to 100 km/h. And with a top speed of 187 km/h, the entry-level TDI model is the ideal car for long stretches on the motorway at high average speeds. Especially as the fuel consumption of around only 5.1 litres per 100 kilometres means that a distance of over 1,000 kilometres can be covered between stops for refuelling.
    This once again demonstrates the superior maturity and efficiency of TDI technology in conjunction with the pump-injector unit. Indeed, this system is still able to provide the highest level of injection pressure of up to 2,050 bar – the weight of a car on an area as small as a fingernail.
    This high pressure assures ultra-fine atomisation of fuel within the combustion chamber, thus providing excellent thermodynamic efficiency. On the road this means outstanding fuel economy and, at the same time, a high torque yield. And thanks to pilot-injection control, the performance spectrum of a pump-injector engine includes good engine acoustics and efficient emissions control. This likewise applies to the 1.9 TDI, which easily undercuts the EU4 emission limits.
    The A3 Sportback 1.9 TDI comes in combination with a five-speed manual gearbox.
    The 2.0 TDI
    There can be no doubt about it: the 2.0-litre TDI which Audi is also offering for its A3 Sportback has all the virtues of its smaller brother – high power output, superior fuel efficiency and low emissions.
    Being the first TDI with a four-valve cylinder head, however, this new engine offers an even better interpretation of these qualities. Maximum output of 103 kW (140 bhp) and peak torque of 320 Nm available all the way between 1750 and 2500 rpm make this the most powerful and dynamic four-cylinder diesel featured by Audi so far. Performance on the road is correspondingly impressive, the front-wheel-drive 2.0 TDI with DSG accelerating to 100 km/h in just 9.2 seconds and continuing up quickly to its top speed of 207 km/h.
    Two other key strengths of the new 2.0 TDI are low fuel consumption – 5.5 litres of diesel fuel per 100 km (overall value) – as well as compliance with the EU4 emission standard.
    In terms of design, the new power unit is distinguished from its related 1.9-litre version not only by its larger capacity, but above all by the new cylinder head with four valves per cylinder. The crossflow cylinder head with two tangential intake ducts on either side and a twisted valve star assures an optimum combination of swirl and cylinder charge.
    Two overhead camshafts and low-friction roller-type followers with hydraulic valve-play compensation help to optimise the valve management process. The pump-injector units, in turn, are operated by roller cam followers running on the exhaust camshaft.
    The A3 Sportback 2.0 TDI is immediately available with front-wheel-drive in conjunction with a 6-speed manual gearbox, or with the Direct Shift Gearbox DSG.
    The Direct Shift Gearbox DSG
    The revolutionary Direct Shift Gearbox DSG combines the advantages of a conventional 6-speed manual gearbox with the qualities of a modern automatic, resulting in a superior drive concept. The driver benefits from enormous agility and driving enjoyment, with acceleration that is as smooth as it is dynamic, characterised by uninterrupted traction. This is combined with good economy thanks to low fuel consumption, and convenient operation.
    The basis for this new development is a three-shaft six-speed manual gearbox which offers considerable variability in the selection of the transmission ratio. Thanks to the use of a twin multi-plate clutch with ingenious electro-hydraulic control, two gears can be engaged at the same time.
    So how does DSG function? When driving, one gear is engaged. When the next gearshift point is approached, the appropriate gear is pre-selected but its clutch kept disengaged. The gearshift process opens the clutch of the activated gear and closes the other clutch at the same time with a certain overlap. The result is that the gear change takes place under load, and a permanent flow of power is thus maintained.
    Incorporating optimum gearshift strategies, the control logic integrated in the transmission provides instantaneous, comfortable and smooth gearshifts virtually free of any jolts or judder. And by moving the gear lever in the manual gate or operating the standard-fit shift paddles behind the steering wheel as in a racing car, the driver can actively influence the choice of gears and the gearshift point at any time.
    In the automatic mode, the driver can shift to the ultra-sporty S program in which upshifts are significantly retarded, downshifts advanced and the shifting process accelerated. A one-touch function accessed via the shift paddles on the steering wheel in addition temporarily calls up the manual mode, even in automatic modes D and S.
    The 6-speed tiptronic
    A 6-speed automatic transmission is still more the exception than the rule in the premium compact segment, yet it brings the driver palpable advantages compared with 5-speed versions. This is because the benefits of the greater spread of transmission ratios – 6:1 instead of the previous 5.5:1 – are not limited simply to superior operating economy.
