Originally posted by fongaroos
can you even do that?
there really isnt all that much room behind the fog light where the OE SMIC is...
were you thinkin about getting a BIGGER CORE or something to replace the OE SMIC?
and why would everything else run hotter just because of an IC?
I am not very familiar w/ the A4's setup as far as clearances go, but on my Supra, there was plenty of room. The FMIC i had on that car was a 4-row (enough to cool 1000hp cars). I bought it for $1275, but mainly to replace my cracked rubber IC hoses, and hardpipes for my car at the time cost nearly $550. When I bought the FMIC, i had issues installing it, for I had to remove (and even CUT) a lot of the plastic duct/panels in order to clear the FMIC, that alone screwed up my cooling efficienct. If I could do it again on that car, I would use a larger core stock SMIC instead of the FMIC.
Sometimes better cooling does not always need a "bigger core". Some IC's cool better than others on design alone. Designs include the positioning of the fins, to the overall layout of the core. This is why some IC's also have less pressure drop than others, and vice versa.
From what Drew and others said, our cars still breath through the top grill section, and his coolant and oil temps didnt change much. I wouldnt mind giving it a try (im always open to new things). But personally, I like to retain the "OEM" stock look on the car, though those FMIC's DO look BADASS :)
Here is a picture of my 4-row FMIC, it has more cooling area than my radiator and AC condensor combined, but less than 1/2 of it was exposed to the outside airflow (which was another problem):
