Results 1 to 7 of 7
    Registered Member Two Rings Dynamic213's Avatar
    Jul 19 2004
    2004 Audi A4 1.8T
    Virginia
    Question Passport 8500 hard wire
    I know this is probably a long shot, but would anyone here know how to hard wire a Passport 8500 radar detector to the A4 with the Direct Wire Smartcord?
    Any help would be greatly appreciate it!
    Veteran Member Four Rings cj-S4's Avatar
    Not enough space here
    Somewheretown, PA
    It would be quite easy, just ground the black wire and run the red wire to the lug under you knee bolster that has power when the key is on. I don't recall which number the lug is, but you can easily find it with a multimeter.
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    75x
    Jul 19 2004
    2004 Audi A4 1.8T
    Virginia
    I heard that you can also tap the positive wire into the fuse box. Eithe jam it into a empty slot, or use a "add a circuit" fuse. Would that work, or is that a bad idea to mess with the fuse box?
    Veteran Member Four Rings Starting's Avatar
    Feb 13 2004
    98 A4 1.8t
    Central, NJ
    That is what I did and how the write up on audiworld shows to do it
    Mar 01 2004
    PA
    Get a fuse tap at radio shack. Tap the postive lead to a fuse in the fuse box (I used the empty rear wiper fuse slot...it'll need a fuse obviously). Ground the negative lead to the car. Run the wire behind A pillar and headliner.
    2001.5 1.8TQM / GIAC / Koni Sports / Neuspeed Race / Borla V2 / V&S short shifter / Greddy III TT / Ipod-IceLink
    AIM: ornjblud34 / ornjblud at work
    Registered Member Three Rings aborchew's Avatar
    Feb 25 2004
    '98 Audi A4 2.8QM
    Chicago, IL
    I stripped an inch long section of the wire, not near the end, looped the exposed copper around one prong on the accessory fuse, and reinserted it. For steath, you can push the wire behind the trim along the roof of the car and have come out along the rear-view mirror. It will turn on when the keys are in the ignition, and turn off when they aren't. There is also a bolt right near the fuse box, underneath the fuse cover, that makes a good ground.
    This was my chosen way to install it because not only is it completely reversable on both ends (it doesn't damage the car or the radar) you can remove it in about one minute. If you need to use the wire for something else, a layer of electrical tape should suffice to shield it and have it back in like-new condition.