    As well as lower engine speeds in sixth gear helping to reduce fuel consumption and engine noise at high speeds, the shorter transmission ratio in first gear provides even more spontaneous "bite" and agile dynamics when accelerating.
    Combined with the Dynamic Shift Program DSP, the six-speed tiptronic is a genuine all-rounder not simply in subjective terms and in the motoring pleasure it offers the driver. This automatic transmission, which first appeared on the Audi TT in 2002, is also notable for its compact design and low weight.
    As well as the standard driving program D which places the emphasis more on economy, the 6-speed tiptronic has the ultra-sporty S program. In this program, the engine speeds at which the transmission shifts up are not only higher; the sport program avoids undesirable upshifts, for more harmonious driving at speed along winding roads.
    A second shift gate has been added for extra ease of operation in the automatic mode, allowing the driver to select the speed manually if desired. And if the car is fitted with a multifunction steering wheel, the driver can also change from one driving mode to another simply by pressing the thumb-operated shift paddles .
    The Dynamic Shift Program DSP provides extra drivability and comfort. It identifies different driving styles and determines the optimum gearshift point for every driver and driving situation.
    On the Audi A3 Sportback quattro, a hydraulic multi-plate clutch varies the distribution of power between the front and rear wheels. This technical solution is indeed particularly suitable for cars with the engine fitted transversely, incorporating all the well-known advantages of an Audi quattro.
    Offering permanent, situation-specific distribution of drive forces to all four wheels, quattro drive guarantees maximum traction and, as a result, optimum acceleration at all times. At the same time there are still ample reserves for transmitting cornering forces in the interests of directional stability and cornering safety.
    The heart of this sophisticated drive system is the multi-plate clutch fitted between the driveshaft and the rear differential. A package of plates running in an oil bath within the clutch housing can be pressed together by controlled hydraulic power, thus providing variable torque distribution between the front and rear axle.
    The more pressure is able to build up on the multi-plate clutch, the more drive torque can be transferred to the rear axle. The electronically controlled system responds instantaneously to any change in traction. And with its own oil supply featuring two axial-piston pumps quickly building up pressure, the clutch is able to intervene as required when the difference in rotating angles between the front and rear axle is as little as 45 degrees.
    Power is distributed not according to a predetermined characteristic, but rather individually as a function of mechanical conditions, using both hydraulic and electronic signals. A data link provided by a CAN bus, that is an electronic data line, serves to register and evaluate a wide range of data fed in by other sensors and control units. The electronics control the clutch pressure, and thus the power transmitted in any given driving situation, via a control valve.
    To this end, the control unit uses all kinds of information such as wheel and engine speed, road speed and engine torque. At the same time the system "learns" all about the driving situation and the driver's current preferences.
    Boxes 'n stuff
    Vancouver, WA
    Audi A3 Sportback: Body
    Like its three-door counterpart, the five-door Audi A3 Sportback is a paragon of what is possible in a modern steel body. It combines a high degree of rigidity – and therefore excellent vibrational comfort – with excellent occupant cell stability and efficient weight-saving design.
    This synthesis is made possible by the specific use of high-strength and ultra-high-strength body panels, tailored blanks (where the thickness varies within the panel itself) and the most advanced and sophisticated joining technologies. High-strength and ultra-high-strength steel components account for over 60 percent of the Sportback's panels.
    The result is lower weight coupled with superior rigidity. And although the previous A3 was most definitely one of the best cars in its class in terms of body rigidity, the new model offers an overall improvement in dynamic flexural and torsional rigidity. A sound basis for high passive safety as well as outstanding acoustic and vibrational comfort.
    Excellent vibrational comfort
    A high level of local and overall dynamic rigidity in the body of the car is essential to superior vibrational comfort. The objective is to keep vibration amplitudes to a minimum at all points of the car that are relevant to comfort, such as the footwells, the area beneath the seats, and the area around the steering wheel.
    The body-in-white of the A3 Sportback plays a significant role in achieving this goal. Cross-sections designed to cope with varying loads, consistently uninterrupted profiles throughout the body, and optimised structural intersections all combine in providing an optimum all-round concept. Tailored blanks are used on the body to guarantee efficient use of materials.
