Page 5 of 7 FirstFirst ... 34567 LastLast
Results 161 to 200 of 271
  1. #161
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    Re: All your Blow Off Valve (BOV) & Diverter Valve (DV) / By-Pass Valve (BPV) Questio
    Quote Originally Posted by Tea Mandy View Post
    I could be mistaken but I'm quite sure the guy I bought my S4 from had the Forge 60/40 bov. After he blew up his K03's, he wondered if it was partly from this. Something about inappropriate backpressure on the turbo's... I can't remember for sure. Will try to ask him for more details.
    Yeah, definitely let me know about that before I Fuk up my car
    2001.5 S4 Nogaro Stage III
    Test Pipes|AWE Twin1|Forge Hybrid BOV/BPV|JHM MBC|VAST Tuned|FrankenTurbos|034 Mounts|Hotchkis S-bars|RS4 Grille/Knob|50w HIDs|Vogland/Bilstien|JHM SS
    02 Suzuki GSXR Telefonica Movistar
    88 Bimmer E30 Vert
    98 Jetta TDI
    90 Corrado G60 Sold!
    92 Audi 100 Sold!
    http://photobucket.com/nateS4
  2. #162
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    It would not be solely because of this. k03s tend to catastrophically fail at the most inconvenient times. The only way he'd be getting backpressure is if the valves weren't doing anything or if one of the paths (atmosphere or intake) were blocked, which is unlikely. mileage, how hard the driver drives, warm up/cool down, etc.. the list goes on. these are all variables in when the turbo goes.
    nate, the air from hte DVs aren't going into the MAF, the MAF is before this on the intake tract. like said before, some cars work well with splitters and blowoff valves, some do not. Just try it out and see how much different it works. You're not going to fuck up your car THAT much by running them for a little bit.
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
  3. #163
    Apr 25 2008
    Baltimore
    ^^^ It's tough to $320 and not be able to continue to use the part, but what is the plug for above the TBB called?
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
  4. #164
    Jul 07 2007
    Tempe, AZ
    ahh the magic of ebay or the classifieds! you can use the part, but you won't have a perfectly running car!
  5. #165
    Aug 08 2008
    BC
    Talked to the previous owner today...
    Turns out he felt the diverter valve took out the turbo on his Golf, not the S4 (splitter valve was not able to blow-off 20psi)
    He found though that the Forge splitters on the S4 had a bad effect on spool time, so it was still making the same power just a longer spool.
    This is just what he found from his testing. And he thinks he probably blew his K03's from running them hard at 18psi. :)
    Hope it helps!
  6. #166
    Jul 07 2007
    Tempe, AZ
    the air does not get rushed into the intake, unlike diverter valves, which is why spool is longer. it just gets put into the atmosphere.
  7. #167
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 24 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    i run a hks bov and one 710n with no problems what so ever. i know the hks sounds pretty gay but if you take out the fin insert it makes it sound totally different. Ko3s must be one of the worst turbos made(for failure). Tell you the truth my car is alot smoother and more easier to drive with the hks bov and one 710n. compared to two dv's
  8. #168
    Jul 07 2007
    Tempe, AZ
    idk how it makes the car "easier to drive"...
  9. #169
    Aug 24 2008
    Santa cruz
    just like i said... it makes my 1-2 shift much smoother i have no idea why? when i had the 710ns in the 1-2 shift is more rough.
  10. #170
    Veteran Member Four Rings will175's Avatar
    Apr 25 2007
    Las Vegas..Hawaii..Nor Cal
    Will that actually be okay to run it that way, one 710n and a BOV
    Train Hard, Go Hard, But always be Humble.
  11. #171
    Aug 24 2008
    Santa cruz
    i beat a LS1 with it like that
  12. #172
    Jul 07 2007
    Tempe, AZ
    wow that has to be one of the most non informative answers of all time.
  13. #173
    Apr 25 2007
    yah I know but its audizine...I was just wondering if it would do any harm to our car, I would think so but Im no expert.
  14. #174
    Aug 24 2008
    Santa cruz
    Well i did just find out the hks valve was throwing me into limp mode when i drove it for a long time along with lots high boost blow offs on the freeway, probably interpreted it as a boost leak and threw a positive deviation code. So no more valve, it was fun while it lasted but the 710N's going in for good.
  15. #175
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    ^ Sorry you had to find out the hard way!
    --Adam
    Have questions? E-mail me.
  16. #176
    Veteran Member Four Rings S-Power's Avatar
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    What is the noise made by the DV when your shifting on WOT ? ? ?
    Like the little air sound ? ?
  17. #177
    Sep 14 2006
    14 GLI
    A little air sound is normal ... a lot could mean you have a boost leak or the DV is bad.
    --Adam
  18. #178
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    okay bro, but what if there is no air sound at all?
    DV is bad ?
  19. #179
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    IF you hear no air then the DV is bad or what ? ?
  20. #180
    Jul 07 2007
    Tempe, AZ
    www.audidiy.com
    under the b5 s4 part, there is DV testing.
    do you have a boost gauge? If you go into boost and the boost doesn't dissipate really quickly, it maynot be functioning.
