Results 1 to 12 of 12
    Registered Member Three Rings
    Jul 13 2004
    san diego
    Unhappy Mabie im parinoid
    Well the ko4's in the stratmosphere dv is in and the boost gauge is in....and after dropping a grip of cash on that, im starting to get worried that somthing will go wrong and ill be putting my savings into fixing it......i have some money left and i would like to prevent future problems.....what do i need new injectors/fuel rails/cam's/pullys...i kno there has to be some things i can upgrade to make sure i dont blow anything
    any advice?
    Active Member Four Rings
    What software are you running? Did you not upgrade the FPR or injectors?
    Connecticut
    As long as your software and associated hardware (fpr, plugs) are correct, you should be fine. Just keep up with timely engine maintenance, and if you're running an older A4 (I believe up to '98 had problems with the lines), make sure you have the updated oil lines. Other than that you should be fine.
    01 a4 1.8tqm, giac x, borla, h&r sport
    7.66 CAPS
    Jul 13 2004
    san diego
    i bought the awe kit witch came with the fpr and new plugs but no injectors and its the awe software 1999 1.8tq with tipchip
    one point eight tee
    You should be fine with that kit.
    Jul 13 2004
    san diego
    alright...thank you....have any ideas for what perfor. mod i should do next when i get some cash
    one point eight tee
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    matters what you already got, stock other than the k04 kit?
    suspension or an fmic
    I'd say suspension.
    Jul 13 2004
    san diego
    yeah actually those were the next two things i were going to do...suspension then mabie greddy fmic (cheepest ive seen)....w
    witch suspension tho...i wont have enough for coilovers but what springs an shocks?
    one point eight tee
    Depends on the kind of drop you want. Do you want it rather low or just enough to be noticeable.
    Washington DC
    That's completely up to you. do some research and find out which setup sounds like what you're looking for (various combinations perfomance vs. ride quality).
    Jul 13 2004
    san diego
    Hmmm, yeah i guess ill look around an read up...name some good companies that i should look into...im looking for performance but still a smooth ride
    one point eight tee