    Modern adhesive is also used in conjunction with welding spots and laser seams together with spot-welded connections to assure firm connections between the individual components. More than three metres of laser seams serve to connect the roof and the side frame alone.
    Integrated assembly components such as the hybrid front end, aluminium subframes and an aluminium cockpit support integrated in the overall structure of the body serve to enhance all-round body rigidity to an even higher level.
    Stable structures for passive safety
    A high standard of occupant safety is one of the obvious goals in developing an Audi – this applies equally to head-on, side or rear-end collisions, as well as to passenger safety in a rollover.
    The Euro-NCAP crash striking a deformable barrier at 64 km/h and with 40 per cent overlap of the front end is an important criterion for determining the safety of a car in the most common type of accident, a head-on collision. The structure of the Audi A3 Sportback is protected in such a case by a multi-chamber aluminium cross-member with deformation elements positioned slightly further back.
    Interacting with the longitudinal arms or "chassis legs", as they are often called, the bumpers correspondingly absorb energy acting on the forward structure, to relieve the load on the passen-ger cell and, in particular, the footwells.
    This effect is supported by the aluminium subframe bolted to the front of the car at six points, spreading out forces efficiently throughout the extra-strong floor and tunnel structure.
    Within the passenger compartment, the exact coordination of all restraint systems as well as the kinematic action of the steering column and pedals keep forces acting on the occupants to a minimum. Two-stage full-size front airbags for the driver and front passenger as well as belt tensioners and belt-force limiters reduce the forces acting on the occupants' bodies in a head-on collision. Special padding on the steering column and in the footwells as well as the foot rest and the bottom-hinged accelerator pedal protect the driver's lower extremities, particularly the sensitive ankle and knee joints.
    In a collision from the side, the occupants of the Sportback benefit from the particularly rigid structure of the bodyshell. A homogeneous contour and cross-sectional design assure a deformation characteristic that minimises the load on the occupants, especially in the area of the B-post and sill.
    The central sill profile prevents any major deformation and, together with the extra-large seat cross members, provides very good support. This is particularly helpful under very substantial local loads, in a pole impact for example.
    In the doors, hybrid carrier systems consisting of aluminium impact members with bolted-on steel aprons assure additional safety. In a side-on collision the carrier system rests on the sill along its full length, thus transmitting forces to the lower structure of the car with maximum efficiency.
    Inside the car, side airbags enhance safety. The sideguard head airbag system, which covers almost the entire window area from the A-post to the D-post and thus significantly enhances protection for the occupants against harsh impact between the head and objects outside the car, is standard in all Audi A3 models in Western Europe.
    With the airbags being rapidly filled by a hybrid gas generator and maintaining their pressure for a protracted period, passenger safety is assured rapidly and consistently, with ample safety potential also in secondary collisions.
    A comprehensive sensing system with a total of six satellite crash sensors on the B- and C-posts and in the front-end support serves to activate the restraint systems with the same standard of efficiency. This ensures on-demand detection of accidents, with the occupants being efficiently protected by decelerating together with the car itself.
    Over and above these benefits, the crash sensors in the Audi A3 Sportback offer additional safety in an accident by opening the central locking, switching on the hazard warning lights and interrupting the supply of fuel to the engine.
    Active head restraints in the front seats reduce the risk in a rear-end collision. Activated mechanically, they move forward whenever required to reduce the gap with the occupant's head as rapidly as possible.
    The compact Audi is also protected with maximum efficiency against the effects of an impact from the rear at higher impact speed. Indeed, the A3 Sportback already meets the requirements of future standards. In other words, it withstands impact with a deformable barrier at 80 km/h and 70 percent overlap. The passenger compartment and fuel tank are located outside the primary deformation zone in this test constellation. The entire rear structure of the car undergoes deformation according to a defined pattern with the aid of extra-large support arms, and thus absorbs impact energy for extra safety.
    Fine-tuning in the wind tunnel
    A longer wheelbase and wider track as well as greater overall length and width than the predecessor, coupled with wider basic tyres: these modified dimensions produce a completely new aerodynamic profile for the new Audi A3 Sportback.
    The number one challenge in designing the car was to maintain the very good drag coeffi-cient despite the larger frontal area.
    The most significant change made to this end was the fine-tuning of the underfloor, with its full panel extending from front to rear. Developing this kind of aerodynamic cover was of course the ideal task for Audi's wind tunnel in Ingolstadt, with the simulation of ground effect conditions provided by belts running beneath the car, to permit highly realistic assessment of air flow below.