  21. #181
    Senior Member Three Rings Boosted-S4's Avatar
    Aug 03 2008
    Silver S4
    Im looking into the turbosmart compact...will there be a problem
  22. #182
    Jul 07 2007
    Tempe, AZ
    its hard to say, dude.. some cars don't really react to them, some dislike them. it all depends on how you have them set up (recirc/ atmosphere). give them a shot and tell us. that woudl be the most helpful thing to do.
  23. #183
    Aug 03 2008
    Silver S4
    from turbosmart specs that DV/BOV can do 3 things...full diverter valve,diverter/atmospheric or 100 atmospheric...they say that both first and second options are perfect for the car but the thirs is use at own risk...i searched forge and they have a similar one....also a buddy of mine who owns a 1.8t is running the turbosmart and he loves it...it produces the bov sound but not as loud!!!
    im gonna take a chance and ill keep u guys posted!!!
    thanx for the info!!!
  24. #184
    Sep 14 2006
    14 GLI
    Good luck!
    To the poster asking about "no sound" -- that would be normal.
    --Adam
  25. #185
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    How Important is it to Re-grease the DV's ?
    How Often Should it be done?
    What are side effects, if they arent greased ?
    Thanks ! ! !
  26. #186
    Apr 25 2008
    Baltimore
    Quote Originally Posted by 1997gtx View Post
    ^ Please try it and let us know how it goes. Most people don't wanna spend the money on a split, but i'm glad someone is :)
    --Adam
    Well, when I was @ H2O I bought 2 Forge Hybrid Bypass/Recirc Vales and so far so good, no codes! Now the only way you hear the woossh sound is to have the sunroof cracked and the music down pretty much, so its definitely recirculating most of the air. Oh and I couldn't pass up the deal they gave me $100 each. for Forge, and on a side note they are probably going to become an Advertiser on here.
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
  27. #187
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    Quote Originally Posted by S-Power View Post
    Thanks ! ! !
    Can someone help me out
  28. #188
    Sep 08 2008
    2K S4+79Merc300SD+65Barracuda
    Rohnert Park CA
    Why does almost everyone use piston type DV....I use APR R1s, no maintenance needed and from what I understand diaphram based are better...yes-no?
  29. #189
    Sep 14 2006
    14 GLI
    People had some issues with the R1 when it first came out. I believe they tweaked the design, but many people were hesitant to go with it afterwards. Glad to hear it's going well.
    Should be re-greased once a year. Bad part would be old and worn out rubber gaskets and pistons -- would eventually lead to small boost leaks.
    Forge is already an advertiser on the forum.
    --Adam
  30. #190
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    --Adam
    Thanks Adam! Much Appreciated
  31. #191
    Sep 14 2006
    14 GLI
  32. #192
    Established Member Two Rings RitchS4 914's Avatar
    Sep 29 2008
    Yonkers NY
    which DVs combined with what intake gives the best sound... not expecting anything major like a BOV sound but just curious... thanks
    00 silver b5 s4
    -stage 2+.. Soon to be stage 3...
  33. #193
    Jul 07 2007
    Tempe, AZ
    My Forges with the Darintake mod makes some sound, but not a lot.. I've heard some Bailey's without the darintake and they were actually a little more loud than mine. Try those with the EVO intake and you will probably get some good sound. But It's REALLY a waste of moeny for an intake... our intakes are pretty much as good as they can get stock.
  34. #194
    Senior Member Two Rings dennisS4's Avatar
    Mar 23 2008
    Tri State aRea
    the extra boost flows through a piece of cloth wrapped rubber and its prone to being brittle over time, what is the best replacement? Will a standard Samco vacuum line work in 3mm??
  35. #195
    Sep 14 2006
    14 GLI
    Yep -- any line will be fine.
    --Adam
  36. #196
    Veteran Member Three Rings Ianxcom's Avatar
    Jul 30 2008
    Socal/Denver
    I was at a local shop today and i asked about 710n's running on a stage 1 s4. The shop employee said that they are crap and that they are the same as a stock DV only with a stiffer spring and that they will still take a dump. I dont know if he was trying to push another more expensive product that i dont need or if he really believes that. Makes me wonder if its only the springs that suck on the stock DV or the whole thing.
    Thoughts?
  37. #197
    Junior Member Two Rings AudiSon's Avatar
    Oct 26 2008
    2000 S4
    TheRoad
    Question Re: All your Blow Off Valve (BOV) & Diverter Valve (DV) / By-Pass Valve (BPV) Questio
    hey I'm tryin to find some inexpensive blow off valves to replace the stockys where should i look?
  38. #198
    Jul 07 2007
    Tempe, AZ
    Quote Originally Posted by Ianxcom View Post
    Thoughts?
    well, he clearly didn't know anything about the 710N. There are a LOT of stage III S4s running 710Ns just fine for many miles under high boost. it's a proven fact that 710Ns can handle from stock to stage 3. I believe he was just trying to make you spend more money.
  39. #199
    Sep 14 2006
    14 GLI
    Quote Originally Posted by AudiSon View Post
    Look no further than 710N's ... They are the stock DV's off an Audi TT.
    --Adam
  40. #200
    Jul 30 2008
    Socal/Denver
    Quote Originally Posted by Jung View Post
    Thanks. Thats what i figured.
