Results 1 to 16 of 16
Thread: Speaker size
    Apr 21 2004
    2013 S4 6MT, 2011 Escalade
    Coopersburg, PA
    Speaker size
    What is the size of the speaker on the rear deck lid? Its blown now. I want to replace it. I have the bose package if that makes a difference. Thanks.
    2013 S4 6MT // sport diff // B&O // Phantom Black // Black Leather and Black Alcantara
    Veteran Member Four Rings MKGIY's Avatar
    2012 S4, 2012 GMC Acadia
    New Jersey
    I believe they are 6.5.
    Mike
    Apr 21 2004
    Coopersburg, PA
    6.5" around, as in circular?
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Yea, 6.5's..
    5.25's can fit in the front doors..
    New Jersey
    If you want an 5.25 components, I have a set of MB quarts that need a home.
    Mike
    Feb 15 2004
    2009 M.B. C300 Sport 6Sp
    T.O. Canada
    5.25's can fit w\o any work??
    I thought all we could do was get a set of 4" to replace the front ....if we didn't get adapters...
    btw: any 4" speakers would be able to hook up and install in the stock location, correct?
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    5.25s will fit rather easily, and you don't need to make adapters, just get some metal strapping and run the strapping from one of the mounting points on the door to one on the speaker. If you do a search you'll find a post that explains what I'm talking about. the stock speakers are 4". The reason you need "adapters" is because stock speakers have 3 mounting points, most aftermarket speakers have 4.
    1999 A4 1.8TQ
    San Jose, Ca
    Not exactly man. It'll depend on what year car you have, at least not on my 99. Right now I have some 5.25s up front hooked on by that strapping method, but believe me, its nothing like the diagram pictures. I really should have taken a picture, because I devised another way to make it work, but it is not prettty, god lord it is not pretty.
    Anyhow, right now it serves well, but i just found a place that still sells adapters, so i just ordered some: http://caraudiosecurity.com/catalog/...oducts_id+1883
    Based in UK, ships worldwide. They also have rear adapters too. Buy them if you're not sure.
    I will soon be replacing the hell behind my door panels with these nice looking things. Cross my fingers they also fit and work on my car (from hell). Then finally maybe i can bump in peace.
    Apr 21 2004
    Coopersburg, PA
    Any opinions on what I should replace these with? Trying to do this as cheap as possible, but still retain good sound quality. Thanks.
    Registered Member Four Rings joeya103's Avatar
    Apr 04 2004
    98.5 A4 1.8T Tip FWD
    Northern VA
    Don't you also need to cut out some of the door panel for the 5.25"? The hole is designed for a 4" speaker so basically without any modifications, the 5.25" speaker would be blasting some of the sound into the door.
    Definitely need to get 5.25...these 4" ones produce no mid-bass/bass =(
    Veteran Member Three Rings Brrman's Avatar
    Indianapolis
    that depens on the speaker. I had to trim a slight amount off my inner door panel, but it was nothing you would notice from inside the cabin of the car.
    2019 S4 Prestige
    RIP... 2013 A4 Allroad
    SOLD 2007 A4 2.0T S-Line Ti (APR stg1, Koni Coilovers, LED Tails)
    SOLD. 2000 A4 avant 1.8T (GIAC stg1, Bilstein/H&R)
    RIP... 1998 A4 1.8T (GIAC stg1, Bilstein/Neuspeed)
    Account Terminated Four Rings MR VTEC's Avatar
    98.5 Audi 1.8TQM
    Brooklyn
    n e one have a link to da write up on front speaker install from 4" to 5.25" please...
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    Hey bro, I thought your Audi was sold?
    The harder I practice, the luckier I get.
    - Gary Player
    Veteran Member Four Rings buck's Avatar
    Feb 16 2004
    '05 Tacoma & '03 Yamaha R6 & '14 Yamaha FZ-09
    Simcoe County ON, Canada
    Stock 4" on right, new 5.25" on left. I'll fit with some modifications and a mounting adapter or ring. My ring came with the speakers and I just drilled 3 holes in it where the stock mounts are.
    APR 93 Octane Chip, VDO Boost Gauge, 710N, Koni C/O's, Carbonio CAI, High Flow Coconut air freshener.
    60% of the time, it works EVERY time.
    Veteran Member Four Rings needforspd's Avatar
    Mar 05 2004
    Deceased 01.5 A4 1.8tm
    Sylmar Hills
    it probably is. this post is over a year old n was brought back from the dead ...
    buck any problems w/ the speaker hitting the door? new compared to old seems to be a big difference in thickness
    Do you have a need for speed? Then drive it like you stole it!
    Feb 16 2004
    HA! just read the original post date... yes yes, this is old.
    ... but I have no problems with the speaker hitting the door. It's close... but no issues.
