Results 1 to 31 of 31
    Veteran Member Four Rings shehatezme's Avatar
    12 BMW F10 528i | 02 Honda S2k
    Bay Area
    Does stock lugs work on aftermarket wheels?
    Or do I need to get new lugs? If so where can I get them for cheap? Wheellocks?
    Veteran Member Four Rings 1sicknickel's Avatar
    My laundry, old records, tools
    Orange County
    You can use your stock ones. The problem is that you wont have locks to protect them
    My Personal Photography and Cinematographer Website
    “Photography is not just a point and shoot process, it is a creative development that one seeks as an art form to capture moments in time” -Nickel 09
    07 Audi A4 Avant 2.0T Sold
    04 Audi A4 1.8T Sold
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Its not a bad idea to get longer lugs..
    PureMS can prolly get you some by friday Ben..
    Bay Area
    I don't even know what size lugs I need.
    Bay Area
    Do you run stock lugs? with Wheel locks? The wheel locks go over your existing lugs right?
    Orange County
    Actually I am not they dont have any in at SPP that match my wheels and also the lock is a extra lug stud that you replace with one of your stock lugs
    Bay Area
    So you are running stock lugs but without locks? I think I am reading that right?
    Orange County
    Yes I am running stock lugs w/o locks
    Veteran Member Four Rings hyperspeed's Avatar
    Feb 13 2004
    Chino Hills, CA
    locks just look exactly like another bolt, but they have a weird pattern.. stock bolts work for some wheels, like iforged, but my wheels i needed longer bolts which i got from SPP. i then got RAD locks from pureMS.
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Who's got 8.5" wide rims, and are using aftermarket lugs?
    How long are they, because I'm using my stockers on my 18X8.5's right now...is this bad?
    Veteran Member Four Rings audidood's Avatar
    56 Oval, 2017 Tacoma
    san diego, ca
    i wouldn't use my stock lugs for aftermarket wheels. they're just too visible, and you might need to switch from ball joint end style to acorn style lugs. and they look purdy with new lugs.
    2004.5 USP A4 1.8t with mild mods.
    1956 VW Bug with major mods.
    Veteran Member Two Rings
    Jun 09 2004
    2005 Audi A4 Avant, 2007 Lexus IS250
    Otterberg Germany
    Unhappy
    From what I understand, the lug nuts that you use depends on the seat type (conical/tapered, ball radius, flat)and also the length. With my 18X8.5 oz antares I had to get new lug nuts with the seat type of my rims. Also the length helped my peach of mind because more than a couple threads was holding them on. But I also heard that the proper bolt length is needed because it could have an affect on our ABS. But maybe I don't know what I'm talking about.
    Bay Area
    So looks like i need to fork over for some lugs?
    san diego, ca
    yeah, u can get a set of lugs at discount tire for like $40+. from what they tell me, the stock wheels are ball seat, and the aftermarket are acorn (conical/tapered). when i had my BBSs on my B5, i needed to use different, longer lugs that tirerack was generous enough to throw in with my order, as well as a set of wheel locks. if you're putting on your 5-spoke 16s from your b5, you should be fine with your stock lugs.
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    Re: Does stock lugs work on aftermarket wheels?
    It really depends on the wheel you are using. Our OE wheels are a ball-type, which uses the ball seat (round) on the lug bolt. Some wheels require a conical (angled/flat) seat, which will require conical lug bolts.
    -Jeff
    Registered Member Three Rings
    Feb 29 2004
    2005 Sebring S2000
    DubC, PA
    You may need new lugs depending on the wheel. For instance, my stock lugs worked fine on my rs6 replicas. When I had giovanna attacks, I had to order different lugs. There are two different types, conical seat, and ball seat. I forget what the stock lugs are....but just to be safe, its best to ask the wheel manufacturer which lugs to use.
    *edit*, just looked it up. Stock wheels & lugs are ball seat. So if the wheel manufacturer says you need conical seat lugs...you need to order new lugs, otherwise, use the stock ones.
