Results 1 to 8 of 8
    Registered Member Three Rings aborchew's Avatar
    Feb 25 2004
    '98 Audi A4 2.8QM
    Chicago, IL
    K&N Drop-In Filter
    What is everyone's experience with these? I went ahead and ordered one, because I needed to replace my air filter anyway.
    Will I notice a significant gain in HP or sound with my 30v? I'm sure it'll be a lot better because my air filter is dirtier than a saigon whore.
    Veteran Member Three Rings Kurzer's Avatar
    Feb 12 2004
    MkV VW Rabbit
    Beaverton, Oregon
    I found that my 12V became sluggish (... more than normal) I plan on getting a stock air filter if I can't finger up a cold-air system for mine. Even if I can figure it out, I'll most likely install the cold air ducting and leave the stock filter.
    Thank you: MatrixIntegrated
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    my 1.8t ran great with it and i had on in for 40k miles before i had to switch to an intake with my new setup.. if anyone wants to get rid of their stock airbox let me know i want to make myself a custom airbox but dont wanna cut up my stocker..... dont mean to threadjack....
    Registered Member Two Rings
    Feb 13 2004
    Sacramento
    before ppl come in here whore it all with stock is the best/CAIs are the best yada yada blahblahblah.....
    i just want to say.... the K&N is probably better than your stock dirty filter. just be careful later when u clean it... make sure you dont get oil on your sensors...
    otherwise... dont worry about whats going to make you 1 hp more because we all know A4s are still not going to beat anything significant with stock filter or k&n filter or evom intake or whatever filter you put in your car, unless its a civic. but if the civic has a CAI then your screwed.
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    You will notice better high Rpms speed, not much but better, Btw, Martha Stewart can rot in jail.
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
    Senior Member Three Rings EuroTall's Avatar
    Feb 15 2004
    Tampa, FL
    ma ma ma ma ma ma Martha...rot in jail you skank law breaking biatch..
    sorry just had to chime in with my 2 cents when I saw Martha on here.
    that skank was on the Board commitee with SEC so should know better than use insider information to play the stock market.
    I have no respect or sympathy for her...give her 20 years...rotten rotten rotten.
    sorry..please continue with the regularly scheduled programming.
    2001.5 - Casa White S4 [2+]
    2002 - Tundra
    SOLD: . . . 2001 Audi A4
    SOLD: . . . 1963 Dodge Dart - slant 6
    DONATED: 1985 Dodge Ramcharger SUV
    Feb 13 2004
    <> Posts: 9913
    Re: K&N Drop-In Filter
    The ITG drop-in is another great option. With the ITG foam, you don't have to worry about the oil from the K&N gunking up your MAF, and it's a lifetime part. A lot of times the K&N oil doesn't cause problems right away, but over a longer period, it can being to cause problems with the sensor.
    -Theodore Roosevelt, 1907
    Registered Member Three Rings A4-Vblack's Avatar
    Feb 19 2004
    A4 2.8MQ
    Austin, TX
    I have a 30v with the K&N filter. You really won't notice an increase in HP, but DRA4 is correct that you will rev a little faster. I think it makes the enigine sound a little different as well.
    All in all you should be happy with it.
    http://www.audizine.com/gallery/data/500/709S4_Sig.jpg
    2000 S4 / 18" RS4 Wheels / RS4 Grill / HW Val 1