    A spoiler fitted on the lower edge of the front bumper serves to guide the flow of air entering the underfloor area efficiently. Spoilers on all four wheels ensure that the airflow to the wheels and brake system is controlled ideally and that the brake discs are simultaneously kept largely clear of dirt.
    Two large underfloor panels around the middle of the car maintain a smooth flow of air with virtually no turbulence. So-called heel-plate spoilers on the panel's rear edge then block the flow of air beneath the body so effectively that the air flow at the car's rear end is favourably altered.
    With its drag coefficient of 0.32, the new A3 Sportback again offers advantages in terms of performance, driving dynamics and fuel economy.
    Boxes 'n stuff
    Vancouver, WA
    Audi A3 Sportback: Running Gear
    The second key to the new Audi A3 Sportback's excellent dynamics on the road is its highly effective suspension with McPherson strut layout at the front and the new four-link independent suspension at the rear.
    The dynamic suspension is designed for sporty, agile handling with a high standard of stability, and providing very good handling in bends with both front-wheel and quattro drive. An additional forte is the high standard of ride comfort, as befits a car in a segment further up the range.
    16 or 17-inch wheels (17-inch wheels are standard on the Ambition models) enhance the car's performance on the road and add a clear sporting touch. 18-inch wheels by quattro GmbH are available as an option. The performance of the engines is reflected by the equally powerful brake system with large-diameter brake discs.
    The electromechanical steering with speed-dependent power assistance is one of the keys to optimum handling. It combines optimum steering feedback with minimal sensitivity to excitation from the road surface, and operates on far less energy.
    Driving dynamics and superior comfort all in one
    The dynamic character of the Audi A3 Sportback is palpable. It is manifested not simply by the precise directional stability that benefits from the longer wheelbase. The Sportback also provides a compelling steering response, the initial subjective impression being confirmed immediately by its exemplary precision in following every movement of the steering wheel, every bend in the road. The Sportback comes across as easy to handle, agile and highly responsive on bends.
    Throughout all of these manoeuvring processes, any movement of the car's body remains strictly within limits even on bumpy roads and in bends, and does not influence the car's driving characteristics. The self-steering behaviour remains neutral right up to a very high handling limit, which signals itself to the driver through slight understeering.
    The driving characteristic is thus overtly dynamic, but nevertheless accompanied by a high degree of comfort. The Audi A3 Sportback's suspension responds discriminatingly, absorbing surface impact at any speed. The steering, too, remains unerringly calm even on bumpy surfaces, consistently providing a good feel for and contact with the road.
    The rear suspension
    The rear suspension critically determines the dynamic driving characteristics and stability of a vehicle. To achieve an even more pronounced sports character, the developers decided to adopt a new axle design for the current A3 generation. They opted for the four-link principle, which combines the benefits of compactness, low weight and above all superior handling.
    The particular strengths of the four-link suspension layout stem from the functional separation of longitudinal and transverse forces. This provides a high standard of lateral rigidity in the interests of optimum dynamics and driving safety and, at the same time, makes the suspension relatively soft lengthwise in order to improve the standard of ride comfort.
    On each side the suspension incorporates a wheel carrier with a wheel bearing unit, two lower wishbones (spring link and tie rod), one upper wishbone and a trailing arm.
    The three wishbones are connected to the car body by a subframe. This structure on the front-wheel-drive A3 Sportback is made of extra-strong steel tubes and plates and is bolted firmly to the body, forming a complete unit that helps to save weight, while simultaneously reinforcing the rear end of the car. The rear axle subframe on quattro models serves additionally to accommodate the final drive and is made of aluminium for even further weight reduction.
    Separate springs and shock absorbers provide the necessary vertical support. The twin-tube gas-filled shock absorbers are fitted very close to the wheels, permitting a particularly generous through-loading width in the luggage compartment. The anti-roll bar is mounted on extra-firm rubber/metal mounts fitted to the axle subframe, efficiently reducing body sway and helping to improve the transmission of lateral forces and, accordingly, the handling of the car.
    The front suspension
    An extensively acclaimed layout principle has been used for the front suspension: McPherson front axle with triangular lower wishbones. Here, the subframe is bolted to the forward structure. The anti-roll bar is mounted directly on the spring strut. The correspondingly more direct transmission results in greater responsiveness, with the result that the anti-roll bar itself can be kept more compact. This allows the weight of the front suspension to be cut by a further
    1.6 kilograms.