    *edit again* looks like jeff beat me too it
    Jun 09 2004
    04 Audi A4 1.8T 6spd
    Union City CA
    Re: Re: Does stock lugs work on aftermarket wheels?
    -Jeff
    Exactly the reason why i changed my bolts on my new wheels when i got them.
    MatT~
    NoFuknJoke
    Veteran Member Three Rings KaiDaRudeboy's Avatar
    2003 A4 3.0Q
    Hawai'i/SoCal
    I've got 8.5" wide wheels and am using stock lugs... I also have RAD locks from PureMS.
    -Kai
    Feb 10 2004
    2019 Mk7.5 Golf R His/Her
    Eastvale
    exactly what Jeff said...most aftermarket wheels other than the aforementioned, Abt and Oettinger uses the OE lugs because they are ball seat. I just picked up some RAD locks from PURE Motorsport they're the 32mm variety. Ben if you're getting aftermarket wheels brand new you should be getting new lugs to go w/ it.
    I would advise you not to run the ball seat lugs if the wheels take conical as you wont be able to torque them down properly.
    Instagram: @daohaus_garage
    Feb 12 2004
    Everywhere
    How long of bolts do I need to get with 18X8.5's? I'm using stock bolts now!
    Feb 10 2004
    Eastvale
    that's the thing depending on offset and the center design of the wheel itself plays a part in lug lengths. Lemme go put my locks on the wheels and i'll measure the Sportec Lugs to give you an idea.
    Feb 10 2004
    Eastvale
    The lugs i got from sportec are 30mm long conical seating.
    Feb 13 2004
    Chino Hills, CA
    my rad locks are 30 and my lugs are 29
    it all depends on the wheel itself.. not really depth of rim ..so by me saying 19x8.5 is completely useless to ur application
    Feb 10 2004
    Eastvale
    did u get the 30mm from PURE Motorsport? Mike just had 32mm
    PureMS.com
    Get new lugs.
    As most have correctly mentioned wheels can come with different styles of "seats" where the bolt meets the wheel.
    Cone (taper), ball, acorn, and flat. Most common on the Audi/VW is the Cone for aftermarket wheels, and ball for genuine, or some OE wheels.
    Lug bolt length is the second criteria. Stock lug bolts are 27mm. Aftermarket wheels vary anywhere from 25mm up to 35mm.
    Both of these specs are critical in making sure the wheels stay on the car. Using improper lug bolts can cause them to loosen, and sometimes even dent or crack the wheel, if an improper seat style is used.
    RAD makes lugs and locks in dozens of lengths, styles, and sizes.
    Feel free to email if you have any questions.
    Feb 13 2004
    Chino Hills, CA
    yeah i got them from purems... lemme chk if they reallky are 30 or not.. i thought they were. could be wrong tho.
    Feb 10 2004
    Eastvale
    i think they be 32 as mike pm'ed me saying that they have em in 29 and 32 mm
    Feb 21 2004
    SF Bay Area
    Other people have already explained ball seat vs. cone seat, so I won't repeat. If they are aftermarket wheels, more than likely you need cone seat.
    Don't mix and match. Not only will it not torque down properly, you will likely damage the wheel.
    Lug bolt length depends only on the thickness of the wheel at the holes. Offset and width have nothing to do with it.
    Stock lug bolts are 27mm. You need 7 complete turns/rotations of the lug from the time the first thread catches to when it bottoms out before torquing. I would try your stock lug bolt with the aftermarket wheel WITHOUT TORQUING to check length. Less than 7 turns = need longer bolt.
    Bay Area
    Bought some =)
    Veteran Member Four Rings A4Shizl's Avatar
    Jun 11 2004
    2003 Audi 1.8T, 2005 Honda
    Inland Empire
    they worked with my sportecs
    Feb 10 2004
    Eastvale
    you're using stock lugs on your sportecs? You better check them out bro...torque every once in awhile i know for a fact that they come longer than the OE lugs and are conical...
