Results 1 to 15 of 15
    Feb 29 2004
    99 Audi A4
    Long Island, NY // the ATL
    Boosting at 15 psi max???
    i just replaced my stock diverter valve with a 710N. the boost still never goes above the 15 psi mark. i was expecting it to go up to like 17 or 18 when i replaced the DV. whats goin on?
    Feb 29 2004
    99 Audi A4
    oh yeah...im chipped obviously. APR.
    Feb 13 2004
    <> Posts: 9913
    I believe that program is a 1bar program (which is 14.7psi), so everything should be fine.
    Don't worry, because boosting more than that is useless on your K03, and even if you boost more, it will not provide any increased power.
    -Theodore Roosevelt, 1907
    Veteran Member Four Rings buck's Avatar
    Feb 16 2004
    '05 Tacoma & '03 Yamaha R6 & '14 Yamaha FZ-09
    Simcoe County ON, Canada
    is it peaking at 15psi?
    my apr chip peaks at almost 20psi and holds at around 16psi.
    if you're holding at 15psi, that may be around where it should be. If you're peaking at 15psi.... that sounds a little bit low.
    Which program are you running..... mine's the 93oct one...
    APR 93 Octane Chip, VDO Boost Gauge, 710N, Koni C/O's, Carbonio CAI, High Flow Coconut air freshener.
    60% of the time, it works EVERY time.
    Active Member Four Rings
    Nothing new, sounds about right.
    Veteran Member Four Rings D Piddy's Avatar
    Feb 12 2004
    Me: 2010 B8 A4 S-Line In the Family: BMW Z4M, BMW 335xi, Range Rover Evoque, Honda Element
    Washington, D.C.
    i don't have the APR, i just got the GIAC 2 days ago. mine peaks at 17-18 and i doubt that 2-3 PSI makes much of a difference.
    Feb 29 2004
    99 Audi A4
    im non drive by wire so i think that means that i have the 91 octane program.
    also the thing is, i dont think that i am spiking at all. the needle never goes beyond the 15 psi mark. when in something like third gear (a tall enough gear to actually have time to see what the gauge is reading for the duration), the boost reaches 15 and stays there. it does not shoot up then drop down a few psi and then hold there which is what i believe it should do when it "spikes."
    can anyone explain this?
    Feb 13 2004
    <> Posts: 9913
    In certain gears, when you first really hammer it, you sometimes see the gauge fly up, or "spike". It's quite meaningless, since it's not sustainable boost. The really number you care about is what you hold, and how quickly it comes on.
    Again, boosting in the high teens and 20's does not mean you're making more power. It just means your turbo is blowing more hot air. The K03 is happiest around 12-14psi. The sport K03s can handle a bit more and still be efficient.
    ^^^^^what he said^^^^^
    1999 A4 1.8TQ
    San Jose, Ca
    Awww man, my sustained 20+psi (k03) boosts are useless...
    I should take some kinda photo next time.
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    my apr only spikes 15, I might get the N75 J vave.
    May 20 2004
    More cars
    Never Land Ranch
    i still have the stock DV and no boost guage, i think i should really get them both, i hope i'm not under boosting
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    will dat J valve turns to limp mode for ndbw??
    IG:@steadysupreme
    Pics&Detail
    Feb 13 2004
    <> Posts: 9913
    It may. But some have had said they run it with no problems. If you're not chipped, then you shouldnt' have to worry about it.
    You have to be careful if you're chipped, since sometimes it can conflict with programming. Rumor has it that chip software was written assuming the stock N75 valve would be in place, so it would not account for the more aggressive J valve, which can cause higher spikes that may throw you into limp mode.
    Veteran Member Four Rings quattroanillos5's Avatar
    Feb 13 2004
    2004 S4 MT6
    Jersey
    I have a 99.5 with giac software and mine holds @ 15psi..... the butt dyno says she's running fine.....
    sold:
    1999.5 B5 A4 1.8T quattro MT5
    current:
    Moro Blue 2004 B6 S4 MT6