    The kinematic configuration of the front axle, in conjunction with the design and configuration of the rubber mounts, helps to produce neutral handling, with slight, always predictable understeering not occurring until the car reaches its limit of handling.
    The front wishbone mount is extra-firm, to provide good lateral support. The rear wishbone mount, in turn, has a non-linear characteristic, assuring very good ride comfort under minor loads and controlled self-steering behaviour as forces increase.
    The steering
    There are many impressive advantages to the electromechanical steering: unlike conventional power steering systems, it only consumes energy when steering actions are actually being performed. This means a fuel saving of up to 0.2 litres per 100 kilometres, depending on driving conditions.
    Sensors monitor steering forces and the speed at which the driver is turning the steering wheel, applying this data to calculate the power assistance required, which is then built up by an electric motor and transmitted via worm gearing directly to the pinion in the steering system. Another crucial factor in determining the level of servo assistance is the speed at which the car is travelling.
    In practice this means maximum ease of steering when parking the car, with the driver then registering a more sensitive response and active steering feel as road speed increases.
    The system also makes it possible to dampen bumps from the road surface effectively. Another innovation is the active return travel of the steering with intuitive zero point. Lateral incline in road surfaces and constant side winds thus no longer impair the vehicle's directional stability.
    Brakes and wheels
    The brake system of the Audi A3 Sportback is a match for the vehicle's dynamic talents. Four disc brakes, of varying sizes depending on the engine version, provide safe, dependable deceleration. The top-of-the-range 3.2 quattro even comes with a 17-inch brake system that sets a new standard in this segment. On the front brakes this means a disc diameter of no less than 345 milli-metres.
    The Audi A3 Sportback is also the pioneer in its class when it comes to operation of the brakes. The compact premium sports car has the feature introduced latterly on the Audi S4 of a dual-rate brake servo. In normal conditions, it allows the braking force to be dispensed very responsively, with an amplification rate of 1:5.
    When the driver applies the brakes in an emergency, however, the brake servo, on sensing a pre-defined braking pressure, switches to a higher support factor of 1:8.5.
    An Electronic Stabilisation Program of the latest generation, ESP, assures active safety reserves at all times. This control system incorporates the anti-lock braking system ABS, electronic brake-force distribution EBD, the traction control system ASR and the engine drag torque control system MSR, the electronic differential lock EDL, hydraulic brake assist and the extended stability braking system ESBS.
    The enhanced control algorithm in the electronic control unit now enables ESP to recognise potentially critical situations at an even earlier point in time, intervening preventively whenever necessary.
    With its self-learning capacity, ESP consistently monitors the car even in stable driving conditions, thus constantly adjusting the intervention point to the current driving situation on the road. This benefits both safety and ride comfort. ESP can intervene much earlier in critical situations and, on the other hand, prevents unnecessary actions.
    The Attraction and Ambiente versions of the Sportback come as standard with 16-inch wheels running on 205/55 R 16 tyres. The Ambiente models have cast aluminium wheel. The ultra-sporty Ambition Sportback versions are equipped with sports suspension and 17-inch cast aluminium wheels with 225/45 tyres. This combination not only looks stunningly dynamic, but also offers excellent running qualities on both dry and wet roads.
    Boxes 'n stuff
    Vancouver, WA
    Audi A3 Sportback: Equipment and Trim
    The standard equipment
    Like its three-door counterpart, the Audi A3 Sportback sets the standard with an equipment specification that befits its premium status. Three separate model lines – the Attraction version full of character, the particularly sporting Ambition model, and the highly exclusive Ambiente version – enable the customer to turn each A3 into their personal dream car.
    Standard items on Attraction models include electric front and rear windows and central locking with radio-operated remote control. It goes without saying that safety features such as the Electronic Stabilisation Program ESP, the new front seats with active head restraints and the sideguard head-level airbag system are inclusive on the A3 Sportback.
    The body is available in a range of 15 colours, from Arctic White to Brilliant Black and from Toucan Yellow to Deep Green, metallic, with three versions available at no extra charge. The body colour Dakar Beige, metallic, a new addition to the A3 model range, is reserved exclusively for the A3 Sportback.
    Individual character and style – two concepts that play a central role in the A3's success story. Indeed, this is precisely why the Sportback adheres to this equipment concept with three very different model lines that appeal to different groups of customers with varying demands and expectations.
    Attraction: This is the modern interpretation of the A3 theme full of style and character. From outside the Attraction models are clearly recognisable with their 16-inch wheels – as an option in alloy – running on 205/55 tyres. The "Module" fabric comes in four colours (black, beige, light grey or deep blue) as standard on the seats.
    The surfaces and applications are available in grain-structure and matt-painted plastic in the colours black or deep blue. The Attraction specification likewise includes an easy-grip 4-spoke steering wheel.
    Ambition: A more dynamic interpretation of a sporty vehicle – and the version that is most in demand. Ambition models are equipped with 5-arm cast aluminium wheels measuring 7.5 x 17 inches, with 225/45 tyres. Five colour combinations of "Matrix" cloth are available for the interior: black/grey, black/blue, black/red, deep blue, and light grey. The trim inserts are in high-gloss black or deep blue.
    In addition to the standard equipment on all Sportback models, the Ambition models come with sports suspension, sports seats at the front, a three-spoke leather-covered steering wheel, and a height-adjustable passenger's seat. Other standard features are fog lights, aluminium door sill trims and the sun screen on the luggage cover.
    Ambiente is synonymous with palpable comfort. Cast aluminium wheels in 7-arm design with 205/55 R 16 tyres clearly identify the third line in the A3 range from the outside. Inside, there are four colours to choose from (black, deep blue, light grey, and beige) for the "Metric" upholstery. The noble wood Vavona Bernstein is a highly stylish material that gives the applications a special note of distinction.
    A four-spoke leather-covered steering wheel and a centre armrest at the front are further visible attributes of the Ambiente models. In addition to the standard range of equipment, the height-adjustable front passenger's seat, an interior mirror with an automatic anti-dazzle feature as well as a light/rain sensor with an integrated coming-home/leaving-home function, cruise control, an outside temperature gauge, a storage package and an interior lights package all help to provide the finishing touch.
    Optional extras
    Over and above the various features offered by the three model lines, A3 drivers have many other options to choose from. Indeed, the sheer quality and diversity of these options reflect the declared aim of the new Audi A3 to introduce the standards of larger and more luxurious cars into the compact segment. The following list is therefore only a selection of the options available:
    A total of twelve optional exterior colours – four metallic and six pearl-effect finishes – enables A3 drivers to choose their favourite paintwork.
    Various cast aluminium wheels measuring 6.5 x 16 or 7.5 x 17 inches give the car a sporting touch from outside, in more than merely visual terms. 18-inch cast aluminium wheels in two different designs by quattro GmbH are likewise available from the outset. A3 drivers need not forgo attractive design in winter, with the choice of cast aluminium wheels and one steel wheel measuring in the sizes 6x16 to 7.5x17 inches.
    The sports suspension - standard on Ambition models - lowers the entire body by 15 millimetres and makes the suspension and damping particularly dynamic.
    The open sky system large-area glass roof, which has been developed specially for the Sportback, is a remarkable concept. The roof is glazed all the way from the windscreen to the rear window, further emphasising the Sportback's sporty character.
    Compared with a conventional sliding roof, the open sky system allows twice as much light into the car thanks to its larger area. Both front and rear occupants have a roller blind for protection against direct sunlight.
    The optional roof rails that further accentuate the coupé-like profile of the roof are of a new design characterised by slender elegance. They can also be combined with the open sky roof if desired.
    Xenon headlights, an immediately visible feature offering improved visibility, can now also be ordered in the compact class: both headlight range and intensity are increased considerably as a result. This equipment features also comprises a headlight cleaning system as well as automatic dynamic headlight range control.
    Halogen fog lights, again standard on the Ambition models, maximise visibility even in difficult weather conditions.
    The interior mirror with automatic anti-dazzle function including a light/rain sensor, automatic headlight control and coming-home/leaving-home function (standard on the Ambiente model) serves to raise visibility and convenience to an even higher level.
    The interior lights package (standard for Ambiente) comprises features such as illuminated inside door handles, footwell and door sill illumination, illuminated vanity mirrors and storage compartments, ambience illumination and reading lights at the front and rear.
    The garage door opener integrated in the sun visor can be programmed to different frequencies.
    Cruise control (standard on Ambiente models) consistently maintains all speeds above 30 km/h, provided sufficient engine braking is available.
    Side airbags at the rear further increase safety for the outer rear passengers.
    The tyre pressure monitoring system that constantly monitors the tyre pressure in all four tyres and alerts the driver both visually and acoustically is a new addition.
    The acoustic parking system facilitates the process of reversing the car into parking spaces by emitting audible signals that change progressively according to how far the car is from an obstacle.
    The driver information system (standard on the Ambition models) com-prises an on-board computer, radio frequency display, outside temperature con-trol, and radio-controlled clock.
    The navigation system with acoustic route guidance offers the driver additional convenience and even greater driving safety.
    The new Audi radio and navigation system plus with DVD drive and 6_-inch colour monitor (optionally with analogue TV reception) provides almost unrestricted navigation throughout Western Europe, as well as playing audio CDs or reading MP3 memory cards. Its operating principle follows the same clear logic as the Audi MMI that is familiar from the A8. The display shows the map and the visual route description, while the driver information system translates the accompanying directions into pictograms and supplements these with further information on distances and the arrival time.
    The new storage medium of the DVD for the navigation system provides more than ten times the storage capacity of a conventional CD ROM, coupled with a noticeably faster access time. Almost the entire road network of Western Europe can now be stored on a single data carrier, overcoming the inconvenience of having to change the CD when the driver crosses a national border.
    A further advantage is that the navigation system calculates the route much more swiftly than on CD-based systems. This is particularly noticeable during map loading and when using the zoom function.
    The audio systems offer the ideal combination of convenience and equipment options for every customer:
    - chorus with cassette player, ten loudspeakers and diversity aerial for optimum reception
    - concert with CD drive (instead of cassette player)
    - symphony with a cassette player and a six-disc CD changer
    The Bose Sound System with dynamic compensation creates the atmosphere of the concert hall in the A3 Sportback.
    Mobile phone preparation for D and E networks offer convenient voice control for entering and dialling up to 50 different numbers. Digital signal processing serves to compensate noise and guarantees excellent voice quality. A multifunction steering wheel brings a particularly high degree of convenience. The Bluetooth interface guarantees the system's future compatibility.
    Deluxe automatic air conditioning with sun-position control offers separate temperature adjustment for the driver and front passenger and comes in addition with an air quality sensor that automatically switches to air recirculation as soon as ambient air quality drops below a certain level.
    Leather-covered steering wheels in three- or four-spoke design turn every bend into a genuine pleasure, with multifunction control also available for various versions with additional buttons for operating the tiptronic and infotainment systems.
    Sports seats at the front provide excellent lateral support and are manually height-adjustable (standard on the Ambition models). Leather or leather/Alcantara seats are available for Ambiente and Attraction models.
    Electric seat adjustment for the driver and, optionally, the front passenger complete with an electrically adjustable lumbar support makes finding the ideal seat position a convenient matter.
    Seat heating including for the outer rear seats is a new and hitherto unique option in the compact segment.
    The storage package (standard for Ambiente) includes storage nets on the front seat backrests, a storage compartment beneath the driver's seat, a map compartment in the glove box, storage nets at the front of the centre console and a net and bag hooks beneath the luggage compartment cover.
    The through-loading facility, optionally with a removable ski bag, is very convenient for transporting long objects – up to four pairs of skis or two snowboards.
    The luggage compartment package comprises a universal net that is fastened to the floor of the luggage compartment or the rear-seat backrest, as well as a power socket within the luggage compartment area and a small-items net to one side in the luggage compartment.
    *Fourtitude
    Even my dishwasher is made by Bosch.
    I have Vag-Com and am happy to help... PM me for more info.
    Veteran Member Four Rings idrivemyself's Avatar
    Boxes 'n stuff
    Vancouver, WA
    Additional photos can be found here: http://www.fourtitude.com/gallery/ga...(A5)/Sportback
    Veteran Member Four Rings Silvant's Avatar
    Feb 12 2004
    Past: 95 Stg3 UrS6 Avant, 01 Stg3 A4 Avant
    LA | CA
    ahhh and the 2.0TFSI arrives!!!!
    that is a slick little ride. damn.
    full sport with rails and 18's please.
    wonder what chip and exhaust will be doing for them and what these will cost over here...........
    Mr. Inappropriate Porno Avatar Man.
    " So do us all a HUGE FAVOR silvant...STOP breathing our air..and go kill yourself...you punk POS...."
